Thin oil, thick oil, synth or dino,
by Cruzingoose
02/13/16 11:25 PM
Compete today? Modernize your skills on own time
by spackard
02/13/16 11:23 PM
Castrol 0w30 leaving Advance Auto Parts
by bbhero
02/13/16 10:53 PM
Oil Change Marathon Today
by BlueOvalFitter
02/13/16 10:01 PM
Raybestos Advance Tech or Police Rotors?
by shiny
02/13/16 09:57 PM
Oil filtration and circulation question
by Doublehaul
02/13/16 09:41 PM
Anyone ever replaced brake fluid on Honda Pilot?
by Islandvic
02/13/16 09:19 PM
Unused WIX 51372-051815C2 cut & post
by WellOiled
02/13/16 08:37 PM
-31 this morning...without the wind chill!
by Doublehaul
02/13/16 08:00 PM
Cleaning Throttle body, necessary service now?
by Colt45ws
02/13/16 07:33 PM
[Cut Open] Ford OE (FL500S equivalent) 4948mi
by DuckRyder
02/13/16 07:20 PM
[Cut Open] Fram XG3600 - 9098mi
by DuckRyder
02/13/16 07:16 PM
Tsr71, SubaFool, dookchoppa, Formula413, Cruzingoose
56910 Registered Users
51 registered (bdcardinal, B320i, bigdawg74, 12 invisible), 940 Guests and 129 Spiders online.
56910 Members
66 Forums
244670 Topics
Page 1 of 34 1 2 3 ... 33 34 >
#1616368 - 09/30/09 05:44 PM Some Filtration Comparisons from the Bench
river_rat Offline
Loc: Iowa
I wanted to share some comparisons of common oil filters' apparent cleaning ability.
The way I do this is to carefully cut the filter elements out of the cans without damaging them. Some elements are open at both ends, and I seal these tight at the end that goes toward the dome of the canister--away from the threaded end. I have a bread loaf pan of 5W-20 motor oil that I have mixed in a copious quantity of talcum powder (about 10 microns average as per The Filter Council); about half a cupful per quart. The mixture is thoroughly stirred, and the filter elements to be compared are immediately lowered in at the same time. When the the center tubes of the elements are full of filtered oil, A syringe is fitted with a 12 inch piec of 1/8 inch inside diameter tubing which is used to stir the inner contents of the filter and then draw a sample. The sample tubes are filled and plugged with pieces of nails at both ends. These sample tubes will be mounted vertically for more than a week to view the amount of filtrate that stacks up on the bottoms for comaprison. However, a lot can be seen just by the initial clarity of the diffeent samples.
I also note which filter elements fill faster/flow better.
A mention about the filters' advertized efficiencies:
The PureOne model that I used--a PL20195 states 99.9% efficient at 20 microns. (20 one-thousandths of a millimeter)
The Mobil 1 Extended Performance M1-209 states 99.2% efficiency, but without giving a particle size for which it can earn this rating. However, by telephone to the maker, Champion Labs, they told me they were "in the ballpark of a 10 micron nominal" filter. This means they catch about half the 10 micron sized particles--and more as the debris gets bigger of course.
The Toyota OEM made by Denso, part number 90915-YZZD1 stated nothing specific.
The Fram PH3593A (orange can) is shown as 95% efficient >20 microns. Presumably, they think you don't know what > means.
The WIX built NAPA Gold 1348 has a nominal rating of 21 microns and a Beta of 2/20=21/37. The beta means 21 micron at 50% and 37 microns at 95% catch, respectively.
The K&N HP-1004 I used, according to K&N via email:
Filter media efficiency (per ISO 16889):
100% at 40 microns
100% at 35 microns
100% at 30 microns
99.4% at 25 microns
98.9% at 20 microns
97.1% at 15 microns
92.3% at 10 microns
82.5% at 5 microns
But I am skeptical of the test conditions as this element was tested twice and never gave as clear of filtrate as it should have by comparison with know filter types.
Here are some pictures:
Left to right: Fram orange, WIX, K&N
These have settled for a few days. I am non-plussed by the NAPA Gold/WIX. But This does correspond to the given betas, efficiencies, in my opinion. It is a well built filter, but has never been an outstanding performer in my cleaning tests. I used Fram for the low standard.
The Wix NG still did a bit better than the K&N.
Left to right: PureOne, Toyota OEM (Denso), Mobil 1 E.P., WIX, K&N
It is hard to tell from the photo, but there is a clear visual difference in the first three, and the second two. The order of cleanliness from best to worst is also left to right. The PureOne, as expected, was outstanding. The Denso and M1 were almost the same but I have to give the nod to the Denso. The Denso also flowed best of all. The WIX and K&N were a bit on the mediocre side of cleanliness but both flowed well.
The PureOne flows twice as fast as the same models made several years ago. There must have been some concern about strat-up valve rattle--but I am speculating on that. The flow charts I have seen for the PureOnes show a nice, pleasing flow curve comparing favorably to other popular filters. The M1 flows about 2/3 again as fast as the PureOne in my test.
Of course, these are all at room temperature with gravity pushing the oil in.
So there you have it. Numbers are numbers, ads are ads, and dirt is dirt when held up to the light.
Take this for whatever it's worth.
Rob
#1616418 - 09/30/09 06:35 PM Re: Some Filtration Comparisons from the Bench [Re: river_rat]
defektes Offline
Loc: Hesperia, CA, USA
Very good presentation, informative and interesting. Thank you for taking the time to do this.
2002 GMC Sierra 5sp. 4.3L 145K ST3980 E-Core
Chevron Supreme 5w-30, Amsoil Synchromesh In Tranny
Valvoline SynPower 75w-90 Gear Oil In Rear
#1616494 - 09/30/09 08:01 PM Re: Some Filtration Comparisons from the Bench [Re: defektes]
TurboLuver Offline
Loc: SW Ohio
Very interesting, thanks for the time and effort!
#1616518 - 09/30/09 08:29 PM Re: Some Filtration Comparisons from the Bench [Re: TurboLuver]
river_rat Offline
Loc: Iowa
You're welcome guys.
Sorry about the dumbing down the terminology, but I posted this first on a non-oil forum and copied and pasted it here.
#1616652 - 09/30/09 10:18 PM Re: Some Filtration Comparisons from the Bench [Re: river_rat]
OVERKILL Offline
Loc: Ontario, Canada
Would you mind testing some more exotic media like the Donaldson Synteq or Fleetguard Stratapore stuff?
02 Expedition
06 Charger R/T
14 Charger SRT-8
#1616654 - 09/30/09 10:20 PM Re: Some Filtration Comparisons from the Bench [Re: OVERKILL]
river_rat Offline
Loc: Iowa
Love to, but It's time and money. I'll get to it when I can though. Cheers2
#1616657 - 09/30/09 10:23 PM Re: Some Filtration Comparisons from the Bench [Re: river_rat]
OVERKILL Offline
Wonderful! I'd be curious as to the results, since they have some very impressive specs (on paper of course).
02 Expedition
06 Charger R/T
14 Charger SRT-8
#1616673 - 09/30/09 10:38 PM Re: Some Filtration Comparisons from the Bench [Re: OVERKILL]
wirelessF Offline
Loc: Oahu, Hawaii
Surprised to see Denso doing well in the test.
#1616703 - 09/30/09 11:15 PM Re: Some Filtration Comparisons from the Bench [Re: wirelessF]
river_rat Offline
Loc: Iowa
I was too the first time I tested one several months ago.
I expected the good performance this time--but still wanted to run it again for direct comparison with some new filter types...It's a really good filter. Especially for less than $6 at the dealer.
#1616710 - 09/30/09 11:21 PM Re: Some Filtration Comparisons from the Bench [Re: wirelessF]
friendly_jacek Offline
Loc: southeast US
Thanks for the tests. This answers my concern with pureone having poor flow in tests done a few years ago but great flow on the flow graph circulated on the web.
#1616829 - 10/01/09 07:08 AM Re: Some Filtration Comparisons from the Bench [Re: friendly_jacek]
river_rat Offline
Loc: Iowa
Yes, I cut open a blue one and a new gold/yellow one (same part numbers) and posted here about the flow difference, etc. The media even looks a little different now than on the old style PureOnes.
#1616886 - 10/01/09 08:50 AM Re: Some Filtration Comparisons from the Bench [Re: river_rat]
Gary Allan Offline
Loc: Pottstown, PA
Excellent home grown turbidity/opacity test.
http://lube-direct.com/gallan/
#1616919 - 10/01/09 09:18 AM Re: Some Filtration Comparisons from the Bench [Re: Gary Allan]
river_rat Offline
Loc: Iowa
I can't even pronounce those words, Gary! But thanks.
I'll post more pics when the grit settles on the last five tubes.
#1617828 - 10/02/09 02:39 AM Re: Some Filtration Comparisons from the Bench [Re: river_rat]
aznboi24 Offline
Loc: Sacramento, CA
Cool, when i run out of wix filters, I wont hesitate to buy OEM filter's for my mom's camry
2014 Toyota Camry LE 2.5L, 0.3k
2001 Acura CL Type S, 138k
1992 Toyota Camry LE 2.2L, 248k
#1617856 - 10/02/09 05:01 AM Re: Some Filtration Comparisons from the Bench [Re: aznboi24]
ZZman Offline
Loc: Michigan
Interesting test.
But what that doesn't take into account is that oil is under pressure and forced thru the filter. This would force many particles into the media material and as the particles built up by constant circulation the efficiency would increase.
These filters also to not claim to be good at filtration that fine. Most use the 20-25 micron level to show good filtration.
But thanks for taking the time and coming up with the test.
2002 Buick Regal GS (3.8 Supercharged) PP, Pure 1 filter
2008 Sebring Hardtop convertible (2.7) PP, Pure 1 filter.
