20W-50 for a hydraulic pump in a hydrostatic trans
by ford46guy
2 minutes 37 seconds ago
new castrol edge high mileage synthetic
by hiflo
17 minutes 55 seconds ago
Just an interesting question
by southernjeeper
Today at 01:52 AM
Value power Walmart battery acid flying out
by bbhero
Today at 12:44 AM
Leased 2013 Ford Suv With19,882 Miles Original Oil
by crazyoildude
Yesterday at 10:35 PM
Steak-House Burgers
by sleddriver
Yesterday at 09:53 PM
Got into an accident.
by bdcardinal
Yesterday at 09:42 PM
Its coming here more and more
by CourierDriver
Yesterday at 08:40 PM
Interpreting oil pressure vs engine RPM
by Emperors6
Yesterday at 08:39 PM
$4 Fram Ultra - Blain's F&F
by Poohbah
Yesterday at 08:21 PM
Toolbox - Pliers
by greasegunn
Yesterday at 08:09 PM
ProSelect Oil Filter????
by qwerty1234
Yesterday at 08:05 PM
jerryg, 1971tr350, Mak712, Lex4TDI4Life, cdub76
57988 Registered Users
24 registered (Char Baby, bbhero, asand1, alcyon, cobra7279, 3 invisible), 512 Guests and 335 Spiders online.
57988 Members
66 Forums
249413 Topics
#1549944 - 07/31/09 10:15 AM kia atf
john stasa Offline
Loc: columbus,ohio
I have a 2007 Kia Amanti, just wondering what brands of AFT are comparable to Kia`s ATF?
#1550118 - 07/31/09 02:05 PM Re: kia atf [Re: john stasa]
coachditka Offline
Loc: Texas
2005 Nissan Titan 280k
Pennzoil Ultra 5w30
Royal Purple Oil Filter
Amsoil ATF
Amsoil 75w140 diff oil
2007 Volvo XC90 V8 AWD 140k
Mobil 1 0w40
Mobil 3309 ATF
#1550191 - 07/31/09 03:01 PM Re: kia atf [Re: coachditka]
Gary Allan Offline
Loc: Pottstown, PA
This too
..but in an effort to more completely answer your question ...
Formula Shell Multi-vehicle ATF
http://www.pzlqs.com/Docs/GPCDOC_X_cbe_24855_key_140002162227_32AE.pdf
The spec's are identical for PZ MVF AFT
http://www.pzlqs.com/Docs/GPCDOC_X_cbe_24855_key_140002163815_4BE.pdf
..and Quaker State is the same as well.
Mobil 1 works
Mobil 1 Synthetic ATF is also suitable for use in vehicles that specify the following fluid requirements:
Audi G 052 025-A2, G 052 162-A1
BMW LA2634
Esso LT 71141
ETL-7045E, ETL-8072B, N402
Ford* MERCON*, MERCON V, MERCON LV
All 2005 and earlier GM vehicles**
Honda ATF-Z1*
Hyundai SP-II, SP-III
Idemitsu K17
JWS 3309
Kia SP-II, SP-III
MAN 339F, V1, V2, Z1, Z2, Z3
Mazda ATF-III, ATF-MV
Mercedes-Benz 236.1, 236.2, 236.5, 236.6, 236.7, 236.9
Mitsubishi Diamond SP-II, SP-III
Nissan Matic-D, Matic-J, Matic-K
Subaru ATF
Toyota T-III, T-IV
Voith 55.6335.XX (G607, G1363),
Volvo 97340
ZF TE-ML 03D, 04D, 09, 14A, 14B, 16L, 17C
as does Mobil's MV ATF
Approved for MERCONŽ VApproved for Allison C-4 applications
Exceeds the requirement of the JASO 1-A performance standards
Mobil Multi-vehicle ATF is also suitable for use in vehicles that specify the following requirements:
BMW LA2634
Esso LT 71141
Ford* MERCON*, MERCON LV
Honda ATF-Z1*
Idemitsu K17
JWS 3309
Kia SP-II, SP-III
Subaru ATF
Toyota T-III, T-IVVoith 55.6335.XX (G607, G1363),
Volvo 97340
Texaco's MD-3 doesn't show SPIII as a recommendation. Just DexIIIH, MerconV, and +4
I didn't dwell too long on Red Line's site, but found no specific reference to SPIII.
http://lube-direct.com/gallan/
#1550273 - 07/31/09 04:55 PM Re: kia atf [Re: Gary Allan]
john stasa Offline
Loc: columbus,ohio
Thanks for the info.Didn`t know there was that many.
#1550586 - 07/31/09 11:21 PM Re: kia atf [Re: john stasa]
unDummy Offline
Loc: RI
Any universal or multivehicle ATF mentioning the spec's on the bottle or datasheet will work well. After a fluid change, do a battery disconnect to improve new fluid adaptability drive-ability.
Amsoil, Amalie, Mobil1, Castrol(import and high mileage), RoyalPurple.... are some great choices.
Certain fluids, like Pennzoil, Mobil1, Qs.... have different revisions depending on the age of the fluid at the local parts store. Make sure it mentions SPIII on the bottle.
My favorite SPIII substitute is ATF+4.
Edited by unDummy (07/31/09 11:21 PM)
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#1550644 - 08/01/09 12:49 AM Re: kia atf [Re: unDummy]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
Make 100% sure it meets the SP-III Specification or you could end up destroying your transmission in a short period of time!
Do Not use a fluid if you are unsure.
Also if you get your fluid changed at a quick lube place, make sure they show you the specification for the oil before putting it in so you know it meets SP-III without a doubt!
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1554287 - 08/04/09 05:31 PM Re: kia atf [Re: StevieC]
LushGreenLawn Offline
Loc: Delaware
Talk to KIA. Chances are, you have to buy from them.
My Wifes Sorrento takes Kia Red 1, which from what I understand is an updated fluid that almost all kia's take now. They would not tell me if I could use another type of fluid. My manual called for Mobil DII, and that is not listed anywhere either.
#1554574 - 08/04/09 09:58 PM Re: kia atf [Re: LushGreenLawn]
unDummy Offline
Loc: RI
I'll give you a hint on Red-1. Its the Korean equivalent of the jatco ATF that Nissan, Subaru.... uses. Any good multivehicle/universal ATF work excellent.
And, SPIII is absolutely pathetic. Its friction modified for the damper clutches, which is no different from any other slip controlled TC.
Don't let the dealer steal what little freedom you have by forcing you to use a dealer OE sourced overpriced inadequate ATF.
#1554792 - 08/05/09 06:40 AM Re: kia atf [Re: LushGreenLawn]
Cup of Joe Offline
Loc: United We Stand
If you choose to stick with the dealer only that is your desicion. A technician that works at a dealership swears that in their factory training you cannot remove the transmission pan for any reason or it will void your warranty. Does that make any sense at all since they sell a transmission filter for my model. I choose to remove the pan and replace the filter warranty be [censored].
FYI Sorrento's used to take Dex III while the rest took SPIII.
Here is a comparison I did of Amsoil ATF and SPIII it also has a link to the VOA I did of SPIII. http://www.bobistheoilguy.com/forums/ubb...&gonew=1#UNREAD
2015 Toyota 4runner with dealer installed bulk Valvoline 0w-20 What the heck?
#1554804 - 08/05/09 07:16 AM Re: kia atf [Re: unDummy]
Falcon_LS Offline
Loc: Kuwait
Mitsubishi SP-III here is sourced from ENEOS (Nippon-Mitsubishi Oil) in Japan, and their operations in Thailand. I cannot comment on the American stuff, or why you reckon it's "pathetic". But I have been using it in my truck's Aisin-Warner tranmission (calling for Dexron II+/SP-II+), and it comes out like new when flushed out at the recommended 25,000 mile interval. It shifts and runs smoother than Dexron III, Mercon and Mercon V in my application, all of which I've tried for at least 25,000 miles each.
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: GC 0W40/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: GC 0W40/M1206
#1556721 - 08/06/09 08:28 PM Re: kia atf [Re: Falcon_LS]
StevieC Offline
I'm using Amsoil ATF which claims to be SP-III rated and have been for the last 100K KM (60K Miles) and my transmission has never shifted better. It has over 200K KM (120K miles) on it now. ;\)
It's a Hyundai Santa Fe 2.7 Litre.
#1557406 - 08/07/09 12:56 PM Re: kia atf [Re: StevieC]
nthach Offline
Loc: California
FWIW, I'm using MaxLife in a Hyundai Santa Fe and it's shifting as fine as ever - or so what the owner says.
#1557646 - 08/07/09 06:00 PM Re: kia atf [Re: nthach]
StevieC Offline
That is because it meets SP-III requirements as stated here: http://www.valvoline.com/faqs/system-fluids/automatic-transmission-fluid/94
 Quote:
8) Q: Is MaxLife ATF an SP-111 fluid?
A: MaxLife Dex/Merc ATF is 100% compatible for use in SP-II and SP-III applications.
This doesn't mean all Dex/Merc products will work in a SP-III application, but this oil happens to meet all these specs, as does the Amsoil I use. ;\)
