What product was that?
by another Todd
38 minutes 36 seconds ago
choice between reciprocating corded saws
by edwardh1
53 minutes 52 seconds ago
Is the driving experience getting worse?
by fdcg27
Today at 06:24 PM
Scratched wheel
by gabriel9766
Today at 05:52 PM
Gear oil added to motor oil in engine
by TiredTrucker
Today at 05:52 PM
Purolator 10111 Cut Open- Red Can- NEW
by FordBroncoVWJeta
Today at 05:51 PM
A Tesla Model S on auto-pilot was in a fatal crash
by JimPghPA
Today at 05:49 PM
Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (5316Mi)
by DuckRyder
Today at 05:00 PM
By law, do owners have to comply with recall ?
by HTSS_TR
Today at 04:54 PM
Stuck ring?
by TurboFiat124
Today at 04:16 PM
Protectant 303 vs. Wax on fiberglass surfaces
by mbacfp
Today at 03:17 PM
Jeep brakes
by buck91
Today at 03:10 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
98 registered (Blkstanger, anl0109, 01rangerxl, 901Memphis, AMC, another Todd, 11 invisible), 1717 Guests and 7 Spiders online.
58322 Members
66 Forums
251057 Topics
#1535474 - 07/17/09 05:12 PM Best product to stop slipping transmission
HECTOR16 Offline
Loc: PA.
anything better than LUCAS TRANSMISSION FIX for stopping
slipping automatic transmission?
#1535485 - 07/17/09 05:22 PM Re: Best product to stop slipping transmission [Re: HECTOR16]
sciphi Offline
Loc: Upstate NY
A new transmission! Just yanking your chain, you set yourself up for that one!
First off,
Next, you could try draining and re-filling with new fluid. Although it's fading fast since it's already slipping. The Lucas might buy you a few more miles before needing a new transmission.
Besides that, I'm out of ideas.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
#1535487 - 07/17/09 05:22 PM Re: Best product to stop slipping transmission [Re: HECTOR16]
ADFD1 Offline
Loc: CA.
If an AT is slipping and the fluid is at the proper level, repair is knocking at your door. If you want to try an additive try one of the Lube Gard products, but don't count on a fix in a bottle. Don't keep driving it while it is slipping!
A pan drop and filter might help, I would give that a try after I was certain the fluid was at the proper level, and before I add anything hoping to fix it.
AD
AD
US Navy. Helping keep our Country Safe!
#1535489 - 07/17/09 05:24 PM Re: Best product to stop slipping transmission [Re: HECTOR16]
SuperDave456 Offline
Loc: Dallas, Texas
Sorry to tell you this, but Lucas isn't that great of a product.
Personally I would do a few drain and refills with the cheapest fluid I could find to get the Lucas out, then I would Add 8 oz of Auto RX to your Transmission to see what happens.
If you haven't been over there before you need to go check out the Auto-RX site. I have had good results from them.
#1535493 - 07/17/09 05:26 PM Re: Best product to stop slipping transmission for [Re: HECTOR16]
HECTOR16 Offline
Loc: PA.
this is for 1968 mercedes-benz 250 se with 102,000 miles
automatic. going from 3rd pulling it into 4th -even though in 4th gear (as far as the position of shift lever on floor) it goes into neutral. you have to jiggle handle it then goes into 4th.
#1535503 - 07/17/09 05:34 PM Re: Best --continued [Re: HECTOR16]
HECTOR16 Offline
Loc: PA.
should say that this car was driven less than 2000 miles in last 4 years. So even if oil was new 4 years ago. since hardly driven- should everything be drained- including differential.
I am no mechanic -just want to save inherited car from my dad.even before the last 4 years-
Car was rarely driven more than 5 miles one way and then 5 miles back. However, it was up a pretty steep hill in pa.then 8 hours later back down the hill. Just in case that had anything to do with it. I appreciate you folks.(covers gals and guys!)
#1535508 - 07/17/09 05:38 PM Re: Best product to stop slipping transmission for [Re: HECTOR16]
gomes512 Offline
Loc: Chicago, IL
I may not be understanding your description nor have I ever dealt with benz trans. Seems like the gear selector cable may be out of whack.
#1535552 - 07/17/09 06:16 PM Re: Best product to stop slipping transmission for [Re: gomes512]
millerbl00 Offline
Loc: Louisiana
Lubeguard Red. Try one bottle at first. If not better use two. I would change filter and fluid first. I would check gear selector too.
Edited by millerbl00 (07/17/09 06:22 PM)
#1535573 - 07/17/09 06:45 PM Re: Best product to stop slipping transmission for [Re: millerbl00]
pcoxe Offline
Loc: South Carolina
Seafoam makes a transmission tune-up in a can. Isn't supposed to swell up the seals like other additives. It helped me with a governor sticking problem on a 700R4.
#1535720 - 07/17/09 08:29 PM Re: Best product to stop slipping transmission for [Re: pcoxe]
demarpaint Offline
Loc: NY
It could be something to do with the gear selector. As far as a slipping automatic tranny. Check the fluid level first, add if needed. If that doesn't work, drop the pan, replace filter, refill. The only additive I would put in a tranny is Lube Gard Red. If it is slipping bad enough you are not going to fix it with an additive.
God Bless Our Troops
