Discount Tire Direct 4th of July Sale
by sopususer
06/24/16 08:37 PM
Bible Students?
by Eddie
06/24/16 07:51 PM
What kind of oil drain plug gasket is this?
by Chris B.
06/24/16 07:36 PM
by Chris B.
06/24/16 07:34 PM
First time changing oil what to use ?
by sshazam
06/24/16 07:13 PM
toshiba 720p 28" TV hdmi to thinkpad vga cable?
by bmwjohn
06/24/16 06:48 PM
1988 Brougham
by momo
06/24/16 06:38 PM
Permatex Silicone Tape
by Warstud
06/24/16 06:28 PM
Walnut Grips Really Make A Difference !
by billt460
06/24/16 06:25 PM
PC freezing up when streaming sports
by sleepery
06/24/16 05:52 PM
Use a heavier oil or HM oil?
by mclasser
06/24/16 05:42 PM
Kendall GT-1 (w/titanium?) 20w-50 for airheads
by Samzone
06/24/16 05:20 PM
Koloa, codeman021, chryslerconcorde, VolCntry73, OilyWaterMIXER
58254 Registered Users
94 registered (69GTX, AEHaas, 2015_PSD, 97f150, 01rangerxl, 7 invisible), 1553 Guests and 11 Spiders online.
58254 Members
66 Forums
250764 Topics
#1624629 - 10/08/09 11:34 AM 2002 ford escape: rear door will not open
mikeinaustin Offline
Loc: austin, texas
not from the inside, not from the outside. when you hit the remote, you can hear it "unlocking" so its not electrical. i suppose the cable has come unlatched.
however, how can i remove the inner door trim and stuff with the door closed? is that even possible? how else can i unlock that door? once it is open, i would think it would be easy to actually diagnose and then fix, but with the door closed....
thoughts please!
#1624648 - 10/08/09 11:52 AM Re: 2002 ford escape: rear door will not open [Re: mikeinaustin]
Drew2000 Offline
Loc: Long Island, NY
Check out this thread...
http://www.escape-central.com/1forum/showthread.php?s=&threadid=14564
You might be able to get jimmy release by popping out the license plate lamps. No way to get the inside cover off with the hatch closed. Probably have to cut a hole in the cover to access the lock unfortunately.
11 Mustang GT
06 Tribute
05 Honda ST1300
03 Yamaha FZ1
93 Regal
91 Explorer
87 F250 6.9l Diesel
85 Yamaha FJ1100
83 Honda Nighthawk 650
#1624650 - 10/08/09 11:58 AM Re: 2002 ford escape: rear door will not open [Re: Drew2000]
Loc: austin, texas
oh, not the rear hatch, the passenger door is what i meant.
#1624656 - 10/08/09 12:10 PM Re: 2002 ford escape: rear door will not open [Re: mikeinaustin]
kkreit01 Offline
Loc: Olathe, KS
Slim Jim? A locksmith may be able to get in? I don't know...that is a tough one.
2014 Dodge Durango Limited AWD 3.6: 5w20 PP/Napa Gold filter
2014 Ford Edge SEL FWD 3.5: Factory Fill
#1624816 - 10/08/09 03:06 PM Re: 2002 ford escape: rear door will not open [Re: kkreit01]
Eric Smith Offline
Loc: Kansas City, KS
You should be able to remove the panel. First remove the lower seat cushion.. second remove all screws (can't remember how many should be 2-3). The panel will lift up -don't try to pry it out - just pull up and it'll come off easy. I don't have access to our Escape right now will in a couple hours. I put new speakers in ours and amazed how it easy it was.
05 Chevy 3500 (Class C RV) 45k (PP 5w30)
04 Escape 148k (PHM 5w20)
02 Focus 128k (MC 5w20)
#1624900 - 10/08/09 04:15 PM Re: 2002 ford escape: rear door will not open [Re: Eric Smith]
Loc: austin, texas
quick question. so i can't even manually open the door (with the inside and outside door handles), does this probably mean the actuator has frozen in the locked position?
#1624967 - 10/08/09 05:16 PM Re: 2002 ford escape: rear door will not open [Re: mikeinaustin]
Loc: austin, texas
also, i hear that for 2002 ford escapes, the actuator is just a part of a door latch assembly and is not servicable by itself. anyone know if this is true? when i look at online parts catalogs some list an actuator some only list an entire assembly. i do not have the door opened up, so i can't tell (and so i don't actually know the problem just, just trying to plan ahead).
Edited by mikeinaustin (10/08/09 05:18 PM)
#1624979 - 10/08/09 05:24 PM Re: 2002 ford escape: rear door will not open [Re: mikeinaustin]
Eric Smith Offline
I think you need to just pull it apart and see. I've never heard of a problem like yours so it's most likely something simple.
#1625032 - 10/08/09 06:15 PM Re: 2002 ford escape: rear door will not open [Re: Eric Smith]
xlt4me Offline
Loc: Northwest Indiana, USA
Well if it's an integrated unit like they use in a 2000 Cougar...
You're screwed!
Big time!
My daughter's 2000 Cougar has an integrated lock assembly that jammed in the lock position. Even if you did get the door panel off you can't get it unlocked. At least mine wouldn't... even after I removed it from the car. So how did I get it out? I removed the back seat and side panel to get at the bolts for the striker. The bolts were extended about a 1/4" past the reinforcing plate and I was able to back them off a little using vise-grips. Then I used a saws-all to cut the bolts and open the door. Since the lock mech was still locked... and wouldn't budge even though I could now get at it, I had to cut the striker off the lock to get the lock out.
good luck!
