Accord door lock issue....
by gregk24
07/31/16 12:26 AM
2000 Corolla vvt-i rattle on startup?
by 55Test
07/30/16 11:24 PM
Brought home a beater today
by exranger06
07/30/16 11:03 PM
Can someone explain to me the nomenclature of ammo
by Vern_in_IL
07/30/16 10:52 PM
Common for bad shift solenoids to shift good warm?
by DemoFly
07/30/16 09:50 PM
Riding mower with non bearing front wheels
by JHZR2
07/30/16 09:17 PM
Mail popup
by Eddie
07/30/16 09:05 PM
Tundra headlight restoration..
by kenwin30
07/30/16 09:00 PM
High mileage and severe service...
by OneEyeJack
07/30/16 08:44 PM
Who uses Quicksilver Multi-purpose oil
by BrocLuno
07/30/16 08:07 PM
Gumout Q&A with Ryan Tuerck - Answers
by wwillson
07/30/16 07:37 PM
Friend Picked Up New 2017 Hyundai Santa Fe Today
by crazyoildude
07/30/16 07:07 PM
danthemann, rodder98, kenb777, Indyfan3, RM53119
58651 Registered Users
22 registered (alcyon, DevilsRule, Chris B., bdcardinal, bamorris2, Blkstanger, 1 invisible), 720 Guests and 5 Spiders online.
58651 Members
66 Forums
252471 Topics
#1541960 - 07/23/09 07:04 PM Super Tech Moly-Lithium Grease
Nick_Escalante Offline
Loc: RI, USA
I'm about to install a bunch of new front end parts, Moog brand, on my car, not a truck, that have zerk grease fittings. So I bought a tube of Super Tech Moly-Lithium grease. ( Extreme Pressure Grease )
Currently I have only Super Tech 'General Purpose' grease in my grease gun, which I relised was the wrong spec for automotive ball-joints, chassis points, bushings, etc...
Product Specs:
Base Type: Lithium 12 Hydroxy Stearate
Color: dark grey
N.I.G.I.: Grade 2
Water Resistance: Excellent
Drop Point: 350 Deg. F Minimum
Timken OK Load: 45 lbs.
Any opinions on this product? thanks.
#1542056 - 07/23/09 08:10 PM Re: Super Tech Moly-Lithium Grease [Re: Nick_Escalante]
Hootbro Offline
Loc: DELAWARE
Does what it says.
Just relabeled Mystik brand grease.
2015 RAM 2500 6.4 HEMI 4x4
2013 FIAT 500
2010 Toyota FJ Cruiser 4x4
#1555873 - 08/06/09 03:16 AM Re: Super Tech Moly-Lithium Grease [Re: Hootbro]
1993_VG30E_GXE Offline
Loc: Ontario, Canada
I've only used this grease on my tools for corrosion protection - it works for that so far, but then so would any.
I think your fine for chassis application. It would be nice to see the service rating though for TEMP - I couldn't find it anywhere on the web for that model.
#1556056 - 08/06/09 09:34 AM Re: Super Tech Moly-Lithium Grease [Re: 1993_VG30E_GXE]
FastSUV Offline
Loc: oklahoma
I am pretty sure it is Sta=lube & not Mystik...besides, wal-mart sells the name-brand Mystik grease but none w/ moly \:\(
'01 Jeep GC 4.0L - 110k (current setup is 6k OCI w/ 10w30 Rotella T5)
'98 Jeep 5.9 Limited - 183k (current setup is 5k/or 1yr OCI w/ 10w30 Rotella T5)
#1588747 - 09/04/09 06:29 AM Re: Super Tech Moly-Lithium Grease [Re: FastSUV]
jhenle Offline
Loc: NH
I need to lube up my car door hinges, since they all started creaking a week or so ago... tried a PTFE spray grease which stopped the creaking for about 2 days only. I have a tube of the Super Tech moly grease, I assume it will do nicely. Any thoughts?
(also, is there a way to temporarily thin this grease out? It's very thick and I'm not sure it can reach inside the hinge if not thinned a bit)
Edited by jhenle (09/04/09 06:40 AM)
#1589161 - 09/04/09 02:13 PM Re: Super Tech Moly-Lithium Grease [Re: jhenle]
Tempest Offline
Loc: Las Vegas NV
You can mix it with some solvent to thin it.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#1589254 - 09/04/09 04:09 PM Re: Super Tech Moly-Lithium Grease [Re: Tempest]
mrsilv04 Offline
Loc: Illinois
I use the SuperTech Moly-Lithium grease on everything... even though it doesn't taste so good on my toast in the morning.
It'll perform well for what you're going to use it to do. I use it on the front end of my pickup... which is used to build houses and is driven across construction sites.
Whatever you do... do NOT speed through the town of Gauley Bridge, WV.
#2893942 - 02/03/13 01:23 PM Re: Super Tech Moly-Lithium Grease [Re: Nick_Escalante]
97K15004WD Offline
Loc: USA
Any Updates?
#2894275 - 02/03/13 04:52 PM Re: Super Tech Moly-Lithium Grease [Re: Nick_Escalante]
shell_user Offline
Loc: U.S.A.
I use it a lot, cant be that bad or horrible, as it gets the job done.
#2894300 - 02/03/13 05:21 PM Re: Super Tech Moly-Lithium Grease [Re: Nick_Escalante]
buck91 Offline
Loc: West Michigan
What's the deal with the lithium hydroxy thickener as opposed to lithium complex? Any compatibility issues?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
1980 Yamaha XS850G
#2894689 - 02/03/13 11:30 PM Re: Super Tech Moly-Lithium Grease [Re: buck91]
Gabe Offline
Loc: Indiana
Here is a grease compatibility chart: LINKY LINK
You should still flush out any old grease before adding a different type - even compatible ones.
#2894950 - 02/04/13 08:32 AM Re: Super Tech Moly-Lithium Grease [Re: Nick_Escalante]
97K15004WD Offline
Loc: USA
Thanks Guys!
