Early review on 2015 Chrysler T&C
by badtlc
06/28/16 07:25 AM
New car storage
by JoelB
06/28/16 07:17 AM
How often should I change my oil.
by Greatwhite7
06/28/16 07:01 AM
'91 Mazda B2600i transfer case and trans oil?
by Jason280
06/28/16 03:59 AM
How to cut power to breaker box ?
by Merkava_4
06/28/16 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
06/28/16 01:07 AM
OK, before I lube it ...
by BrocLuno
06/28/16 12:53 AM
Toyota Japan Fluid SDS
by SXE10
06/27/16 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
06/27/16 11:25 PM
Considering a differential swap
by buck91
06/27/16 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
06/27/16 09:51 PM
Car Acronyms
by Marco620
06/27/16 09:46 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
73 registered (Benzadmiral, 69GTX, bbhero, AirgunSavant, 2015_PSD, Astro14, 9 invisible), 1382 Guests and 8 Spiders online.
58295 Members
66 Forums
250920 Topics
#1572426 - 08/20/09 01:21 AM CV joint grease?
nthach Offline
Loc: California
Which stuff would you guys use out of these:
Amsoil Racing 2000
Red Line CV-2
Mobil Delvac Extreme
Lubro Moly CV grease with moly
Good ol' Sta-Lube CV joint grease
I'm looking for something better than OEM.
#1572635 - 08/20/09 09:01 AM Re: CV joint grease? [Re: nthach]
Trav Offline
Loc: MA, Mittelfranken.de
I cant make an informed decision of the choices you gave.Having used only the Liqui Moly version which work well enough i guess,its still in the car.
My question is why are you looking for something better than OEM?
Unless the boots get torn these joints seem to be pretty well lubed from the factory.
We see examples every day with over 100K on them with no issues.
Granted the OEM's don't always use the best designs or even the best parts in some areas but in general the fluids and lubricants seem to hold up pretty well.
#1572968 - 08/20/09 02:00 PM Re: CV joint grease? [Re: Trav]
nthach Offline
Loc: California
The grease has broken down to a thick liquid. Otherwise, the joints are in great shape.
#1580506 - 08/27/09 07:36 PM Re: CV joint grease? [Re: nthach]
Triaged Offline
Loc: SoCal
#1615760 - 09/30/09 09:20 AM Re: CV joint grease? [Re: Triaged]
artificialist Offline
Loc: Florida
Some cars had very weak halfshafts, a better grease might work as a band-aid to extend the life of the halfshafts.
1980s cars often had the biggest problems with halfshafts.
2010 Lancer Ralliart Sportback
#1615853 - 09/30/09 10:26 AM Re: CV joint grease? [Re: artificialist]
Johnny Offline
Loc: Retired | Wausau, WI
I have had really good luck with the Red Line CV-2 grease in this application.
#1617587 - 10/01/09 09:11 PM Re: CV joint grease? [Re: Johnny]
Ken2 Offline
Loc: Washington St.
Use only a grease labeled for the CV joints. This is very tough duty for a grease.
The CV joint boot kits I've bought have included special CV joint grease. You aren't re-using old boots, are you? Get new boots.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
