33022 Members
60 Forums
137289 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1613902 - 09/28/09 07:17 PM
VOA's: Mobil 1 Syn ATF, Redline D4 ATF, GM MTF
Loc: California, Santa Clara
#1613967 - 09/28/09 08:11 PM
Re: VOA's: Mobil 1 Syn ATF, Redline D4 ATF, GM MTF
[Re: 4wheels]
Loc: Illinois
It looks to me the M1 is equal to Red line and both are better than the GM.
2007 Ford Fusion 59,000 miles M1 5-20EP 2007 Ford Focus 71,000 miles M1 5-20EP 10,000 mile OCI M1 ATF
#1613968 - 09/28/09 08:11 PM
[Re: 4wheels]
Loc: Ka .li . for, nia
Thankyou!!!!
There is no substitute for a REAL manual transmission...cheaper to buy, more durable, and cheaper to maintain and fix after the warranty runs out.
#1614034 - 09/28/09 09:20 PM
[Re: tig1]
Loc: Minnesota
It looks to me the M1 is equal to Red line and both are better than the GM. I am assuming that more additive = better...but how do we know that this is actually the case? How would these additives affect clutch friction or gear/pump/converter wear? I have always wondered how these universal fluids perform in the different applications. Is it just that GM's fluid has been cost reduced and the additional additive is actually beneficial? FYI - I am trying to determine if I want to go with OEM fluid next or switch to one of these universal fluids.
Vehicles: 1997 Honda del Sol 2004 Ford F150
Toys: 1980 Yamaha 440 Exciter 1981 Polaris Cutlass 440 1982 Yamaha XJ1100 2008 Victory Vision Tour
#1614040 - 09/28/09 09:25 PM
[Re: XJ1100]
Loc: Illinois
M1 has been universal for years as in dextron and mercon. Now it covers others but I have used their ATF since they invented M1 and have yet to have my first tranny or PS pump failure.
#1614044 - 09/28/09 09:28 PM
[Re: tig1]
Loc: Duvall WA - Pacific NW USA
It looks to me the M1 is equal to Red line and both are better than the GM. How the heck did you come to THAT conclusion??? $20 VOA's can not possibly tell you if an ATF is "better" than an MTF. Now I will agree, for something to be called "MTF", the GM stuff looks by just pure elemental additives under additized. But if you have read more than 2 or 3 posts here, a cheapie VOA doesn't really tell you what a lubricant is.
#1614214 - 09/29/09 12:48 AM
[Re: Pablo]
Loc: Las Vegas NV
I really wish they would test for sulfur in these tests.
#1614231 - 09/29/09 01:39 AM
[Re: Tempest]
I will say that all 3 of these produce slightly different shift "feel" with the manual transmissions I've tried them in. In my current test vehicle, the Redline actually shifts better over a wider temperature range than the other 2. The GM shifts best when cold to warm, and the Mobil 1 is just "ok" but not great at any temp.
Another post of mine with the BMW MTF-LT-2 shows it looking similar to the Mobil 1 ATF with a couple minor differences, but yet it produces another slightly different shift feel. Next on my list will be some regular dino Dex/Merc ATF's and some fancy BMW MTF-LT-3. Possibly the RLI as well, depending on when I get tired of testing or settle on a fluid.
Keep in mind that the "GM Manual Trans & Transaxle Lube" tested above is only suggested for use in vehicles where ATF is the suggested lube. From everything I've seen this stuff appears to be a repackaged Dexron 3 ATF, since GM is now pushing only Dex 6 for automatics.
#1615243 - 09/29/09 08:26 PM
[Re: Pablo]
Loc: Illinois
It looks to me the M1 is equal to Red line and both are better than the GM. How the heck did you come to THAT conclusion??? $20 VOA's can not possibly tell you if an ATF is "better" than an MTF. Now I will agree, for something to be called "MTF", the GM stuff looks by just pure elemental additives under additized. But if you have read more than 2 or 3 posts here, a cheapie VOA doesn't really tell you what a lubricant is. I was wondering if anyone would bite on that. Just the numbers are simular with M1 and Red line. It's possible RL may be as good as M1 in the real world, never used RL, Used M1 ever since they invented the stuff and it's good.
#1615476 - 09/29/09 11:14 PM
[Re: tig1]
Loc: RI
The GM fluid is their replacement for mineral Dexron-III gearboxes that can't use Dexron VI. But, the boron is higher(almost double) than most cheapie mineral D3's were. So, GM 'might' have created a slightly better gearbox oriented Dexron-III replacement. But, it still looks 'weak'.
Mobil1 and Redline D4 have always been excellent ATFs and its shows with a stout additive package.
My sarcastically useless opinion is always available. Just point me in the direction of your thread!
#1615955 - 09/30/09 11:19 AM
[Re: tig1]
Loc: MS
It's possible RL may be as good as M1 in the real world Better
1999 Mustang GT 4.6 4V - RL 5W-20, RL D4 ATF, RL 75W-90, FL-1A 2001 F150 SuperCrew 4.6 2V - RL 5W-20, RL D4 ATF, RL 75W-140, FL-820S
#1616699 - 09/30/09 11:10 PM
[Re: unDummy]
Loc: southeast US
I would say the additive pack is similar if not the same. The VI and thus base oils are different though (obviously not shown in the results).
#1617321 - 10/01/09 04:16 PM
[Re: Ben99GT]
It's possible RL may be as good as M1 in the real world Better How so and how can it be proved? I am wondering.
#1617718 - 10/01/09 11:33 PM
[Re: Steve S]
Loc: RI
It can be proved with testing. But, that would cost plenty. Until then, they are both excellent ATFs.
#1628282 - 10/11/09 08:09 PM
[Re: unDummy]
Loc: Midwest
Thanks for the VOA's. It can be proved with testing. But, that would cost plenty. Until then, they are both excellent ATFs. Very true. I am assuming that more additive = better...but how do we know that this is actually the case? How would these additives affect clutch friction or gear/pump/converter wear?
No, this is a common misconception. What this shows is that with their combination of base oils, these additives and additive dosages perform best in their testing and analysis results. You will never see the friction modification chemistry detected in these low cost analyses.
Edited by MolaKule (10/11/09 08:15 PM)
Nothing astonishes men so much as common sense and plain dealing. R.W. Emerson
