Sears Battery Pricing
by PeterGreen
20 minutes 3 seconds ago
My 12am emergency strut spring repair on a Civic
by Colt45ws
29 minutes 37 seconds ago
My upper sidewall pinehole leak fix
by Pokermatters
56 minutes 56 seconds ago
QS filters 'closer' to OEM quality?
by addyguy
Today at 07:44 PM
Need tire experts regarding tire wear pattern.
by ST2008
Today at 07:18 PM
Best not drying grease
by ST2008
Today at 06:56 PM
Honda GCC160 crank question
by FastLane
Today at 06:55 PM
by Pokermatters
Today at 06:52 PM
Sunl Scooter Troubleshooting
by yeehaw1960
Today at 06:47 PM
Ozonated Distilled Water in the Cooling System
by ZeeOSix
Today at 06:42 PM
2001 Honda Accord 4 cyl
by gmh101357
Today at 06:25 PM
No Oil Additives with MDS System - Ram 2500 6.4L
by Dexters
Today at 05:39 PM
lowsapsdieseloil, kit2523, rfabrocini, Tobin28, r0k
58600 Registered Users
116 registered (Anduril, 41 Plymouth, acbent, 4WD, ag_ghost, 14 invisible), 1890 Guests and 21 Spiders online.
58600 Members
66 Forums
252287 Topics
Page 1 of 2 1 2 >
#1605868 - 09/20/09 03:39 PM Broke EZ Out in Exhaust Manifold Stud
1993_VG30E_GXE Offline
Loc: Ontario, Canada
I broke the EZ Out flush with the pre-broken exhaust manifold stud, trying to remove it Left Twist.
How much should I bid to the Machinist to remove this thing? I tried to drill out the portion of the EZ Out but it broke my LH Jobber Drill Bit. Moved up a size, and it just won't drill into the EZ Out material.
#1605874 - 09/20/09 03:48 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: 1993_VG30E_GXE]
andyd Offline
Loc: Marshfield , MA
Are we having fun on this engine job yet? You have my full sympathy. I put another engine into my Grand Wagoneer back in '03. The best way I have heard for DIYer to deal with a sheared EZ out is to go after it. with a burring tool in a Dremel grinder. Just grind it up. I have never done this, I have just Heard this. Twice. Machinists get big bucks to arc them out.
BTW, EZ outs are just a cruel trick to play on a hack like me. I just use drills on sheared stuff. I learned like you just did.
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#1605875 - 09/20/09 03:49 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: 1993_VG30E_GXE]
soldierman Offline
Loc: mcminnville tn
Sometimes if your lucky you can take a GOOD center punch and a sharp blow to the ezout and if its made of cheaper hard metal that is brittle it might shatter. You can then take some dental picks and fish out the remainder of it. If however its a good quality ezout then it may have to be burned out with something like an EDM machine. I've only had that done once. and it was in a cylinder head but it was on a motorcycle and not installed on the bike at the time. Cost was about $50 and that was about 20 years ago.
I have at times laid a nut on a broken stud or bolt and mig welded the nut to the bolt. Then sprayed the said bolt with PB blaster. Wait for the weld to cool and then heat the part the bolt is in trying to keep the bolt as cool as possible and then slowly work the bolt out. If you can ever get it to turn one full round your likely home free.
1991 mitsubshi galant 2.0 SOHC auto 250,000
2002 mitsubshi galant 2.4 SOHC auto 90,000
1986 F150 4x4 302 4speed 130,000 (for sale)
#1605878 - 09/20/09 03:53 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: soldierman]
Chris142 Online   content
Loc: apple valley, ca
Burn it out with a torch. The bolt thats broken off will melt before the cast iron manifold will. Once the bolt is gone the EZout will fall out. Then you can run a tap through the threads to remove any pieces that might still be stuck in the threads.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#1605889 - 09/20/09 04:00 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: soldierman]
pickled Offline
Loc: The Rocky Mountains
Follow the centerpunch hammer recommendation first. If that doesn't work take it to your machinist and they will be able to get it out. I'm really sorry about your misfortune! We had to deal with one of these issues when the mechanic next door broke a high quality tap off in a Durango's thermostat well ( have no idea how he did it because the manifold was aluminum). We set it up in the mill and used a 3/8" carbide end mill to plunge through it. Took about 10 minutes with flood coolant on and slow Z feed. We were able to save the piece for him thankfully.
Used gear lube and burnt ATF is all the cologne a real man will ever need!
Too many toys and automotive parts to list...
#1605892 - 09/20/09 04:02 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: pickled]
pickled Offline
Also if you could braze something to it you might be able to coax it out with heating, careful penetrating oil application and reverse torque...good luck bud!
#1605907 - 09/20/09 04:19 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: pickled]
OK Thanks guys. The EZ Out is the original type by CLEVELAND, bought at Grainger so I think it's the good material. The cylinder heads are Aluminum. I managed to get out 5 of the other studs with the broken EZ out piece that seemed to work better when the pointed part sheared off.
I'll try some of your methods but when I was trying to drill it 30 mintues ago, the drill slipped and started drilling into the side of the threads in the M8 hole.
I have the carbide Burr double cut rounded top one but it seems risky - M8 is a pretty small hole, i'll try it but I don't think I'll make progress. I could buy another smaller carbide burr for my die grinder, but it could be a waste of money as I could put it towards paying the machinist.
I don't think I want to hook up my MIG and try it. ie. weld a small cap screw to the end of it. It's a really tight spot.
I'll try your center punch method now - I picked up last week a couple of Proto center punches - really high quality stuff. The tip doesn't seem to go dull like the cheap Harbor Freight ones.
Edited by 1993_VG30E_GXE (09/20/09 04:20 PM)
#1605925 - 09/20/09 04:31 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: 1993_VG30E_GXE]
pickled Offline
Don't forget that your time is valuable too. An aluminum head is usually something that I would be looking to take into the machinist pretty quick if 2 or 3 methods failed. The screw ups that you might make will cost you more money at the machine shop. When you take it to him/her on a bid basis before you screw it up too bad- they own the screw ups and remedial actions/costs from that point forward.
#1605932 - 09/20/09 04:38 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: 1993_VG30E_GXE]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Been there done that ONCE for myself and then after a successful rework on my Volvo turbo, I did it for TWO other guys.
Best way? Easiest way?
Dremel tool and diamond bits. Just go to Harbor Freight and buy a couple low cost diamond bit kit sets for your Dremel. Just hunker down and go after the Easy-Out (ball tips work best), use some light oil in the hole to make a diamond dust slurry and change bits as the diamond leaves the tips. Takes a little control but you get the stud and the broke Easy out ground to nothing without messing the hole up. Clean and retap. Good to go.
#1605935 - 09/20/09 04:42 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: 1993_VG30E_GXE]
tom slick Offline
Loc: Central Coast, Calif.
Weld a large nut to it with the weld on the inside of the nut. The aluminum won't stick or melt while you are welding (dissimilar metals) make sure to get good penetration into the ez-out.
You get what you pay for...
So keep in mind how much you paid for this advice.
#1606086 - 09/20/09 07:50 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: tom slick]
alreadygone Offline
Loc: North Arkansas
Any of the above methods can work in the hands of an experienced fubar-fixer. Question is,, Are You Experienced?
To which version of reality would you like to convert me?
Bob
#1606088 - 09/20/09 07:51 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: tom slick]
Oh this is broken off in the alum head? Dont try to burn it out like I said to. I thought it was broken off in the manifold
87 F250 delo 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#1606127 - 09/20/09 08:27 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: 1993_VG30E_GXE]
wvrailroader Offline
Loc: West Virginia
I believe there is a drill bit that will drill the EZ-out. I had a shop break an easy out off in the aluminum head of a Ford V-10 when they were putting the headers on it. I took it to another shop and after some work with this bit they got it drilled out. To make matters worse, the first shop had drilled the broken stud crooked and into the threads in the head in which the EZ-out went into and then broke. I will check with the shop tomorrow and see what type of bit it was (I believe it came from Snap-On).
#1606220 - 09/20/09 09:34 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: wvrailroader]
onion Offline
Loc: kansastan
This is a quick & DIRTY method- not for the faint of heart:
Try a masonry bit. I've never tried one on an easy-out, but I've drilled through some impossible situations with masonry bits (including hard-facing and a broken tap). Go SLOW, use lots of oil. It'll chatter and smoke, and the hole will be rough as [censored]- but I think there's a pretty good chance that it will drill through. The hole can be cleaned up thereafter and repaired with a helicoil if necessary.
I also agree with others on this thread that a dremel with diamond bits could also do the job. These are also handy if you're drilling out a broken steel bolt in aluminum heads, and the drill starts to get off-center- you can get out the dremel and re-center the cutting area. Takes a little patience, but works fine. A carbide burr on a die grinder can serve the same purpose- but a dremel would be better suited for a hole of this size.
The invisible and the imaginary look exactly the same.
#1606314 - 09/20/09 11:53 PM Re: Broke EZ Out in Exhaust Manifold Stud [Re: onion]
Bad news guys, the carbide burr slipped while using the die grinder, and because it's such a high quality double cut one, it instantly started taking metal off on the side of the hole right into the threads.
Photo to come tommorow. I think I want to leave this for the machine shop at this point so I don't render the head useless, unless you guys have another approach. I'll read the recent replies more closely.
To save the little money doing this myself, it's probably not very cost effective at this point. In the shop, don't they stabilize the head in some huge vice and use a super precise drill to go STRAIGHT DOWN into the thing?
Page 1 of 2 1 2 >
