2002 Camry 2.4 147.5k with 7500mile oci GC 0w30 wi
by Thebuckaman
05/26/16 02:53 PM
Excessive Soot in Diesel Oil
by outoforder
05/26/16 02:20 PM
2006 Scion xB, 1NZ-FE under the valve cover pics.
by MichiganMadMan
05/26/16 02:05 PM
Not sure whats going on with Pep Boys
by Chris142
05/26/16 01:56 PM
In-car footage at the Milwaukee Mile & Autobahn CC
by dparm
05/26/16 01:43 PM
Spark plug tube gaskets
by supton
05/26/16 01:22 PM
IBM System I and 8" Floppy Disks for MDS
by MolaKule
05/26/16 01:20 PM
Replacing cap bolts- bolt strength?
by ford46guy
05/26/16 12:49 PM
What's worse? Walmart or eBay direct from China?
by CharlieBauer
05/26/16 12:30 PM
When did BITOG start?
by camrydriver111
05/26/16 11:56 AM
Equipment/Calibratio
n Tracking
by racer12306
05/26/16 11:55 AM
Microgreen Oil Filter 50% Off Discount Code
by kohnen
05/26/16 11:24 AM
watergate528, iamtheanimal, 1991300sl, Rdyno, Darsahn
57993 Registered Users
93 registered (Bandito440, 2015_PSD, aquariuscsm, 1JZ_E46, 1991300sl, AirgunSavant, 10 invisible), 1847 Guests and 320 Spiders online.
57993 Members
66 Forums
249437 Topics
#1482161 - 05/31/09 12:34 AM Small engine oil filter cross reference resource
mitsuman47 Offline
Loc: East Texas
Hey guys, I'm looking for a cross reference (wix, amsoil, mobil 1 or any other high quality filter) for the oil filter on my 20hp briggs. The briggs filter number is 78-23545-0111. Thanks for the help. I feel as if I've looked everywhere.
'05 Civic 5MT ~322k mi
QSUD, Mobil 1 oil filter, Fram air filter. 10k mi OCI
Honda HRX217 Mobil 1 HM 10w-30 (rescued from negligent previous owner)
#1482274 - 05/31/09 07:18 AM Re: Small engine oil filter cross reference resource [Re: mitsuman47]
daman Offline
Loc: Bad Axe, MI
Did u try a search?? been posted many times..
"Always"....Mobil 1
Current fill: AFE 0w30
#1482391 - 05/31/09 10:21 AM Re: Small engine oil filter cross reference resource [Re: daman]
JTK Offline
Loc: Buffalo, NY
If you can fit the length, any Motorcraft FL400 or x-ref of your choice.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#1482529 - 05/31/09 01:38 PM Re: Small engine oil filter cross reference resource [Re: JTK]
dwendt44 Offline
Loc: Central Wisconsin
The large Fram parts catalog at the local ag mart has/had listings for small engines.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#1482734 - 05/31/09 06:39 PM Re: Small engine oil filter cross reference resour [Re: JTK]
mitsuman47 Offline
Loc: East Texas
Thanks for the help guys. The FL400 is a little too long, but it looks like there are 4 wix filters that match up with it, so I'll get the longest one that will fit. Thanks again.
Edited by mitsuman47 (05/31/09 06:39 PM)
#1482929 - 05/31/09 08:52 PM Re: Small engine oil filter cross reference resour [Re: mitsuman47]
unDummy Offline
Loc: RI
I couldn't stuff the FL400s(ph3600) on my mower. But the smaller ph3614(Toyota 4.7L) filter fit perfectly.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#1483379 - 06/01/09 09:54 AM Re: Small engine oil filter cross reference resource [Re: mitsuman47]
eoghan Offline
Loc: Nebraska
"Briggs/Kohler type" 3/4" X 16 threads 8-11 PSI Bypass Gasket 2.734"OD X2 .430"ID 0.226" thick
Length" Wix Purolator Hastings Kohler B&S Baldwin MotorCraft AC Walmart JD
2.3" 57035 NA LF503 2805001 492932 B7165 NA NA? NA ?
2.7" 51056 L35310 LF302 1205001 492056 B1410 NA PF2210 NA AM125424
3.4" 51348 L10241 LF157 5205002 491056 BT223 FL793 PF53 ST3614 AM101207
4.8" 51516 L20195 LF134 NA NA B243 FL400A PFL400A ST3600 ?
ADD TO LIST
Amsoil
3.4" Ea057
4.8" Ea034
15 microns, low restriction, more capacity, more surface area to cool oil if you have the room for the longer than stock B & S filters.
I use the Amsoils on my JD rider with a B & S 22hp \:\!
your 78-23545-0111 / 112607FF2 briggs crosses out to the wix 57035 2.3" You can use a longer filter if you have the room for it.
WIX makes NAPA Gold and CarQuest Blue filters. (identical except for the paint job)
For a NAPA filter, use the last 4 digits of the Wix#
For a CarQuest filter, replace the first 2 digits of the Wix# with 85.
Example. Wix 51348 becomes CarQuest 85348 or NAPA Gold 1348.
Audaciter beer
Powered by Amsoil & Amsoil accessories!
#1483650 - 06/01/09 02:56 PM Re: Small engine oil filter cross reference resource [Re: eoghan]
mitsuman47 Offline
Loc: East Texas
eoghan, thanks for the table. It's nice to have all of the choices in one place.
Anyone know who makes the briggs filters, or what their performance specs are?
Edited by mitsuman47 (06/01/09 02:58 PM)
#1485217 - 06/02/09 07:35 PM Re: Small engine oil filter cross reference resource [Re: mitsuman47]
Bullet Offline
Loc: New Orleans La
#1487208 - 06/04/09 10:31 AM Re: Small engine oil filter cross reference resource [Re: eoghan]
mitsuman47 Offline
Loc: East Texas
Do you guys think the wix 51215 would also work? It crosses over to the m1-102, I believe. And, it has the same (that I can tell) gasket dimensions, threads and canister diameter.
After looking I can't really tell what the difference is between the wix 51348 and 51215? Little bit of burst pressure and micron rating is a little different. Is there anything else?
#1487567 - 06/04/09 03:00 PM Re: Small engine oil filter cross reference resource [Re: mitsuman47]
RWEST Offline
Loc: Somerset County, PA
Yep, that'll work. You could even get the chrome version - to really dress it up!!!
"even if you're paranoid, they can still be following you" hide
"live so the preacher doesn't have to lie at your funeral" wink
#1487660 - 06/04/09 03:59 PM Re: Small engine oil filter cross reference resource [Re: RWEST]
Pete591 Offline
Loc: Michigan
M-1 102 works on all B&S application very well.
#1487862 - 06/04/09 06:17 PM Re: Small engine oil filter cross reference resour [Re: RWEST]
mitsuman47 Offline
Loc: East Texas
OOOOOOOH!! CHROME!
And yet another reason for my better half to call me an idiot.
Edited by mitsuman47 (06/04/09 06:20 PM)
