Local Big Lots still has Valvoline next gen 10w30
by Electromotive
06/26/16 01:25 PM
Best Value Differential Oil 75W-90
by KevinP
06/26/16 01:02 PM
kohler 17hp . changed oil , now will not run
by chad8
06/26/16 12:32 PM
Oil change recomendations for '11 Ranger 2.3 Liter
by ryan2022
06/26/16 11:49 AM
Suggestions for 94 Lexus LS400 ATF
by Gasbuggy
06/26/16 11:23 AM
GOST Diesel fueln
by m37charlie
06/26/16 11:10 AM
Old interesting finds
by car51
06/26/16 10:53 AM
Filling nail holes in drywall
by Drew99GT
06/26/16 10:47 AM
1987 ford 460 motorhome, which oil to use?
by digler
06/26/16 10:30 AM
My ride in a B-17
by cb4017
06/26/16 10:28 AM
Speaking of missing members
by Oldmoparguy1
06/26/16 10:10 AM
Wiper blades $3.88 at Home Depot
by Jimmy9190
06/26/16 09:57 AM
Ruturaj, derfderfgoose, ssnead, mtrev, redtacoma
58277 Registered Users
75 registered (-SyN-, 901Memphis, andyd, b1amgm47, Atesz792, 04SE, 7 invisible), 1954 Guests and 10 Spiders online.
58277 Members
66 Forums
250838 Topics
#1554402 - 08/04/09 06:53 PM Harsh shifts in 2004 Impala 3.4L
cq2120 Offline
Loc: Elgin, IL
I have a 2004 Impala 3.4L with 53k on it. It has been shift harshly recently. When the trans is cold it shifts butter smooth, but after about 15-20 miles of driving every shift is very hard. If I let the car cool for a few hours it shifts great again. That is for first 15-20 miles. Any thoughts?
#1554472 - 08/04/09 08:03 PM Re: Harsh shifts in 2004 Impala 3.4L [Re: cq2120]
wafrederick1 Offline
Loc: Mi
Does the service engine soon light come on?Get it scanned for codes and one known code,1811 will probally come up
#1554516 - 08/04/09 08:56 PM Re: Harsh shifts in 2004 Impala 3.4L [Re: wafrederick1]
GMFan Offline
Loc: NC
Have you ever changed the transmission fluid or had it done recently?
2011 Mazda6, 81k miles
Havoline Pro DS 0W-20, Fram ToughGuard
“Muscles aching to work, minds aching to create - this is man.”
#1554535 - 08/04/09 09:09 PM Re: Harsh shifts in 2004 Impala 3.4L [Re: cq2120]
cq2120 Offline
Loc: Elgin, IL
The service light does not come on. And the DTC scan performed by Autozone did not show any codes. Is is possible that an aftermarket scanner won't be able to read the tranny DTC codes. And yes the fluid has been changed, and none off the symptoms changed afterwords.
#1554555 - 08/04/09 09:40 PM Re: Harsh shifts in 2004 Impala 3.4L [Re: cq2120]
RedDart Offline
Loc: Maryland
I had a 2002 Impala with the same problem, which acually became worse after a full transmission flush. In addition, there was a whirring sound coming from the left side of the vehicle in the vicinity of the transaxle. After doing some research I learned that it appears that this problem may be caused by a defective pressure control solenoid and GM has issued a TSB (#00-07-30-002B) for that issue. In my case, the harsh shifting from 1st to 2nd gear set codes that the transmission shop could read via a scanner. The GM 4T65 transaxle has a known problem with the planetary gearset wearing out early when driven under certain conditions. If you have not had a pan drop and filter change done I would recommend that service and use the latest version of Dexron, which is Dexron VI. You are at the point where fluid replacement should occur using the severe schedule. I strongly recommend that you avoid a full flush. I believe the flush I had done distributed dirt and metal particles throughout the transaxle exacerbating the issues I was having. I wish you the best of luck and that you can get some more life of your 4T65. We had our unit replaced at 84K miles due to the possibility of an internal failure.
#1554583 - 08/04/09 10:14 PM Re: Harsh shifts in 2004 Impala 3.4L [Re: RedDart]
Loc: Mi
Sonnex does sell an updated pressure control solenoid.AutoZone uses a code reader which only read codes.Any aftermarket including the Snap On Modis can read the transmission codes.
#1563039 - 08/12/09 06:42 AM Re: Harsh shifts in 2004 Impala 3.4L [Re: cq2120]
raidermark Offline
Loc: Nevada,US
I have the same problem with my 2003 Impala w/ 3.8 liter @105000 mi. It started soon after I had a complete transmission flush. The shifting for me is a pre-mature hard shift when first accelerating. It seems to clear if I manually shift through 1rst, 2nd & 3rd gears & then Drive. I'll take it to the shop if it gets worse.
1998 Suburban 1500
2014 Equinox
2007 Yukon XL 2500
Mobil 1
