USB flash drive security
by bowlofturtle
07/02/16 04:32 AM
Radiator fan motor on the way out?
by Falcon_LS
07/02/16 04:05 AM
Ultimate "el cheapo" oil change, LOL
by gfh77665
07/02/16 02:54 AM
Chrome polish for spoke wheels
by gman2304
07/02/16 01:52 AM
'09 Nissan Sentra-Eni i-Sint XL 4AM 5w-30-10k.
by montero1
07/02/16 01:11 AM
Questions about manual transmission sounds
by Why_Anything
07/01/16 11:09 PM
HOW to learn PINSTRIPING & lettering ??
by SumpChump
07/01/16 11:08 PM
'96 Nissan Maxima - Intake R&R - EGR tube bent
by 92saturnsl2
07/01/16 11:00 PM
Anybody want a lot of 6 Carquest Blue 84060?
by CapitalTruck
07/01/16 10:38 PM
new Tundra color
by lawnman
07/01/16 10:36 PM
Bought A Yamaha XSR900 today!
by donnyj08
07/01/16 10:21 PM
Akebono ProACT vs EBC Ultimax "Blackstuff" pads
by slacktide_bitog
07/01/16 10:08 PM
Aidil, dandandan, dbertheau, Jennyp, dcdodge
58341 Registered Users
27 registered (bowlofturtle, bdcardinal, bernau, bigdreama, Black_Thunder, 01_celica_gt, 3 invisible), 815 Guests and 11 Spiders online.
58341 Members
66 Forums
251133 Topics
#1588350 - 09/03/09 08:01 PM Anyone know the viscosity of Bardahl no-smoke?
55Test Offline
Loc: New Brunswick
I picked up an old 92 Plymouth Voyager with the Mitsu 3 liter V6 a week ago for 250 bucks. It runs quite good but it's a little smokey. I bought a bottle of Bardahl no-smoke and put it in the engine and the smoking has been reduced noticeably. I was just curious as to the viscosity of the stuff. Oh, also, does this stuff have any anti-friction/anti-wear or any other additives, or is it just a thickener?
The total sum of everything I have learned from this website: ...Oil in engine, good!
#1593262 - 09/08/09 05:02 PM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: 55Test]
ted s Offline
Loc: Albany NY
IT bearly pours from the bottle
#1593277 - 09/08/09 05:33 PM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: ted s]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
Those engines are notorious for valve seals problems and so thickening up the oil will help but nothing less than replacing the seals will fix the problem completely.
Good reliable engines that run forever as long as they have enough oil and aren't overheated.
You could run 20w50 in the engine until the cooler temps get here and then go to a 40wt then a 30wt as the temperature gets colder.
cheers
Steve grin
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1593298 - 09/08/09 06:13 PM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: StevieC]
Falcon_LS Online   content
Loc: Kuwait
The real problem with the 12-valve 3 litre are the valve guides. Replacing the seals alone will only be a band aid fix, unfortunately.
Seeing the vehicle is a '92, repairing the issue will probably cost more in labour than the vehicle's worth. The best solution to the problem is to use Lexus-branded 5W-40 full synthetic. Consumption will be around a litre every 3,000 miles. If you top it up at the 3,000 mile mark, you can change the oil every 6,000 miles. Anything beyond that, and the oil will be too thin to withstand consumption.
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: GC 0W40/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: GC 0W40/M1206
#1593312 - 09/08/09 06:33 PM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: Falcon_LS]
ionbeam22 Offline
Loc: Boston, MA
That stuff is incredibly thick, thicker than Lucas Oil Stabilizer, which is what I would use for this sort of thing.
IMHO your best bet is a high milage oil in the correct weight, fortified with something like Lucas Oil Stabilizer to make it more substantive.
What you are shooting for is a combination of thin oils that will creep and lubricate as well as thick oils that will stay behind and prevent blowby and dry starts.
You may also want to look up "Restore" engine treatment which contains soft metals compounds that are supposed to seal up rings and things. Seems to have gotten good reviews.
#1593373 - 09/08/09 07:36 PM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: StevieC]
noi8u Offline
Loc: Witch City, Salem, MA, USA
cheers
Steve grin
I wouldn't use a single 30 or 40 as the temperature gets colder! Single 40 is only good for over 60 degrees and single 30 is only good from 30-90 degrees unless you use the Amsoil ACD, which I think everyone should use.
#1593383 - 09/08/09 07:40 PM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: noi8u]
Loc: Kuwait
I think Steve meant 10W-30 or 10W-40 as opposed to a straight 30 or 40 weight. wink
#1593399 - 09/08/09 07:49 PM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: ionbeam22]
noi8u Offline
I totally agree. When I use to drive engines into the ground I would change the oil with a can of Restore shaken well and a bottle of Lucas Stop Leak. Then if I got down a quart I would add the Lucas Heavy Duty Stabilizer, up to 2 times since you can have 60% Lucas in the oil. I included the Lucas Stop Leak in the 60%. Since the additives are so expensive I would use Amsoil so I could go 15k miles between oil changes. No point in changing the oil every 3k miles with all those additives in it. I think Amsoil ACD is the best. In stores I like Castrol Syntec 5w50 also. No need for 0w40 unless you're gonna see 30 below zero.
#1595276 - 09/10/09 12:08 PM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: noi8u]
addyguy Offline
Loc: Canada
I'd try Restore. Can't hurt.
2010 Kia Soul 2U - 2.0L I-4, auto, 86k miles.
QSGB 5W-20, NAPA select filter(?)
#1596055 - 09/11/09 01:49 AM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: addyguy]
KLowD9x Offline
Loc: Lugoff, SC
It's printed on the bottle!
10,000w6,000,000
How that gets a winter rating, I don't know, but they did it!
1993 Volvo 850 2.4i (280K miles, Valvoline Maxlife Full-syn 5w30)
2004 Volvo S60 2.4i (130K miles, Mobil1 0w40)
#1596117 - 09/11/09 03:34 AM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: KLowD9x]
Colt45ws Offline
Loc: Central Washington
Nothing above 50 in the standard range or above 25W in the winter range exists. Anything higher is some company extrapolating.
-Colton
2002 Ford Crown Vic PI, 187k "Highwayman"
Ex-Kootenai County, ID Unit #42
Maxlife 5W20
Lubegard Bio/Tech oil treatment
Ultra XG2
#1596212 - 09/11/09 07:10 AM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: Colt45ws]
KLowD9x Offline
Loc: Lugoff, SC
Please note, I WAS BEING SARCASTIC.
Did I lay it on thick enough there? Just in case you didn't catch it this time either.
#1596257 - 09/11/09 07:46 AM Re: Anyone know the viscosity of Bardahl no-smoke? [Re: KLowD9x]
Colt45ws Offline
I was adding it for informational purposes. I didnt read your whole post, just that number.
-Colton
Maxlife 5W20
Ultra XG2
