Irregular transmission leak? -- Toyota RAV4
by 535678
Yesterday at 11:27 PM
First Auto Tranny - Need ATF Recommendation
by wemis
Humming pipes/fixtures
by JHZR2
Yesterday at 11:04 PM
NBA Final
by HTSS_TR
Yesterday at 10:12 PM
Power Steering or Amsoil ATF in 10' Camry P/S?
by rcbc96
Yesterday at 09:47 PM
Finally, a synthetic blend that meets ACEA A5
by tommygunn
Yesterday at 09:45 PM
Following the OLM
by DevilsRule
Yesterday at 09:23 PM
Seattle Blooms
by andrewg
Yesterday at 09:22 PM
Are gas pump auto-shutoff mechanisms consistent?
by Pajamarama
Yesterday at 09:17 PM
Random post-quick rinse pic of Gretchen...
by 97tbird
Yesterday at 09:15 PM
Cost to add on to an existing deck?
by dishdude
Yesterday at 08:38 PM
Wheel Horse Fuel Pump Woes
by dsmith41
Yesterday at 08:15 PM
GreatWhite, Bulletproof, Pete4638, jzzj2v, RushW
45569 Registered Users
45 registered (147_Grain, aquariuscsm, 535678, 1kickbuttranger, 92saturnsl2, 3 invisible), 686 Guests and 234 Spiders online.
45569 Members
64 Forums
193964 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#1482892 - 05/31/09 08:27 PM Grease in bush hog gear box - compatibility.
Von Offline
Loc: Mississippi
Everybody I ask around here uses grease in their bush hog gear boxes along with 90 weight lube.
The reason for the lube is for the bearings - they won't get lubed by the grease.
The reason for the grease is sooner or later you will have a leak, and the whole thing won't burn up if you have some grease until you can get the leak fixed.
Soooooooo, my question is this: are there types/brands of lube and grease that are more compatible?? Nobody has said they had a failure from doing this, but I wonder if there are compatibility issues with the gear lubes and the greases? Or are they just creating a 500 weight lube??
Thanks, Von
#1483709 - 06/01/09 04:05 PM Re: Grease in bush hog gear box - compatibility. [Re: Von]
Steve S Offline
Loc: East of IGO
You are making a thick oil or a thin grease.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1484272 - 06/02/09 05:39 AM Re: Grease in bush hog gear box - compatibility. [Re: Steve S]
fred Offline
Loc: idaho
Amsoil has a 00 grade grease that works good
#1484275 - 06/02/09 05:50 AM Re: Grease in bush hog gear box - compatibility. [Re: fred]
doubleclutch Offline
Loc: Hillsborough, N.C.
I would stay with the manufacturer's recommendation. I have a Taylor Way finish mower, and a King Kutter bush hog, they both recommend 90W gear oil. I am running AMSOIL 85W 140 in the King Kutter though. I had to replace an input shaft seal and I refilled it with what I had on the shelf.
#1484928 - 06/02/09 03:29 PM Re: Grease in bush hog gear box - compatibility. [Re: fred]
Von Offline
Loc: Mississippi
Fred, thanks, I didn't even think about the 00 Amsoil.
In fact, it seems like I saw some non-synthetic 0 or 00 at the coop one time and didn't even think about using it.
Great idea. I just don't know how heavy you can go and still get to the bearings?? All my cutting will be over 60 degrees air temp, and much of it in the 90's. The whole problem is there is no warning if you lose a gasket or have a crack in the box. It can run out with no warning. I've had both happen, but fortunately, they weren't catastrophic. I saw them while taking a break.
Doubleclutch, I always run 85-140 in gear boxes and differentials down here in MS for anything working hard. I left the 90 weight in the 1/2 ton p/u though.
When I was in the Border Patrol in CA, the mechanic that rebuilt the Bronco and Tahoe rear ends used 140W and said it made all the difference. Said they didn't have them come back in with 140, and I've used it ever since in severe service. Don't want to waste the gas in the 1/2T though.
Von
Edited by Von (06/02/09 03:33 PM)
#1485027 - 06/02/09 04:39 PM Re: Grease in bush hog gear box - compatibility. [Re: Von]
Tempest Offline
Loc: Las Vegas NV
Engine assembly lube is usually 0 grease designed to be mixed with oil.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#1485474 - 06/02/09 10:29 PM Re: Grease in bush hog gear box - compatibility. [Re: Tempest]
Von Offline
Loc: Mississippi
Great idea, Tempest. Thanks
Von
