Penrite 5W-30 Full Synthetic
by KL31
37 minutes 35 seconds ago
PP HM at Walmart
by dlundblad
Today at 04:55 AM
74/76mm x 15 Flutes
by Merkava_4
Today at 04:33 AM
Autozone - Pennzoil with the PP - Rebates
by Kwuality
Today at 03:29 AM
Old Toyota
by artbuc
Today at 03:18 AM
Shell Helix Ultra 5W-20 & 0W-20 in Australia
by SR5
Today at 03:03 AM
Little different lube regimen on my 454
by Alex_V
Today at 03:00 AM
REPCO oil sale this weekend in Australia
by SR5
Today at 02:58 AM
ALG Go-Juice
by Ws6
Today at 02:55 AM
Stupid ? 20hp Intek b&s
by southernjeeper
Today at 02:23 AM
Mouse Guns
by bobbob
Today at 02:14 AM
Grease for gun
by DARKSCOPE001
Today at 01:44 AM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
54 registered (akcooper9, beanoil, aquariuscsm, BigD1, Bandito440, 97K15004WD, 4 invisible), 1133 Guests and 11 Spiders online.
58332 Members
66 Forums
251080 Topics
#1582815 - 08/29/09 10:03 PM Brake Fluid Clean Up
Ndx Offline
Loc: IL
Hi all. Had my high pressure hose blow out of the coupling with the master cylinder. Fluid got pretty much everywhere in the engine area, looks like it drenched a couple of wire connectors. What is the best way to clean this stuff off? Go easy with the hose? Wipe it all down by hand? Also, where can I get a factory service manual (dealer only I assume?) Thanks for helping a newbie out!
Mazda 6 2005....
I sprayed it slightly with some water ... I guess it should be fine ?
#1582821 - 08/29/09 10:06 PM Re: Brake Fluid Clean Up [Re: Ndx]
The Critic Offline
Loc: Walnut Creek, CA
I would just spray a degreaser on the engine components and proceed to power-wash the entire engine compartment, just like any other routine wash.
11 Prius - 129k - M1 EP 0w20/OE
07 Accord 2.4 - 111k - M1 5w20/FPS Filter
10 Altima 3.5 - 34k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#1582823 - 08/29/09 10:07 PM Re: Brake Fluid Clean Up [Re: The Critic]
Ndx Offline
Loc: IL
Is this necessary will Brake Fluid eat some stuff ? :P there
#1582846 - 08/29/09 10:21 PM Re: Brake Fluid Clean Up [Re: Ndx]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
Just clean up the excess with a cloth, rinse a bit with water and don't worry about it. Had the master cylinder start peeing fluid all over my electrical harness in my Caravan and it was fine the 12 years after I drove it and it drenched everything in sight.
Tech manuals at the dealer... Best kind to buy, they tell you everything and more than you ever wanted to know about the car.
Being an older model they should be a reasonable price.
What do you need for?
Edited by StevieC (08/29/09 10:21 PM)
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1583152 - 08/30/09 10:32 AM Re: Brake Fluid Clean Up [Re: StevieC]
Kestas Offline
Loc: The Motor City
No need for degreaser, just detergent. Brake fluid is water soluble.
#1583496 - 08/30/09 04:00 PM Re: Brake Fluid Clean Up [Re: Kestas]
mechtech2 Offline
Loc: Chicago Area
Brake fluid is not water soluble. It is hygroscopic.
Brake fluid will eat the paint off of whatever it is laying on in the engine compartment.
It will look fine, then a week or so later, you will notice bubbles and lifting.
Household cleaner like 409, engine cleaner, simple green, etc., and water with a hose.
#1583612 - 08/30/09 05:40 PM Re: Brake Fluid Clean Up [Re: mechtech2]
Kestas Offline
Loc: The Motor City
I repeat, brake fluid IS water soluble.
#1583817 - 08/30/09 08:34 PM Re: Brake Fluid Clean Up [Re: Kestas]
PT1 Offline
Loc: near the mistake
Simple Green is biodegradeable and will take it off. Rinse with warm water.
Oils well that ends well...
#1584894 - 08/31/09 07:52 PM Re: Brake Fluid Clean Up [Re: PT1]
mechtech2 Offline
Loc: Chicago Area
On paper, brake fluid may be water soluble, as some sort of technical point.
But working with it for decades shows me otherwise. Water alone is not a good clean up or solvent for it by any means.
#1585477 - 09/01/09 09:01 AM Re: Brake Fluid Clean Up [Re: mechtech2]
Kestas Offline
Loc: The Motor City
Take a beaker of water, mix in some brake fluid, and see for yourself what happens. Water alone should work fine to remove all traces of ethylene glycol brake fluid.
#1585528 - 09/01/09 09:53 AM Re: Brake Fluid Clean Up [Re: Kestas]
mechtech2 Offline
Loc: Chicago Area
Try cleaning parts, tools, and your hands with just water when you are dealing with brake fluid. Good luck.
[I'm sure you are right technically .]
But this is the original poster's concern - cleaning.
