Originally Posted By: tonycarguy
Minimal shearing, high TBN after 10k miles, etc?
I don't know the specifics but I'm pretty sure you're on the right track. The one thing I'm sure of is that the oil has to have a minimum high temperature/high shear (HTHS) viscosity of 3.5. I'd assume there are also specifications for wear prevention and deposit control.
I heard somewhere that BMW's LL-xx tests are basically the same as ACEA tests (e.g. A3), just done on BMW engines instead of whatever standard rigs the ACEA uses. Not sure if that's true.
