Just look up the SAE number that's stenciled on it.
The spec's for cooler line or otherwise "hot oil" are
SAE J1532 and SAE J1019
SAE J1532
This SAE Standard covers four types of hose for use with automatic transmission fluid: A, B, AT, and BT. Type A and Type B are for use within a temperature range of -40 to 125 degrees C (-40 to 257 degrees F) while types AT and BT are for use within a temperature range of -40 to 150 degrees C (-40 to 302 degrees F). Recommended maximum operating pressure for Type A and Type AT hose is 1.7 MPa (250 psi) while recommended maximum operating pressure for Type B and Type BT hose is 1.0 MPa (150 psi). The lower pressure (Types B and BT) hose is for auxiliary cooler applications only. The reference fluid for tests requiring the use of automatic transmission fluid shall be Dexron-II E/Mercon or equivalent.
Document Number: J1019
Date Published: September 2007
Issuing Committee:
Hydraulic Hose And Hose Fittings Committee
Scope:
This SAE Standard is intended to establish uniform methods for testing and evaluation of hose and hose assemblies for use in high temperature transmission oil systems and high temperature lubricating oil systems using petroleum base oils within a temperature range of -40 to 150 degrees C (-40 to 302 degrees F) and a maximum working pressure of 1.5 MPa (217 psi).
For air brake hose, power steering, fuel filter, engine and transmission coolant lines and hot +149°C (+300°F) lube lines. Recommended for diesel engine flexlines.
• Meets DOT FMVSS 106-74 Type AI and SAE J1019 hot oil circulation test.
• 300 to 1,500 psi working pressure.
For fuel line, I don't think SAE 30R7 would be acceptable. It's got a 50lb (I think) working pressure limit. The temp @ 250f+ is probably okay.
SAE 30R9 is good for 900psi burst pressure and a 257F working temp limit.
