What happened to Anco wiper blades
by grampi
05/27/16 07:21 AM
Full brand oil filter
by RRLJR
05/27/16 05:31 AM
Half Price GTX 15W-40 @ REPCO in Oz
by SR5
05/27/16 03:27 AM
1991 Sierra rear brake squeel
by sr17
05/27/16 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
05/27/16 12:25 AM
Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
05/26/16 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
05/26/16 10:54 PM
What Ohm antenna wire to use?
by daves66nova
05/26/16 10:46 PM
Turtle Wax Passed The Test
by RevRider
05/26/16 10:46 PM
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
05/26/16 10:17 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
67 registered (2015_PSD, A_Harman, 69GTX, Astro_Guy, aquariuscsm, badtlc, 6 invisible), 1074 Guests and 310 Spiders online.
57996 Members
66 Forums
249472 Topics
#1524681 - 07/07/09 11:33 PM Should i buy a hotter thermostat?
Klutch9 Offline
Loc: Rochester, MI, US, World
my car is a 1997 pontiac grand am, 2.4l 4-cyl with 148k miles... filled with dexcool. it has the factory 180*f thermostat (IMO thats pretty cold, especially according to today's emissions standards). i would like to get a little better gas mileage out of the car though, and i have seen a 192 and 195*f thermostat for sale online. would slightly hotter engine temps hurt? i know... some may say "well it came that way from the factory so dont mess with it". i've had several high performance cars that i've put lower temperature thermostats into with no problems at all, so maybe it would also work the other way around...? the car is slow to reach operating temperature and rarely creeps above operating temperature even in the summer heat or in traffic, so overheating isn't a problem.
Edited by Klutch9 (07/07/09 11:40 PM)
'11 Fusion 2.5L - 60k miles - Napa 0w20, Fram TG filter
'08 Sedona LWB 3.8L - 96k miles - Napa 0w20, K&N PS filter
#1524718 - 07/08/09 12:25 AM Re: Should i buy a hotter thermostat? [Re: Klutch9]
Quest Offline
Loc: beaver land EH?
Been working on imports most of my time, I'm a firm believer in factory spec'ed termostat (most of the time, I replace with factory OE'ed thermostat, and wouldn't even bother with aftermarkets).
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#1524899 - 07/08/09 08:29 AM Re: Should i buy a hotter thermostat? [Re: Quest]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
I wouldn't change from the OE thermostat temperature. You could end up cracking a head, blowing a head gasket, wearing your water pump prematurely. This is assuming the right one is in there now and wasn't changed with a cooler one at some point. Your local dealership and many parts look-up catalogs can tell you.
Now assuming that 180oF is the spec'ed thermostat...
Hotter engine temps are usually better for emissions but there is no telling what you could be trading off changing to a hotter thermostat.
You could send your NOX levels through the roof with hotter cylinder temperatures which can create pre-ignition (pinging) problems and cause you to fail a yearly emissions test if you are required to have one.
Now, all those warnings aside if you want to try it and are ok with the risks above, I wouldn't go past a 192oF if your original one is a 180oF
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1525048 - 07/08/09 10:33 AM Re: Should i buy a hotter thermostat? [Re: StevieC]
artificialist Offline
Loc: Florida
Increasing the coolant temp may mean that the ignition timing has to be retarded, so much so that it may hurt MPG rather than help.
You will have to buy more expensive parts such as a performance exhaust to get more MPG.
2010 Lancer Ralliart Sportback
#1528737 - 07/11/09 01:28 PM Re: Should i buy a hotter thermostat? [Re: artificialist]
Gary Allan Offline
Loc: Pottstown, PA
They set it up that way for some reason.
I was trying to verify that this was a traditional outlet thermostat and not some early evolution of the inlet thermostat ..but there does seem to be some oddity to the way they're routing fluid flow. Probably just bypass(heater core) and a sensor port ..but it still looks strange.
housing
http://lube-direct.com/gallan/
#1530050 - 07/12/09 10:30 PM Re: Should i buy a hotter thermostat? [Re: Gary Allan]
SLCraig Offline
Loc: London, ON, Canada
All the Saturnfans people keep saying you HAVE to replace your broken/old thermostats with 195 units (185 was from factory)
I had a 185 in my SL1, and I have a 195 in my SL2.. There is no real difference aside from the gauge reading slightly higher in the SL2. Mileage is good in both cars.
I'd just use the OEM stat unless your mileage sucks (ex. your tstat has failed open)
2010 Civic SI sedan 6MT
Total Quartz 9000 | Wix 7356 | Pennzoil MTF
#1537531 - 07/19/09 10:19 PM Re: Should i buy a hotter thermostat? [Re: SLCraig]
Shaman Offline
Loc: Frankfort, Kentucky
Are you sure that the 180 is the recommended temperature? Seems really weird
#1539668 - 07/21/09 06:57 PM Re: Should i buy a hotter thermostat? [Re: Shaman]
Ken2 Offline
Loc: Washington St.
Install a new thermostat of the original set point. Thermostats do wear out and sometimes get sluggish instead of just failing.
We don't know what hot spots are present inside the engine. GM's engineers might know that and designed that engine to have an average coolant outlet temperature at that safe setting.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#1539690 - 07/21/09 07:23 PM Re: Should i buy a hotter thermostat? [Re: Ken2]
eljefino Offline
Loc: ME
I'm with Ken, it's possible theres some bias you don't know about to make some other part of the engine run at 195 when the rad outlet is at 180.
#1547766 - 07/29/09 09:29 AM Re: Should i buy a hotter thermostat? [Re: eljefino]
unDummy Offline
Loc: RI
Run the 195 thermostat and FIND THAT OE FLAW.
I've played with thermostat temps trying to increase MPG. In the winter, your engine will probably prefer the hotter thermostat. In the summer, you risk failure.
The biggest issue with changing the thermostat is that you need to understand the programming in the ECU. Suddenly the engine is running hotter, and the A/F and timing are not where they should be for MPG, HP, or emissions. You risk throwing all out the window unless you can tune or trick for that thermostat.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#1547851 - 07/29/09 10:46 AM Re: Should i buy a hotter thermostat? [Re: Gary Allan]
moklock Offline
Loc: FL
I agree.
The thermostat is in the inlet pipe that bends down under the oil pan. The water outlet on the head, shown in that picture, is empty on the 2.4L and on last couple of years of the related 2.3L Quad 4.
Another possible theory is perhaps the cooler stat was needed to keep the head temp low enough to still avoid having to fit that engine with an EGR system.
Edited by moklock (07/29/09 10:47 AM)
