Your FINAL though on Quaker State oil line
by MetalSlug
07/27/16 07:45 AM
Amsoil SS 5w30, 10K, 04 Chevy Tahoe, 206K
by dhellman12
07/27/16 07:30 AM
2004 Chevy 2500HD, 60k Amsoil ATF, 194K
by dhellman12
07/27/16 07:17 AM
The History of Snake Oil
by Char Baby
07/27/16 07:16 AM
Industrial hand cleaners?
by KenO
07/26/16 11:58 PM
Shell Rotella T6 in a Altima 2.5
by Grambo
07/26/16 11:24 PM
"Creaking" Conti DWS's?
by Lolvoguy
07/26/16 10:52 PM
Check your car after it's been worked on
by Nick1994
07/26/16 10:15 PM
How are lg android devices now days?
by ram_man
07/26/16 09:42 PM
Dexos 5w30 with highest 100c Viscosity
by CapitalTruck
07/26/16 09:32 PM
How do you avoid being perceived as a rookie when
by motor_oil_madman
07/26/16 09:27 PM
Oil opinions after dumping FF
by JoelB
07/26/16 09:27 PM
snydercn, surfbum, Tmemz4, woollum86, Phil108
58612 Registered Users
63 registered (Asterix, Bandito440, Bamaro, Anduril, badtlc, bbhero, 3 invisible), 1599 Guests and 16 Spiders online.
58612 Members
66 Forums
252300 Topics
Page 1 of 2 1 2 >
#1600403 - 09/14/09 09:18 PM STP vs ZDD Plus
Johnny248 Offline
Loc: Detroit, MI
Hey guys,
Is it worth it to spend the extra money for the ZDD Plus zinc additive, or is the $3 bottle of STP fine? I've seen the voa of the STP and the Zinc content, I'm just wondering if there is something that would make one better than the other?
Thanks
'11 Ram 1500 5.7L
'08 Beetle 2.5L
'06 Eclipse GT 3.8L
'95 Four Winns Sundowner 5.0FI
'94 Honda Dio 72cc Big Bore
#1600449 - 09/14/09 09:46 PM Re: STP vs ZDD Plus [Re: Johnny248]
TallPaul Offline
Loc: By Detroit
I don't know, but the Redline breakin additive has tons of zddp, something like you would only need 2 oz for a whole crankcase IIRC. There are threads on it.
The masses, thirsting for convenience, unwittingly dig the grave of the automobile as we knew it. The industry already has one foot in that grave.
#1600625 - 09/15/09 02:34 AM Re: STP vs ZDD Plus [Re: TallPaul]
ionbeam22 Offline
Loc: Boston, MA
Lucas makes a break-in additive as well.
http://www.lucasoil.com/products/display...B%20Zinc%20Plus
#1600763 - 09/15/09 08:43 AM Re: STP vs ZDD Plus [Re: ionbeam22]
Johnny248 Offline
Loc: Detroit, MI
16oz to 4.5qts will bring zinc to 5000ppm. That is a lot.
'11 Ram 1500 5.7L
'08 Beetle 2.5L
'06 Eclipse GT 3.8L
#1600807 - 09/15/09 09:36 AM Re: STP vs ZDD Plus [Re: Johnny248]
ADFD1 Offline
Loc: CA.
Any down side to too much ZDDP? Say 1 ounce/qt of the Red Line add?
AD
AD
US Navy. Helping keep our Country Safe!
#1600838 - 09/15/09 10:13 AM Re: STP vs ZDD Plus [Re: ADFD1]
m37charlie Offline
Loc: Alaska
AD
Yes! Over 2000 ppm (I'm not sure whether Zn or P, use Zn to be safe since it's ~10% higher) can attack camshaft lobes and cause catastrophic chunking. Be very careful with these additives. For example, ZDDPlus has 71800ppm Zn, 51500 ppm P. 30ml in 5qts will raise Zn ~450ppm, P300ppm. In a somewhat typical fairly weak 600ppm SM oil, that will raise Zn/P to "safe" levels of ~1100/900. Certainly add no more than 1/2 bottle (60ml) to get levels up to ~1600/1200. Remember, many Mobil 1s as an example are 900/800 at a minimum, HDEOs range from 900/800 (some CJ4s) to 1400/1300 (some CI4s).
STP was analyzed on the 1st page of the sticky of VOAs. It's <2000ppm undiluted and comes in a vehicle of very thick (~105 CsT @ 100 C.) oil. If you want to raise Zn/P carefully, use one of the more potent single-ingredient ones like ZDDPlus or Redline, know exactly what its' concentration is AND your oil's concentration, and do your sums carefully, recheck at least once. Too much of a good thing is very bad!
Maybe download (for $15) and read SAE technical article 2004-01-2986 "How much ZDP is enough", first.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#1600907 - 09/15/09 11:29 AM Re: STP vs ZDD Plus [Re: m37charlie]
Johnny248 Offline
Loc: Detroit, MI
So how would adding the STP to say 6 qts of oil that is SL Rated affect the level?
'11 Ram 1500 5.7L
'08 Beetle 2.5L
'06 Eclipse GT 3.8L
#1601009 - 09/15/09 01:00 PM Re: STP vs ZDD Plus [Re: m37charlie]
ADFD1 Offline
Loc: CA.
AD
Charlie
How about adding 5 oz of the Red line break in add to a 5 qt sump effect a high quality SM oil? Would it put ZDDP to a dangerous level?
AD
AD
#1601077 - 09/15/09 01:57 PM Re: STP vs ZDD Plus [Re: ADFD1]
m37charlie Offline
Loc: Alaska
I don't know. What is the Zn and P content, and what else is in it?
And the article says that one probably doesn't need >600-800ppm P for anything except high performance flat tappet engines with high valve spring pressures. OTOH, why do HDEOs have 800-1300 ppm P?
Charlie
#1601102 - 09/15/09 02:20 PM Re: STP vs ZDD Plus [Re: Johnny248]
m37charlie Offline
Loc: Alaska
Take the difference between STP (2000 ppm Zn) and your oil's Zn (let's say 700) and divide by dilution factor. If STP bottle is 1 pint (?), and you already have 6qts, dilution factor is 6.5/0.5 = 13. (2000-700)/13 = 100 ppm increase. Not much, plus you just increased your viscosity an unknown amount.
Charlie
#1601213 - 09/15/09 03:56 PM Re: STP vs ZDD Plus [Re: Johnny248]
TallPaul Offline
Loc: By Detroit
Use only 2 to 4 ounces per crankcase fill. 5000 ppm is wayyyyyyy toooooo much! You make out on this one because one bottle will last 4-8 oil changes. Calculate it so that you boost only to about 1200 ppm, no need to go higher.
#1601216 - 09/15/09 04:01 PM Re: STP vs ZDD Plus [Re: TallPaul]
ADFD1 Offline
Loc: CA.
How about 4 ounces to 5 qts of the RL additive? Will that hurt an engine if added to one of the better oils?
AD
AD
#1601280 - 09/15/09 05:22 PM Re: STP vs ZDD Plus [Re: ADFD1]
[RT] ProjUltraZ Offline
Loc: Honolulu, HI
check out the Redline break-in additive table on this page
#1601319 - 09/15/09 06:04 PM Re: STP vs ZDD Plus [Re: [RT] ProjUltraZ]
demarpaint Offline
Loc: NY
Originally Posted By: [RT
ProjUltraZ]check out the Redline break-in additive table on this page
Good stuff, 1 oz/qt of oil should boost the ZDDP nicely, and not cause any problems. Give Redline a call their tech people are very good.
God Bless Our Troops
#1601357 - 09/15/09 07:08 PM Re: STP vs ZDD Plus [Re: demarpaint]
m37charlie Offline
Loc: Alaska
Looks to me like ZDDPlus and Redline are the only products I'd add myself, in carefully calculated quantities so as not to exceed 1600 ppm Zn, 13-1400ppm P. I'm curious about the "other ingredients" in the RL.
Charlie
Page 1 of 2 1 2 >
