'01 Toyota 3.0: oil to clean up sludge?
by HawkeyeScott
5 minutes 27 seconds ago
What is the purpose of a 4.4 litre oil container?
by vitez
14 minutes 58 seconds ago
Cut Open: Nissan OEM, Bosch D3300 & Mobil M1-110
by davison0976
33 minutes 2 seconds ago
Briggs and stratton flathead?
by pdxglocker9mm
44 minutes 14 seconds ago
Charcoal
by dlundblad
Today at 09:43 PM
2013 Dodge Dart: replace AF on miles or time?
by vitez
Today at 09:20 PM
Rotella T5 10w30 or QSUD 5w30
by GumbyJarvis
Today at 09:04 PM
People running thru red lights. You ever follow th
by motor_oil_madman
Today at 08:30 PM
747-400 versus 747-8
by mjoekingz28
Today at 08:22 PM
14psi bypass pressure for small engines?
by motor_oil_madman
Today at 07:47 PM
'13 Wrangler 2.5" lift
by JXW
Today at 07:37 PM
group 7 v6128 ford 6.7 7k miles
by robo339
Today at 07:34 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
78 registered (2015_PSD, barkingspider, 901Memphis, aquariuscsm, 10 invisible), 1219 Guests and 101 Spiders online.
57779 Members
66 Forums
248434 Topics
Page 1 of 5 1 2 3 4 5 >
#1483035 - 05/31/09 10:24 PM Pros and Cons of Diesel Oil in Gasoline Engine?
lancerplayer Offline
Loc: Cleveland, OH
What are the pros and cons of using diesel oil in a gasoline engine? I know diesel oils has more additives and detergents and such, but is that the only reason?
2009 Honda Accord EX-L V6 (75k miles)
#1483045 - 05/31/09 10:32 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine? [Re: lancerplayer]
pitzel Offline
Loc: Saskatchewan, Canada
Pros: more ZDDP.
Higher initial TBN
Lower cost due to less marketing.
Cons: higher ZDDP (not good if you are a frequent oil changer and have emmissions gear, but probably not an issue if you do extended drains).
Typically only available in heavier viscosities.
May not be readily available.
Change your thinking...not your oil!
#1483202 - 06/01/09 05:13 AM Re: Pros and Cons of Diesel Oil in Gasoline Engine? [Re: pitzel]
Char Baby Offline
Loc: Western NY
May reduce MPG but, not always!
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#1483465 - 06/01/09 11:07 AM Re: Pros and Cons of Diesel Oil in Gasoline Engine? [Re: Char Baby]
addyguy Offline
Loc: Canada
Pro: Thicker, most are 40-weight, even the 30 weights are heavy within the grade - may help consumption.
2003 Mazda Tribute LX V-6, 196,850 miles...DEAD.
MM F1 5W-20 conventional + Bardahl + top-offs.
MM MPH2 filter.
#1483530 - 06/01/09 12:07 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine? [Re: addyguy]
pickled Offline
Loc: The Rocky Mountains
Pros contamination tolerance Cons well sometimes you can only by them by the gallon.
Used gear lube and burnt ATF is all the cologne a real man will ever need!
Too many toys and automotive parts to list...
#1483778 - 06/01/09 05:39 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine? [Re: pickled]
mechtech2 Offline
Loc: Chicago Area
There is a 10-30 available, but that is the thinnest I've heard of.
Normally 15-40 or 5-40.
This is a bit thick for modern cars. Not a big deal in Summer, but cold starts in winter will suffer -flow and drag.
I think if they had a5-20 and 5-30 HD oil, everyone here would consider using it, otherwise.
#1483805 - 06/01/09 06:11 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine? [Re: mechtech2]
wannafbody Offline
Loc: PA
Cons: spark plugs start to glow
engine sounds like rattling cans
blows black smoke
2000 TA WS6
#1483837 - 06/01/09 06:42 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine? [Re: wannafbody]
ARCOgraphite Offline
Loc: N.H, U.S.A.
How about the magnesium additive; that is usually not in PCMO, mosy likely for a good reason. Will that Mg (?) compound cause some issues?
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#1483841 - 06/01/09 06:50 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine [Re: ARCOgraphite]
Ben99GT Offline
Loc: MS
According to Horsepower TV, Rotella will cause engine sludge in a gasoline engine.
2001 F150 Supercrew
1991 Mustang LX notch
1999 Mustang GT
#1483845 - 06/01/09 06:55 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine [Re: ARCOgraphite]
saaber1 Offline
Loc: Pacnw
Castrol syntec 5W40 is loaded with Magnesium. As I remember I saw on the order of 700-900ppm on UOAs.
"when 5W30 is cold, ...the oil is 35 weight (5+30),...20 w 50 starts at 70 and warms up to 50"
- Kyle, auto mechanic & VP Speedline Motorsports, INTL
#1483848 - 06/01/09 06:57 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine [Re: Ben99GT]
saaber1 Offline
Loc: Pacnw
What is horsepower tv? I assume an informercial? What brand are they trying to sell if it is an infomercial?
#1483868 - 06/01/09 07:18 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine [Re: saaber1]
Doug Hillary Online   content
Loc: Airlie Beach Australia
Hi,
saaber1 - "Magnesium" is typically used as a detergent. It is being replaced in some HDEOs by the more expensive "Calcium" products
HDEOs that are not endorsed "mixed fleet" and carry dual petrol/diesel API/ACEA Quality ratings should NOT be used in petrol engines. This especially applies to those with a very high TBN due to their likely SA levels
Regards
Doug
#1483900 - 06/01/09 07:59 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine [Re: Doug Hillary]
FiremarshalRob Offline
Loc: Baton Rouge, LA
What about SAE 30 in an older model vehicle that calls for 5w-30?
I have a tendency to be rather OCD regarding my vehicle maintenance.
2008 Nissan Altima 2.5S
2006 Silverado 5.3L
1996 1.3L Geo Metro
#1483935 - 06/01/09 08:23 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine [Re: Doug Hillary]
IcebergS2000 Offline
Loc: Southeast Texas
Just want to clarify your statement... Are you saying that, if they do not say "mixed fleet", even though they may be SM rated, they should still not be used in a gasoline engine?
The value of life can be measured by how many times your soul has been deeply stirred Soichiro Honda
#1483950 - 06/01/09 08:34 PM Re: Pros and Cons of Diesel Oil in Gasoline Engine [Re: Ben99GT]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
I heard that last weekend... I laughed too!
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
