Originally Posted By: Pablo
If you are using 2 cycle oil at a strong enough ratio that you can smell it, you are using too much. I use it from time to time and it does work, I can actually feel it in the butt dyno. I've posted about this before. Basically functions as a top end lube/oil seal at the rings.
At 400 or 500:1, I would not worry about increased combustion temperatures at all.
I agree with Pablo. I'm using it in all of our vehicles now, at approx 400:1. Idle is quieter and smoother. Most notably, in my hybrid Camry, it's harder to tell when the ICE starts (these cars have no traditional "starter" -- the smaller motor-generator spins the engine up to about 1k rpm, then the ECU adds fuel and spark). Usually, you feel/hear a little rumble before the ICE lights off, and it you back off a tad, you can abort many ICE starts. Harder to feel now. I'm getting slightly better mpgs too. Engine sounds smoother across the range. I have an interstate on-ramp that I drive every time I go home from work. Unless there's traffic, I typically go WOT just for the fun of it. Engine sounds better doing this as well. I'll keep using it.
