ACDelco X66P
by OldEuroCarLover
Today at 12:07 AM
FL910S C&P, 4,000 miles
by cb4017
Today at 12:02 AM
Mobil 1 Full Synthetic $3.99 AR Menards
by John_K
Yesterday at 10:32 PM
Causes of steering wheel shudder
by buck91
Yesterday at 10:14 PM
Brand new Focus ST...
by Striker
Yesterday at 09:55 PM
Chevy Volt bad idea for BITOG members!
by kohnen
Yesterday at 09:22 PM
Looking for oil suggestion Chevy Express 3500 6.0L
by Goofball1205
Yesterday at 08:38 PM
What ATF? 2004 Toyota Sequoia 4WD
by ShadowSix
Yesterday at 08:35 PM
Tundra steering wheel
by RN89
Yesterday at 08:11 PM
98-02 Corolla and Oil Consumption
by mmorri16
Yesterday at 08:10 PM
How does fuel dilution affect HTHS viscosity?
by HKPolice
Yesterday at 07:58 PM
Volkswagen bets big on EV(Electric Vehicle)
by HTSS_TR
Yesterday at 07:50 PM
sledhead1, AtillatheHunk, Goofball1205, Djlmedic, BigHoss256
58926 Registered Users
21 registered (Boomer, Billbert, AnthemBassMan, BlueOvalFitter, Atesz792, 2 invisible), 629 Guests and 35 Spiders online.
58926 Members
66 Forums
253568 Topics
Page 1 of 2 1 2 >
#1513082 - 06/26/09 09:20 PM mmo application
sleepery Offline
Loc: NY
Does anyone use mmo thru the intake like seafoam . Are the cleaning aspects similar between the two to warrant mmo application like seafoam ? Also does using seafoam in the fuel and not in the oil still necessitate an oil change ?
#1513484 - 06/27/09 08:41 AM Re: mmo application [Re: sleepery]
leckbass Offline
Loc: NJ
I havent used MMO like seafoam, i use the seafoam to clean the intake and fuel system, but i use the MMO for maintaince. You dont need to change the oil if adding seafoam to the gas.
I add MMO to my gas all the time, i also add MMO to my oil a few miles before an oil change.
#1513770 - 06/27/09 03:01 PM Re: mmo application [Re: leckbass]
mechtech2 Offline
Loc: Chicago Area
Please don't do it.
Water is good for this application.
#1515526 - 06/29/09 02:15 PM Re: mmo application [Re: mechtech2]
crw Offline
Loc: Pocatello, ID
Aaaaaa.... What was that again?
By the way, Seafoam works great, I don't know about MMO in the intake, and water???? I'm not raising my hand to support that one.
2005 Nissan Maxima, 6-speed manual; many others...
#1515554 - 06/29/09 02:38 PM Re: mmo application [Re: crw]
chevrofreak Offline
Loc: Billings, MT
Water works very well through the intake to clean the combustion chambers. The hotter the water the better.
I <3 Red Line oil
#1515610 - 06/29/09 03:33 PM Re: mmo application [Re: chevrofreak]
demarpaint Offline
Loc: NY
+1 odds are MMO through a vacuum line will throw a smoke cloud that would be beyond belief. It will foul the plugs out too.
God Bless Our Troops
#1515751 - 06/29/09 06:26 PM Re: mmo application [Re: demarpaint]
sleepery Offline
Loc: NY
I have read that water can be misted in thru the carb . Is it better to go thru the pcv with water ? I think I may try seafoam after trying water . I sucked in about 2 oz of liquid wrench thru the pcv this morning no smoke but the rpm's dropped a bit . I have sprayed it in to 3 spark plug holes and will crank it over tomorrow . Is it necessary to pull the other 3 plugs before turning the motor or just disconnect the wires ?
Is seafoam good in the gas tank or just better as a fast clean thru the intake ?
My motor is pretty shot so a little experimenting is more of a hobby at this point .
Thanks for the tips I appreciate it .
#1520618 - 07/04/09 06:48 AM Re: mmo application [Re: sleepery]
sleepery Offline
Loc: NY
I just did a 3 day piston soak with mmo , liquid wrench and atf. . Started the engine and could not believe the smoke . I lost sight of my neighbors house ,no joke . I had to retreat back inside the house because most of their windows were open . I will take it for a spin later when it is dark .
Wind direction was the last thing on my mind when doing this .
Happy 4'th to everyone .
#1520961 - 07/04/09 02:40 PM Re: mmo application [Re: demarpaint]
Falcon_LS Offline
Loc: Kuwait
I actually tried it, out of curiosity, before I changed my plugs. Smoke was enough to have the neighbours rushing in with fire extinguishers. But this is what it looked like after 20 minutes or so of idling: MMO through vacuum lines
The more you rev, the more the smoke. Took about half an hour of driving, with lots of WOT runs, to get rid of it. No ill effects afterwards, but there was no point to it, either.
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: GC 0W40/51372XP
03 Expedition: M1 0W40/51372XP
05 Envoy: GC 0W40/51522XP
#1521067 - 07/04/09 04:44 PM Re: mmo application [Re: Falcon_LS]
mechtech2 Offline
Loc: Chicago Area
Water through the carb or throttle body has a better chance of being equally distributed to each cylinder. Also, water through the carb can kill the engine unless you are really attentive.
But use what you can .
#1521103 - 07/04/09 05:28 PM Re: mmo application [Re: mechtech2]
Gary Allan Offline
Loc: Pottstown, PA
Fish an extended centrally located vacuum line through the cowl into the passenger compartment and do it while driving down the road under load. Use your agent of choice.
http://lube-direct.com/gallan/
#1521154 - 07/04/09 06:38 PM Re: mmo application [Re: Gary Allan]
es350 Offline
Loc: LA
Funny, Gary you do not tell peole to use Amsoil Power Foam. Light years above MMO in the intake...Gee whiz.
"RX is great, the instructions are not"..Sprintman 7-2009
#1521160 - 07/04/09 06:43 PM Re: mmo application [Re: es350]
unDummy Offline
Loc: RI
MMO is too mild to be used that way.
Add it to your fuel.
Use an inverse oiler for eternal low dosage as prevention.
Steam is the best. Seafoam, or something better like injector cleaner, would be great. If its too oily, it'll smoke too much and not clean too well. It needs to be more of a solvent.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#1521285 - 07/04/09 09:55 PM Re: mmo application [Re: unDummy]
wileyE Offline
Loc: Kitsap, WA
Might add any of the outboard motor cleaner to your list, OMC tune -up, quicksilver mecury etc, yamalube ring free, most are far more concentrated than seafoam.
#1521869 - 07/05/09 04:19 PM Re: mmo application [Re: wileyE]
es350 Offline
Loc: LA
seafoam sucks.. I stopped using it years ago
Page 1 of 2 1 2 >
