Form-A-Funnel
Pennzoil YB $1.79/Quart after MIR (Limit 5)
by akk944
17 minutes 22 seconds ago
Oil recommendations please.
by matt_in_tulsa
57 minutes 24 seconds ago
Multiple quotes
by ChiTDI
Today at 09:30 AM
What's the preferred flavor of weed-trimmer??
by deeter16317
Today at 09:16 AM
September Advance Auto Ad
by tenderloin
Today at 08:34 AM
Brake system bleed now fluid is really dirty
by plrprecision
Today at 07:55 AM
which equation does widman calculator use?
by lipadj46
Today at 07:55 AM
Redline MT-85.
by simple_gifts
Today at 06:10 AM
jimo, porvdub, OADGTi, vicious_fishes, MASSMINI
32957 Registered Users
99 registered (addyguy, asamek, akk944, bdcardinal, AWDfreak, 10 invisible), 506 Guests and 42 Spiders online.
32957 Members
60 Forums
136840 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1530624 - 07/13/09 01:07 PM pressure washer storage-mineral oil
imaduner Offline
Loc: Washington
A friend recomended a solution of 50-50 mineral oil and rv antifreeze for using in my pressure washer pump for storing. Where can I get a gallon of this and what variety should I use ??
I would think it needs to be water soluable. I have a few p/w's to maintain. Thanks
#1530642 - 07/13/09 01:34 PM Re: pressure washer storage-mineral oil [Re: imaduner]
demarpaint Offline
Loc: NY
For the last 15 years here is what I do to store the my pressure washer pump. I made a small hose (male attachment from an old hose) that attaches to where you feed water to the pump. I put a funnel in it and pour green anti freeze in it. Pull the starter cord with the engine in the off position until the AF comes out the pump outlet. Then I take the hose fold it in half, and clamp it with a hose clamp so nothing drips out. My current machine is 15 years old and has been stored that way w/o issue in freezing cold temps.
As a side note, I drain the pump oil and refill it with fresh oil at the end of the season, before I fog the engine and put it away.
GOD Bless our Troops!
#1530725 - 07/13/09 03:12 PM Re: pressure washer storage-mineral oil [Re: demarpaint]
imaduner Offline
Loc: Washington
Thanks, What oil are you using in the pump ???
#1531126 - 07/13/09 09:18 PM Re: pressure washer storage-mineral oil [Re: imaduner]
demarpaint Offline
Loc: NY
I use a straight 30 grade non-detergent oil, I've done so with this machine for 15 years w/o issue.
#1543263 - 07/24/09 10:46 PM Re: pressure washer storage-mineral oil [Re: demarpaint]
JHZR2 Offline
Loc: Collingswood, NJ
so what do you use now that you can't really get green AF anymore?
#1543266 - 07/24/09 10:48 PM Re: pressure washer storage-mineral oil [Re: demarpaint]
JHZR2 Offline
CAT pump?
#1543497 - 07/25/09 07:43 AM Re: pressure washer storage-mineral oil [Re: JHZR2]
demarpaint Offline
Loc: NY
I have about 2 gallons of Green AF in the garage, it takes very little to run it through the machine. I would imagine any anti-freeze would work.
It's not a cat pump, not sure who makes the pump. If I had the machine here I would check the pump brand, I lent it to one of my guys.
The pump is a direct drive pump, not belt driven. 30wt non detergent oil was suggested when I bought the machine 15 years back, vs. a more expensive re-labeled pump oil. The only problems I had with it was the Honda tank rusted out, and last year the carb let go. It was more cost effective to buy a new carb than play around rebuilding the old one. As far as the gas tank goes. I welded a bracket to the handles used for pushing the machine around, and attached a tank there. The Honda gas tank was too much money!
#1587711 - 09/03/09 09:00 AM Re: pressure washer storage-mineral oil [Re: imaduner]
ABM Offline
Loc: Norhtern Michigan
As others have stated just use a 30wt non detergent oil in the pump, non detergent because you don't want the impurities to be suspended in the oil since it's not filtered.
I would recommend running the machine with the gun attached and letting it either suck in the anti freeze or feed it through with gravity from a container above the head hooked up with a hose. I use RV antifreeze in all of mine. The reason you want to run it through with the gun is so that you can release the trigger and have it run through the unloader as well otherwise you run the risk of it freezing.
#1589788 - 09/05/09 12:29 AM Re: pressure washer storage-mineral oil [Re: ABM]
m37charlie Offline
Loc: Alaska
I bought my Karcher at the Exxon Valdez cleanup auction in 1991, so I've kept it running in Alaska for 18 years. It's very important that the water in the heating coils not freeze. So, on ~Sept 15, I put it inside the garage. That's not very complicated.
I run Delo 400 in the oil system.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d
01 BMW 325xi
52 Dodge M37/Hercules diesel
79 BJ40 Landcruiser
