Lodge Sportsman Grill
by hatt
07/29/16 06:07 PM
2016 Honda Civic factory filter, CUT OPEN
by car51
07/29/16 05:34 PM
Fishing reel drag grease
by bernau
07/29/16 04:26 PM
Sulfated Ash, wt%, ASTM D 874 test questions
by mbacfp
07/29/16 04:02 PM
HD radio
by 007
07/29/16 03:51 PM
Front end repair
by possum328
07/29/16 03:49 PM
Purolator 10111 Red Can
by FordBroncoVWJeta
07/29/16 03:30 PM
Carquest #R85372, 2013 E-250 van, 4,500k
by car51
07/29/16 03:03 PM
Strange failure: Starter AND flywheel cogs ripped
by lars11
07/29/16 02:22 PM
My email from Castrol about Magnatec
by Tech819
07/29/16 02:13 PM
Audi 5000 / Known Stop-Leak Compatible w/ CHF 7.1?
by Miles07PT
07/29/16 01:41 PM
Observations on Workplace corrosion
by Vdubuk
07/29/16 12:15 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
83 registered (aquariuscsm, Alex_V, andrewlg, 2009Edge, anonobomber, Anduril, 6 invisible), 1920 Guests and 6 Spiders online.
58632 Members
66 Forums
252413 Topics
#1518588 - 07/02/09 10:29 AM Dodge Grand Caravan - Coolant Type
coopns Offline
Loc: Scituate MA
Dodge Grand Caravan. What type of coolant should be in there? I dropped by Advance Auto and buddy working there suggested Prestone or Peak...All Makes/All Models (says on it...works with any type of coolant). I said thanks then promptly left.
Coop
#1518621 - 07/02/09 10:50 AM Re: Dodge Grand Caravan - Coolant Type [Re: coopns]
Sayjac Offline
Loc: The Old North State
What year? Late model will be G-05, not sold at AAP, AZ or O'R as far as I know.
Chart here might help, though G-05 would be best option, IMO.
btw, like your screen name. lol
J
Edited by sayjac (07/02/09 10:52 AM)
Edit Reason: added btw
#1518727 - 07/02/09 12:07 PM Re: Dodge Grand Caravan - Coolant Type [Re: Sayjac]
coopns Offline
Loc: Scituate MA
2002 Caravan.
I think it is orange. I can't really see it so I dipped a string down and it came up orangis-ish, must be eh?
So shhould I go with Zerex DEX-COOL? Does it have to be Zerex or as long as it is orange?
Thanks.
Coop
#1518965 - 07/02/09 02:56 PM Re: Dodge Grand Caravan - Coolant Type [Re: coopns]
Dr_No Offline
Loc: Canada
If it is dex-cool it usually has a sticker saying dex-cool, or on your res the cap will say "coolant" ither in green or orange.
#1519595 - 07/03/09 07:09 AM Re: Dodge Grand Caravan - Coolant Type [Re: coopns]
Sayjac Offline
I can't tell you what coolant you have in there now. If it's the original coolant it should say in the owners manual. According to the Zerex chart it should be G-05 in a Chrysler/Dodge 2002.
It doesn't have to be Zerex. And, color is not a great indicator of what type of coolant it is because many brands use different colers for the same thing.
Whatever, if it were me, I'd do a distilled water flush series (several distilled drain and refills), to get the old stuff out. Then go with a concentrated(not50/50) coolant to 50% of system capacity and top off with distilled water.
G-05 though sometimes difficult to find, prolly best bet for you.
#1520367 - 07/03/09 10:17 PM Re: Dodge Grand Caravan - Coolant Type [Re: Sayjac]
01rangerxl Offline
Loc: Birmingham, AL
Your Caravan likely uses G-05, but I don't know for sure. Most Fords were using G-05 by 2002, but I don't know about Chrysler.
If your van does use G-05, find a Napa. They usually stock Zerex G-05. It is about $10-$15 a gallon.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 185K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 180K miles
#1520623 - 07/04/09 07:10 AM Re: Dodge Grand Caravan - Coolant Type [Re: 01rangerxl]
Sayjac Offline
Or you could check the local Chrysler and/or Ford dealer to get their price. On other thread, G-05 was going for 12 bucks at the Ford dealer.
#1520945 - 07/04/09 02:22 PM Re: Dodge Grand Caravan - Coolant Type [Re: Sayjac]
StormRider Offline
Loc: Maryland
Didn't Chrysler use G05 but with a pink dye for some reason? I think they also used Dex-Cool in some of their earlier models (not all of them)
Good luck finding Zerex G05, its pretty scarce and expensive in my area. Also keep in mind Peak Global Lifetime as it may be more available and cheaper, but doesn't have the 2EHA corrosion inhibitor in it...
2009 Ford Escape V6/8400 mi/MC 5W-20
2007 Mercury Montego/50K/MC 5W-20
1976 Chevy K-10/73K/PYB 10W-40
#1523352 - 07/06/09 09:43 PM Re: Dodge Grand Caravan - Coolant Type [Re: StormRider]
artificialist Offline
Loc: Florida
Some Chryslers had orange coolant, but it was G-05 that happened to be dyed that way.
Use G-05 and use nothing else.
2010 Lancer Ralliart Sportback
#1531591 - 07/14/09 09:21 AM Re: Dodge Grand Caravan - Coolant Type [Re: artificialist]
Jase Offline
Loc: Ontario, Canada
I just did a rad flush on my 07 Jeep GC and was worried about going from the redish G05 to the Zerex's yellow. Zerex was easy to find at Walley's but dealership supply was out to lunch, hope I didn't make a mistake.
