New Dillon CV-2001 Tumbler
by 2015_PSD
07/30/16 05:16 PM
Any video gamers?
by NavyVet88
07/30/16 04:40 PM
Full Synthetic High Mileage Oil
by jsjonz01
07/30/16 04:38 PM
Road trip on new vehicle?
by mrjlube
07/30/16 03:54 PM
Oil Infatuation
by Passport1
07/30/16 03:43 PM
FREE T-SHIRT, $10, AND GOD KNOWS WHAT ELSE....
by macarose
07/30/16 03:16 PM
Griot's Brilliant Finish Carwash
by SavagePatch
07/30/16 02:25 PM
Hanging 3rd - Honda Automatic
by RevelationLion
07/30/16 01:31 PM
Oil Interval Mountain Driving Road Trip
by Yup
07/30/16 12:58 PM
Giant VW Beetle....
by mattwithcats
07/30/16 12:43 PM
anyone have the 12 ton HF press?
by joel95ex
07/30/16 12:27 PM
BMW final drive 75W90 GL5. Supertech semisyn OK?
by David_g
07/30/16 12:00 PM
kenb777, Indyfan3, RM53119, Ctanke, jractk
58649 Registered Users
72 registered (Blkstanger, 2015_PSD, 182RG, AirgunSavant, billt460, Astro14, 7 invisible), 1692 Guests and 7 Spiders online.
58649 Members
66 Forums
252456 Topics
#1551185 - 08/01/09 08:09 PM High Vacuum Pump Oil
TxGreaseMonkey Offline
Loc: Texas
What specific synthetic high vacuum pump oil would you recommend for a U.S. General (Harbor Freight #98076) 2.5 CFM Vacuum Pump? No vacuum pump oil information was provided with the product.
Amsoil ASL, GLC, ATF, MTF, PSF, ATP and PureOne Filters.
#1551258 - 08/01/09 09:00 PM Re: High Vacuum Pump Oil [Re: TxGreaseMonkey]
tom slick Offline
Loc: Central Coast, Calif.
Vacuum pumps take a specific oil. Mobil sells it by the quart. Grainger and mcmaster-carr both carry it.
You get what you pay for...
So keep in mind how much you paid for this advice.
#1551943 - 08/02/09 03:54 PM Re: High Vacuum Pump Oil [Re: TxGreaseMonkey]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
As far as I can tell most of these smaller "home" unit vacuum pumps take ISO 68 viscosity oil. Robin sells one as does Mobil (Cross reference to Amsoil PCJ PCJ LINK ). Both are petroleum/conventional base oils. The only thing special about these oils, are the low vapor pressure and the dryness.
I have recommended PCI PCI LINK for smaller vacuum pumps and PCK PCK LINK for the bigger pumps in the past with great success, but I hesitate a bit because I just don't know exactly what the supplied HF oil is. I doubt there would be any problem with a 50/50 PCI/PCK (same as PCJ PCJ LINK ) mix as other folks have done in the past with similar vacuum pumps.
#1551978 - 08/02/09 04:28 PM Re: High Vacuum Pump Oil [Re: Pablo]
Chris142 Offline
Loc: apple valley, ca
We get vacuum oil from Napa. Comes in a qt container.
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#1552485 - 08/03/09 07:34 AM Re: High Vacuum Pump Oil [Re: TxGreaseMonkey]
Pablo Offline
I just got a reply from HF:
 Quote:
The iso is not critical as long as its vacuum pump oil. I recommend the
Yellow Jacket brand, that is what I have used in the past. Vacuum pump
oil is specially designed to absorb air and is non-foaming. Some brands
that I have searched on the internet state iso 100.
With that, I would just get a quart of Amsoil PCK ISO 100 vacuum pump/compressor oil.
#1552628 - 08/03/09 10:21 AM Re: High Vacuum Pump Oil [Re: Pablo]
Loc: Texas
I came to the same conclusion (Amsoil PCK).
#1552674 - 08/03/09 11:09 AM Re: High Vacuum Pump Oil [Re: TxGreaseMonkey]
Pablo Offline
Funny how he says viscosity doesn't matter.
Anyhow - cool - let us know how she goes (sucks...) :)
#1552714 - 08/03/09 11:44 AM Re: High Vacuum Pump Oil [Re: Pablo]
Loc: Texas
It's amazing how the vacuum pump manufacturers talk about how critical it is to use the proper high vacuum pump oil and then provide no technical information whatsoever on what the characteristic of that oil should be. This goes for U.S. General (Harbor Freight), Robinair, and MasterCool. I've never seen the likes of it.
Some have said to dump the oil after a month, since it's hygroscopic. Sounds like they are putting this oil in the same league as PAG oil. Any thoughts, Paul?
#1552837 - 08/03/09 01:44 PM Re: High Vacuum Pump Oil [Re: TxGreaseMonkey]
Pablo Offline
I suppose if you use the pump constantly in very humid conditions, sure.
#1572657 - 08/20/09 09:18 AM Re: High Vacuum Pump Oil [Re: Pablo]
bsmithwins Offline
Loc: OR, USA
I've serviced a lot of rotary oil filled roughing pumps.
I've never noticed a performance difference from different vacuum oil, including pumps using mineral based oils and those using Fomblin type synthetics.
Oil change frequency depends on what you're pumping. Systems with no process gas (or inert gas) and that aren't open to air I've done annual oil changes on. These were pumps that ran 24/7. I have seen oil filled rotary pumps that were used with a gas mix that required the oil to be changed every 3 days. If it wasn't the oil started polymerizing.
BSW
#1573265 - 08/20/09 07:29 PM Re: High Vacuum Pump Oil [Re: bsmithwins]
moklock Offline
Loc: FL
FWIW, I've been running the Robinair oil in the same pump. It is IMO the same thickness as the no-name stuff that came with it, which I ran for only one use then dumped.
#1644631 - 10/24/09 09:33 PM Re: High Vacuum Pump Oil [Re: moklock]
HardbodyLoyalist Offline
Loc: Lower Alabama
I run Robinair oil in all of my vac pumps, both belt drive and direct drive.
It's usually available through air conditioning supply houses.
1994 Nissan Hardbody -- Mobil 1 HM 5W30
1998 Ford F150 4WD -- Mobil 1 HM 5W30
2009 VW Jetta TDI -- Pentosin SuperPerformance III 5W30
#2016923 - 09/14/10 02:51 PM Re: High Vacuum Pump Oil [Re: HardbodyLoyalist]
porcupine73 Offline
Loc: Buffalo, NY
I just picked up the 3CFM dual stage version of this pump. The manual says 'Use a low viscosity vacuum pump oil (i.e., HFV-46)'. HFV-46 appears to be an oil of Chinese origin not available in small quantities.
After reviewing this thread and the Amsoil literature, I have decided to use Amsoil PCI (ISO 46 compressor oil) in this application.
#2018485 - 09/16/10 07:45 AM Re: High Vacuum Pump Oil [Re: porcupine73]
widman Offline
Loc: Bolivia
I looked into one for a milking machine and found the spec sheet. It was regular hydraulic oil.
Richard's Car Restorations
