Power Steering Fluid
by DWC28
07/25/16 10:07 AM
Troy-Built 4.5hp running problem
by Kestas
07/25/16 09:26 AM
Conventional oil instead of synthetic
by corndogzombie
07/25/16 08:05 AM
kohler courage 15 issues
by tomm22
07/25/16 07:58 AM
Small overlap crash test?
by Huie83
07/25/16 07:39 AM
Top Tier Fuels and Tailpipe deposits
by virginoil
07/25/16 07:20 AM
Honda GX35 question
by dirtydannyd
07/25/16 02:08 AM
Need advices for oil filter inspection
by ST2008
07/25/16 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Toyota 5w20 blend?
by researcher
07/24/16 11:36 PM
Smoked some baby backs today
by BeerCan
07/24/16 10:28 PM
Ken_Clifton, HotDog15, curiousaboutoil, 01CAMRY, corndogzombie
58589 Registered Users
90 registered (4WD, 1foxracing, 18LateModelFan, 2015_PSD, 2002 Maxima SE, AIRJAC3, 6 invisible), 1829 Guests and 15 Spiders online.
58589 Members
66 Forums
252228 Topics
Page 1 of 2 1 2 >
#1553724 - 08/04/09 08:25 AM Marvel Mystery Oil
CCI Offline
Loc: New Mexico USA
What does Marvel Mystery Oil do?
How does it work?
What are any down-sides to it?
I've got a mid-1950s engine that had stuck piston rings, smoked like a mosquito truck. I added Marvel to the crankcase oil, to the gas, and down the spark plug holes.
It worked great. No more smoking, no more stuck rings, almost immediately.
Should I change the oil now?
Thanks.
#1553755 - 08/04/09 08:43 AM Re: Marvel Mystery Oil [Re: CCI]
sciphi Offline
Loc: Upstate NY
I'd let it run for a little longer with the MMO in, then change the oil. Let it ensure everything is freed up.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
#1553756 - 08/04/09 08:43 AM Re: Marvel Mystery Oil [Re: CCI]
Rob_Roy Offline
Loc: Northern, NY
I run it for a little bit then change the oil. The MMO isn't as much of a concern as all of the junk it probably loosened out of the ring packs.
After the initial oil change feel free to keep using the MMO in the fuel and oil to continue the clean up.
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10 workhorse
#1553765 - 08/04/09 08:51 AM Re: Marvel Mystery Oil [Re: CCI]
JHZR2 Offline
Loc: New Jersey
good stuff, but mystery is part of the name. Chemical analysis, MSDS, etc., IMO isnt all that telling.
Obviously lots of folks put it in their oil, so a bit of dilution is no biggie... that said, on an original 1950s engine, Id want as much cleaning as I could get, so doing a number of changes with an HDEO is, IMO a good idea.
#1553826 - 08/04/09 09:49 AM Re: Marvel Mystery Oil [Re: JHZR2]
CCI Offline
Loc: New Mexico USA
Thank you everyone who replied. I wasn't too sure about this, but as bad as the engine was running I figured it was worth a try. The results were simply amazing. Almost immediate, certainly within minutes.
I'll run it until the oil is hot today and change it, and keep running it in the fuel.
While we're on the subject, what is the significance of oil dilution in this case?
#1553831 - 08/04/09 09:56 AM Re: Marvel Mystery Oil [Re: CCI]
FastSUV Offline
Loc: oklahoma
Is it as good/better for carbon cleaning (in fuel) as SeaFoam???
Is it as good/better for cleaning (in crank case) as Rislone???
I like MMO but I rarely use it because of those other 2 products.
'01 Jeep GC 4.0L - 110k (current setup is 6k OCI w/ 10w30 Rotella T5)
'98 Jeep 5.9 Limited - 183k (current setup is 5k/or 1yr OCI w/ 10w30 Rotella T5)
#1553925 - 08/04/09 11:33 AM Re: Marvel Mystery Oil [Re: FastSUV]
panthermike Offline
Loc: Phoenix, AZ
Not sure as an oil cleaner vs. rislone, but seafoam i'd imagine is more aggressive on carbon. MMO is a UCL and probably keeps your fuel system clean. MMO actually recommends using something strong for an initial cleaning if you haven't, then go onto MMO. Pretty sure on that, not positive.
'16 Ram Sport 1500;PP 5w20 2K
'15 Lincoln MKC; MC 5w30 24K
'77 F250 "Ol Yeller"; Kendall/Mos2
'98 ES300; ML/Biotech 206K
#1553954 - 08/04/09 12:03 PM Re: Marvel Mystery Oil [Re: panthermike]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
MMO contains solvents and not just UCL properties.
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1553959 - 08/04/09 12:07 PM Re: Marvel Mystery Oil [Re: StevieC]
chevrofreak Offline
Loc: Billings, MT
Oil of wintergreen is apparently quite a good cleaner.
I <3 Red Line oil
#1553971 - 08/04/09 12:13 PM Re: Marvel Mystery Oil [Re: chevrofreak]
StevieC Offline
Dunno.. Smells great though, thinkin' about showering in it!
#1554013 - 08/04/09 12:43 PM Re: Marvel Mystery Oil [Re: StevieC]
ericthepig Offline
Loc: Little Rock, AR
The bulk of my reading on the various cleaners tells me none of them will hang the moon in short order. If MMO did something for you in one dose, then you're fortunate.
I'm an ongoing MMO user - in the gas, and at the end of an OCI I'll sometimes do my last top off with some MMO. In my brain, Neutra 131 (Schaeffers) trumps MMO in both uses (gas and as slow engine purge) - but I don't always have Neutra around. (MMO markets itself as resisting deposits - not so much at cleaning up what's there. Neutra is designed to clean.)
If I were attacking a dirty engine I would (and have with good results) - hit it first with a strong solvent to kick start the softening process - that is, I'd run Seafoam for 200 miles or do a 30 min Amsoil flush (with their 15 min. stuff) - and then follow this in your next fill with your favorite slow cleaner.
(and the slow cleaner phase could be multi-phased - over six months to a yr)
Edited by ericthepig (08/04/09 12:46 PM)
'06 Mazda 6 (97k) - Pennz YB 5w20 for summer (1 filter/yr)
'98 Sienna - (87k) - Pennz YB 5w30 1 yr OCI (but only ~5k miles)
#1554114 - 08/04/09 02:36 PM Re: Marvel Mystery Oil [Re: ericthepig]
360kid Offline
Loc: USA
I was under the impression that a product like Seafoam is a better cleaner, i.e. removing sludge and deposits. Where MMO is a cleaner too but MMO also lubricates as well? I only am assuming this because many users have commented that they use it to lubricate their fuel systems where seafoam users only comment on the cleaning aspect? Right or Wrong?
#1554120 - 08/04/09 02:45 PM Re: Marvel Mystery Oil [Re: 360kid]
es350 Offline
Loc: LA
seafoam is poor for any cleaning.
"RX is great, the instructions are not"..Sprintman 7-2009
#1554156 - 08/04/09 03:23 PM Re: Marvel Mystery Oil [Re: CCI]
demarpaint Offline
Loc: NY
 Originally Posted By: CCI
What does Marvel Mystery Oil do? CLEANS, LUBRICATES, AND WORKS AS A uCL.
How does it work? IT IS VERY THIN AND ACTED LIKE A PENETRATING OIL IN YOUR CASE.
What are any down-sides to it? NONE IF USED AS DIRECTED.
Thanks.
MMO in the oil cleans as well as lubricates. I wouldn't exceed their suggested dose of 1 qt in the sump. Since you added it to the cylinders, I would change the oil out. Fill it with your favorite oil, less one quart, a new filter, and drive it. Continue adding it to the gas at a rate of 4 oz/ 10 gallons of gas. Enjoy. MMO has been known to free up engines with the same symptoms you've described.
God Bless Our Troops
#1554229 - 08/04/09 04:29 PM Re: Marvel Mystery Oil [Re: 360kid]
FastSUV Offline
Loc: oklahoma
I REFUSE to put any solvents in my crank case! If it disolves the trash, then think what it does to the lubrication? That is why I choos rislone for gentle engine cleaning over a 3k OCI. It reminds me of Doxidan.
As for SeaFoam, I ONLY use it in gas tanks (jetski, boats, lawnmowers, vehicles, etc.) as a winterizer (if I am out of Stabil), but most likely I am using it throught the intake to knock the carbon off the valves & pistons. That is my primary use for SeaFoam.
Page 1 of 2 1 2 >
