What bike (s) do you have?
by whizbyu
05/21/13 05:56 PM
Mini-14: grease or oil?
by bsmithwins
05/21/13 05:35 PM
2012 Impreza, 2.0i, 6859mi, Amsoil OE
by brschmid
05/21/13 05:33 PM
1999 Vortec 5700 - Tick upon cold start up
by Thugzy
05/21/13 05:13 PM
wicked oil leak '93 camry, had to go to a pro
by mpvue
05/21/13 04:46 PM
2011 Audi S4 Eneos Sustina mix 2300 miles
by dparm
05/21/13 04:00 PM
Road Racing Sidecars
by HackNutz
05/21/13 03:52 PM
Castrol Edge 0w40 VOA
by dparm
05/21/13 03:49 PM
CAM 2 5-30 SYNAVEX
by ARMY_Guy
05/21/13 03:38 PM
Running an engine close to Redline
by Realtech214
05/21/13 03:35 PM
How much does UOA cost you?
by sgvaibhav
05/21/13 01:51 PM
Doors Fans: Ray Manzarek Has Died
by Rhymingmechanic
05/21/13 01:37 PM
newninja, pfj911, TheLocnar, frozenfbks, DNW
45494 Registered Users
121 registered (AEHaas, andyd, 05LGTLtd, aquariuscsm, 77GrandPrix, 13 invisible), 1687 Guests and 244 Spiders online.
45494 Members
64 Forums
193724 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 2 1 2 >
#1612267 - 09/27/09 07:12 AM Front brakes - 2004 Mercedes ML350
wavinwayne Offline
Loc: North Alabama
On Friday, my wife told me her Mercedes was "making a funny noise when she puts on the brakes". Upon close inspection, I determined that the driver's side front outboard brake pad was worn to practically nothing. FWIW, the rears still seem fine. So on Saturday, I replaced the front brake pads. I fully expected the job to be overly complex, but was pleasantly surprised. That was the easiest brake job I've ever done, hands down. Kudos to the Mercedes engineers for not over-complicating things.
The only down side....The Duralast Gold Ceramic pads from AutoZone were $65, for front pads only. That surprised me. At least they have a lifetime warranty, in case I ever need to replace them again.
Silence is golden, but duct tape is silver.
#1612291 - 09/27/09 07:53 AM Re: Front brakes - 2004 Mercedes ML350 [Re: wavinwayne]
duaneb9729 Offline
Loc: minneapolis mn
sounds like a nice experience, $65 isnt too bad for brake pads, our Chevy van break pads are in the $80 range.
#1612381 - 09/27/09 09:14 AM Re: Front brakes - 2004 Mercedes ML350 [Re: duaneb9729]
Corvette Owner Offline
Loc: Waldorf, Maryland
My experience is that disc brakes are simple to replace. A large c-clamp being the only "specialized" tool you need, to press the pistons back in the caliper so the caliper and used pads are easy to remove and the new thicker pads can be easily installed. Some Chevies need large allen wrenches for the caliper bolts.
One trick is to loosen only one of the two caliper bolts and tilt the caliper down to replace the pads. Of course, you must make sure that the un-loosened bolt body is well lubricated and not sticking.
This is FAR EASIER than fooling around with the springs on drum brakes!
A pair of front pads can cost $150 for my Corvette (Corvette Tax).
Edited by Corvette Owner (09/27/09 09:16 AM)
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
10 Starcraft Boat
13 Buick Enclave
#1612465 - 09/27/09 10:48 AM Re: Front brakes - 2004 Mercedes ML350 [Re: Corvette Owner]
Kestas Offline
Loc: The Motor City
Weren't there wear sensors to give advanced warning on the dash that the pads needed replacing?
(Brakes are about the only thing Mercedes engineers don't overcomplicate.)
#1612524 - 09/27/09 12:04 PM Re: Front brakes - 2004 Mercedes ML350 [Re: Kestas]
wavinwayne Offline
Loc: North Alabama
There is one on the driver's side inboard pad. The sensor never triggered a warning light. The inboard pad had not worn at the same rate as the outboard pad, so I'm guessing that's why I never saw a warning light.
#1612554 - 09/27/09 12:54 PM Re: Front brakes - 2004 Mercedes ML350 [Re: wavinwayne]
Kestas Offline
Loc: The Motor City
It seems the calipers aren't working properly and that you did a 'pad slap'. Either the calipers need replacing, rebuilding, or something needs to be cleaned and lubricated.
#1614573 - 09/29/09 11:05 AM Re: Front brakes - 2004 Mercedes ML350 [Re: wavinwayne]
Vikas Offline
Loc: NorthEast
Hope you lubed the guide as that seems to be sticking. It would cause one pad to wear faster than the other.
- Vikas
#1614578 - 09/29/09 11:08 AM Re: Front brakes - 2004 Mercedes ML350 [Re: Vikas]
wavinwayne Offline
Loc: North Alabama
- Vikas
I didn't lube anything. All I did was remove the old pads, press the piston back into the caliper, and install new pads. If I have to replace the pads again in another 80k miles (which is how long the OEM's have been on), then so be it. It's a good excuse to spend a few hours in the man-cave.
#1614602 - 09/29/09 11:28 AM Re: Front brakes - 2004 Mercedes ML350 [Re: wavinwayne]
tom slick Offline
Loc: Central Coast, Calif.
Are they 2 or 4 piston calipers?
You get what you pay for...
So keep in mind how much you paid for this advice.
#1614624 - 09/29/09 11:41 AM Re: Front brakes - 2004 Mercedes ML350 [Re: Kestas]
labman Offline
Loc: Nothern USA
+1
#1614640 - 09/29/09 11:49 AM Re: Front brakes - 2004 Mercedes ML350 [Re: tom slick]
wavinwayne Offline
Loc: North Alabama
Each caliper has 1 piston.
#1614722 - 09/29/09 01:11 PM Re: Front brakes - 2004 Mercedes ML350 [Re: wavinwayne]
nthach Offline
Loc: California
I wouldn't use DuraLast or any mass-market pad on a Benz - I'd stick to Textar, Jurid, Pagid, ATE or PBR. Mercedes also calls for a pad paste to be used, which is identical to Molykote M77 which can be had at a Honda dealer or industrial supply house.
#1614729 - 09/29/09 01:17 PM Re: Front brakes - 2004 Mercedes ML350 [Re: nthach]
wavinwayne Offline
Loc: North Alabama
I've never heard of any of those, so I'll take your word that they're good. Personally, I've had nothing but excellent results from Duralast pads on several vehicles, and will continue using them on all my vehicles without the slightest concern.
#1614797 - 09/29/09 02:12 PM Re: Front brakes - 2004 Mercedes ML350 [Re: labman]
mechtech2 Offline
Loc: Chicago Area
'Pad slap' brake replacement is great for road racing.
It is not smart for long term car maintenance.
#1614809 - 09/29/09 02:25 PM Re: Front brakes - 2004 Mercedes ML350 [Re: nthach]
Trav Offline
Loc: MA, Mittelfranken.de
Those listed are all excellent,ATE and Pagid i believe are both OEM suppliers for MB.I would add Bendix and Raybestos (higher grades) to that list as well as maybe a few others.
Duralast and other house brands would definitely not be on my list of choices.
ASE L1, Master. Deutsch Meisterbrief
Page 1 of 2 1 2 >
