Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
How to do a clean install
by Oldmoparguy1
02/10/16 07:21 PM
Troy Bilt Pony
by OSUFan86
02/10/16 06:43 PM
$1.33 for a GALLON of 87!
by Vern_in_IL
02/10/16 06:30 PM
Eating out, beware you all
by CourierDriver
02/10/16 06:13 PM
Best Sponge For Washing Cars
by George7941
02/10/16 06:08 PM
Old school (ethanol) and (leaded) fuels
by mjoekingz28
02/10/16 05:37 PM
Opinions on this oil filter relocation setup
by bspag
02/10/16 04:42 PM
E-brake tightening on Cobalt Chevrolet
by mjoekingz28
02/10/16 04:32 PM
Mobil 1 EP rollbacks at local Walmart
by HTSS_TR
02/10/16 04:29 PM
Miningman, pocketdrummer, bspag, Lana, phem0r
56883 Registered Users
117 registered (3800Series, A1O, 01rangerxl, 901Memphis, 69GTX, 97f150, 12 invisible), 1549 Guests and 247 Spiders online.
56883 Members
66 Forums
244525 Topics
Page 1 of 4 1 2 3 4 >
#1550090 - 07/31/09 01:27 PM Best oil for a 2009 BMW 335d
Burpelson Offline
Loc: Jannesville
New BMW 335d. What is the best oil Mobil 1 ESP 5w30? You guys know best.
Should I do a break change? I will use a 7500 mile OCI even with a good oil because the car is a taxi.
#1550123 - 07/31/09 02:11 PM Re: Best oil for a 2009 BMW 335d [Re: Burpelson]
BimmerMan Offline
Loc: California
A 2009 BMW 335d as a taxi....WOW!
Mobil 1 ESP 5w30 is fine..:)
2000 BMW 528i
1992 BMW 325is
#1550133 - 07/31/09 02:16 PM Re: Best oil for a 2009 BMW 335d [Re: BimmerMan]
djlinux64 Offline
Loc: College Park, MD
Not sure how much you care about wear. If you want to minimize wear, use German Castrol (Euro formula) 0w-30 or Redline. Redline will give you far and away the least wear. If that is what you care about then shell out the money and worry no longer. There are a ton of guys on here that have 300-600K miles on their trucks and cars on that stuff that have done tear down analysis to find most or all metal parts within factory spec. GC is also a solid oil and slightly more available around the states.
#1550134 - 07/31/09 02:19 PM Re: Best oil for a 2009 BMW 335d [Re: djlinux64]
djlinux64 Offline
The issue I have with Mobil 1 is that my father had a 2001 Mercury Sable that was gently driven for 165,000 miles on Mobil 1 5w-30 with a 3000 mile OCI and then after that the engine started knocking and smoking!? [censored]? Also, most OCI of Mobil 1 have completely unexplainable elevated iron levels. Oil does not come with iron. Also, Mobil 1 changed their formulation after they lost the synthetic name lawsuit with Castrol and have cheapened their oil to hydrocracked Group III [censored] ever since 1997. Don't use Mobil 1. It is not what it used to be.
#1550135 - 07/31/09 02:19 PM Re: Best oil for a 2009 BMW 335d [Re: djlinux64]
BimmerMan Offline
Loc: California
GC doesn't meet the LL-04 spec required for the new diesels.
2000 BMW 528i
1992 BMW 325is
#1550137 - 07/31/09 02:19 PM Re: Best oil for a 2009 BMW 335d [Re: djlinux64]
Quattro Pete Offline
Loc: Great Lakes
His engine calls for an oil meeting LL-04 spec. While GC is good oil, it does not meet this spec. Another words, GC is not some kind of a miracle cure that's always good for everything.
In order to preserve the manufacturer warranty, he should stick with an LL-04 oil. M1 ESP 5w-30 is probably as good as it gets in this area.
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#1550138 - 07/31/09 02:20 PM Re: Best oil for a 2009 BMW 335d [Re: djlinux64]
BimmerMan Offline
Loc: California
:facepalm:
2000 BMW 528i
1992 BMW 325is
#1550140 - 07/31/09 02:22 PM Re: Best oil for a 2009 BMW 335d [Re: djlinux64]
Loc: Great Lakes
M1 and M1 ESP aren't exactly the same animal.
Besides, what you describe here isn't really proof that it was M1 that caused his engine to smoke. There could have been a number of other factors that were responsible. How sure are you that there would not be any smoke after 165k miles if he used any other oil?
#1550141 - 07/31/09 02:23 PM Re: Best oil for a 2009 BMW 335d [Re: BimmerMan]
djlinux64 Offline
What a shame. Check out the Redline. You will fall in love with it once you see the flash points and HTHS numbers
#1550145 - 07/31/09 02:25 PM Re: Best oil for a 2009 BMW 335d [Re: Quattro Pete]
hate2work Offline
Loc: Western Washington
Exactly, and neither is Redline, as dj would have us believe. I think he works for them
#1550146 - 07/31/09 02:25 PM Re: Best oil for a 2009 BMW 335d [Re: Quattro Pete]
djlinux64 Offline
Besides, what you describe here isn't really proof that it was M1 that caused his engine to smoke. There could have been a number of other factors that were responsible. How sure are you that there would not be any smoke if he used any other oil?
The only other explanation is that Ford engines suck. That car was in tip top shape and completely babied for its entire life... Poor thing - but its gone now.
#1550152 - 07/31/09 02:31 PM Re: Best oil for a 2009 BMW 335d [Re: djlinux64]
Loc: Great Lakes
I've seen a lot of engines that developed some sort of smoke problem by the time they hit 165k miles. I'm sure not all of them were running M1. Your example is anecdotal at best.
#1550156 - 07/31/09 02:34 PM Re: Best oil for a 2009 BMW 335d [Re: djlinux64]
Loc: Great Lakes
I'm afraid that when it comes to a rather complex diesel engine such as his, there is more to oil than just flash point and HT/HS. Certainly, Redline makes good oils, but which one of them carries LL-04 or even basic API certification? Try to explain it to the dealer when push comes to shove considering honoring of the vehicle warranty.
#1550160 - 07/31/09 02:36 PM Re: Best oil for a 2009 BMW 335d [Re: hate2work]
BimmerMan Offline
Loc: California
Here's some more oils that meet LL-04..
Amsoil 5w-40 European Car Formula
Valvoline Synpower MST 5w-30
Valvoline Synpower MST 5w-40
LIQUI MOLY Longtime High Tech 5W-30
Total QUARTZ INEO MC3 5W-30
2000 BMW 528i
1992 BMW 325is
#1550226 - 07/31/09 03:39 PM Re: Best oil for a 2009 BMW 335d [Re: BimmerMan]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
Best oil? I'd go with some bio-diesel!
Nice car, gotta love over 400 ft/lbs of torque!
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
