Mercon LV or MaxLife
by buck91
Yesterday at 11:46 PM
VW Electric Plans
by Y_K
Yesterday at 10:49 PM
Oil Recommendation for Nissan 3.5 V6 113,000 miles
by BlueSmoke16
Yesterday at 10:10 PM
Sticky Ear Question - Speak Up!
by Ducked
Yesterday at 10:07 PM
House hunting follies
by Jarlaxle
Yesterday at 09:36 PM
Goodbye, Stubby
by Inspecktor
Yesterday at 09:35 PM
Undercarriage
by jay929
Yesterday at 09:31 PM
$1200 Cabela's Gift Card For Sale- Louisville, KY
by FirstNissan
Yesterday at 08:37 PM
Motor oil recommendations, '04 Toyota Sequoia
by ShadowSix
Yesterday at 08:21 PM
Quick Question About Car Battery Quality And Price
by crazyoildude
Yesterday at 07:44 PM
Shelf Life of Gas Stabilizer.
by George7941
Yesterday at 07:34 PM
Got some Leather Seats for the Focus
by Miller88
Yesterday at 06:53 PM
gioburk, turrican, GGilbert, leje0306, DLL
58951 Registered Users
45 registered (1JZ_E46, Bandito440, asiancivicmaniac, bdcardinal, barkingspider, bowlofturtle, 5 invisible), 962 Guests and 9 Spiders online.
58951 Members
66 Forums
253706 Topics
#1602418 - 09/16/09 07:37 PM TRC 15w40, 150 hrs in N14 Cummins
Rob_Roy Offline
Loc: Northern, NY
Texas Refinery Corp. Pro-Spec III 15w40 CI4+. The N14 puts out roughly 500hp and is installed in a John Deere self propelled chopper. This unit runs wide open most of the time at maximum load. Sump capacity is 42 quarts, 3 quarts of make up oil added. Analysis by Wearcheck, values of zero were omitted.
Time on unit: 4223 hrs
Time on oil & filter: 150 hrs
Oil not changed, sample pulled with vacuum pump.
Silicon: 2.6
Potassium: 2.8
Sodium: 5.2
Fuel%: <2
Glycol: Negative
Water%: <0.1
Soot%: 0.9
Sulfation: 61
Nitration: 67
Boron: 5.8
Barium: 0.5
Calcium: 4076
Magnesium: 14
Molybdenum: 5.2
Phosphorus: 1130
Sulfur: 5490
Zinc: 1281
Iron: 13
Copper: 0.4
Aluminum: 1.7
Lead: 6
Viscosity @ 100C: 15.49
TBN: 15.1
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10 workhorse
#1602439 - 09/16/09 07:58 PM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: Rob_Roy]
daman Offline
Loc: Bad Axe, MI
where did you get that oil from?
"Always"....Mobil 1
Current fill: AFE 0w30
#1602494 - 09/16/09 08:48 PM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: daman]
soldierman Offline
Loc: mcminnville tn
That would be roughly like 8000 miles on a semi truck. And your oil is still showing TBN of 15! :-) I can't for the life of me convince my FIL that new computer controlled diesels aren't the same old engines he grew up with. They are built tighter, atomize better and burn much cleaner than what he drove just 10 years ago. He is stuck on doing 10K oil changes. When he could stick $100-150 in the bank easy every other change. I'm sure his truck most likely could easily go 20K.
1991 mitsubshi galant 2.0 SOHC auto 250,000
2002 mitsubshi galant 2.4 SOHC auto 90,000
1986 F150 4x4 302 4speed 130,000 (for sale)
#1602541 - 09/16/09 09:28 PM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: soldierman]
rshunter Offline
Loc: Ohio,USA
Holy [email protected]! Oil changes every 10K? I'm running my trucks on 40K intervals...
'99 Eurovan GLS,'06 Raider DuroCross V8 Ext,'08 GTI DSG,'14 PriusPLUS
#1602660 - 09/16/09 11:53 PM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: rshunter]
pickled Offline
Loc: The Rocky Mountains
Nice wearing N14 (uggh I sounded like Blackstone for a minute please forgive me)! Looks like your limiting factor will be soot. Heck if you were to put a bypass or centrifuge on that puppy you could tack weld the drain plug before you fill it up at your next oil change and forget about it! Wear appears to be well controlled. I take it that you aren't running ULSD and this beauty has NO EGR to bother with.
Used gear lube and burnt ATF is all the cologne a real man will ever need!
Too many toys and automotive parts to list...
#1603290 - 09/17/09 06:56 PM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: pickled]
Rob_Roy Offline
Loc: Northern, NY
The fuel is an unknown, off road diesel in our area can be either LSD or ULSD. No EGR to worry about.
Keeping the air cleaner free of pollen/seeds & dirt is a constant battle, I suspect that may have something to do with the soot.
#1603327 - 09/17/09 07:23 PM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: Rob_Roy]
m37charlie Offline
Loc: Alaska
It's worthwhile going to the site of that oil co. All their oils are very strongly formulated. The Pro-spec III has a SA of 1.72%, TBN>15, Ca 4500, Zn 1300 or 1400. If it were a 5W-40 it would be a "super-oil"; which it already is for temperate and warm conditions. The CJ4 version has a very high TBN of 14!!
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#1603394 - 09/17/09 08:07 PM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: m37charlie]
sdan27 Offline
Loc: Michigan
How many hours do you generally you put on your unit in a year? We have a Claas unit on our farm and the last two years put on about 370 hours each. I'm guessing we'll go over that this year though as we're looking to chop a lot more corn. What type of oil filters do you use? The Fleetguard combo filters work real well in some of our applications in keeping soot down. With an N14 you'd probably want to look for an LF9009.
'94 F250 Powerstroke. LF9691 primary oil. AH1141 air filter. FS1282, FF5320 fuel filter. WF2071 coolant filter.
#1603395 - 09/17/09 08:09 PM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: sdan27]
oliver88 Offline
Loc: ohio
Where can you buy TRC oil??
#1864188 - 04/20/10 01:19 AM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: oliver88]
Texan4Life Offline
Loc: Texas
+1
I have been finding these UOA's to be steller and almost unbelievable.
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
#1864623 - 04/20/10 12:28 PM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: rshunter]
1969 Offline
Loc: Ft Worth, Tx Tarrant County
The TRC stands for Texas Refinery Corporation and they are located in Ft.Worth, Tx. It is a privately held company with apparently world class products. You can order their products over the phone.
#1866018 - 04/21/10 01:58 PM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: 1969]
Johnny Offline
Loc: Retired | Wausau, WI
Phone: (800) 827-0711
#3478345 - 09/09/14 01:09 PM Re: TRC 15w40, 150 hrs in N14 Cummins [Re: Rob_Roy]
zpinch Offline
Loc: Sk, Canada
Dug out an old thread, but has anyone else here tried some of TRC's engine oils in their cars, trucks, etc?
2003 Honda CRV w/217,000km
AMSOIL remote bypass filter (EAO15 & BP90) & EAA
Signature Series AZO 0w30 - 41,000km+ on bypass unit/oil
