Form-A-Funnel
Motorcyclists: Watch out for left hand turners.
by mrsilv04
2 minutes 9 seconds ago
Pennzoil YB $1.79/Quart after MIR (Limit 5)
by akk944
23 minutes 34 seconds ago
Oil recommendations please.
by matt_in_tulsa
Today at 09:50 AM
Multiple quotes
by ChiTDI
Today at 09:30 AM
What's the preferred flavor of weed-trimmer??
by deeter16317
Today at 09:16 AM
September Advance Auto Ad
by tenderloin
Today at 08:34 AM
Brake system bleed now fluid is really dirty
by plrprecision
Today at 07:55 AM
which equation does widman calculator use?
by lipadj46
Today at 07:55 AM
jimo, porvdub, OADGTi, vicious_fishes, MASSMINI
32957 Registered Users
105 registered (87sammy, ARH_0700, addyguy, asamek, akk944, 9 invisible), 495 Guests and 46 Spiders online.
32957 Members
60 Forums
136840 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1474157 - 05/23/09 01:05 AM Amsoil ATL
montero1 Offline
Loc: East Coast
Been waiting for them to come out with a fluid for my Prius (WS), but it says "not for use in CVT or Ford type F". Bummer.
'08 Prius
'08 GL1800
'09 Sentra
'98 Shadow 750
'10 Jeep Rubicon
#1474161 - 05/23/09 01:08 AM Re: Amsoil ATL [Re: montero1]
AzFireGuy79 Offline
Loc: Arizona
WHy is that a bummer dude? Do you have an old ford or a nissan that would require that?
2006 Toyota Tacoma TRD 4.0: Redline 5w-30,Redline D6 ATF,Redline 75w-90
2006 Toyota Camry SE 3.3: Redline 5w-30,Redline D4 ,ATF Bypass, Eclipse NAV
#1474216 - 05/23/09 04:48 AM Re: Amsoil ATL [Re: AzFireGuy79]
Gary Allan Offline
Loc: Pottstown, PA
I think I already know the answer (Pablo may) but I put in a email to technical. I'm behind on my reading.
What it should say (I believe) is: ATL recommended wherever WS is specified EXCEPT when it is specified for a CVT transmission (one statement).
Putting "Not for use in CVT transmission" as a side note while recommending it for (otherwise) all WS applications just ..well, it's ...it's just rude.
http://lube-direct.com/gallan/
#1474285 - 05/23/09 07:45 AM Re: Amsoil ATL [Re: montero1]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
 Quote:
AMSOIL Synthetic Low-Viscosity Automatic
Transmission Fluid is recommended
for automatic transmissions and other applications
requiring DEXRON® VI, MERCON
® LV, SP or Toyota WS.
 Quote:
*Not for use with CVT or Ford Type F applications.
#1474414 - 05/23/09 10:49 AM Re: Amsoil ATL [Re: montero1]
rumple Offline
Loc: USA, NJ
The Prius does not use a CVT in the traditional sense. The gear ratio of the PSD (Power Split Device) of the Prius is fixed and cannot be changed. Instead, the Prius uses it's two electric motor/generators to change the power loading and flow. In many cases the some portion of power from the engine is routed *electrically* around the gears via the electric motor/generators.
There are no clutches or frictional surfaces in the Prius transaxle. There are many cases of many different people over on http://www.priuschat.com using Redline D6, or Dexron VI, and several other fluids with UOA showning good results.
The only negative was a high copper wear metal with Amsoil ATF in the first gen Prius transaxle, which from the factory specs Toyota IV in contrast to WS being spec'd for the 2nd gen Prius. I do not know what is spec'd for the latest (2010+) 3rd gen Prius.
Rumple
#1474465 - 05/23/09 11:47 AM Re: Amsoil ATL [Re: rumple]
Pablo Offline
 Originally Posted By: rumple
The only negative was a high copper wear metal with Amsoil ATF in the first gen Prius transaxle, which from the factory specs Toyota IV......
Can we see the data?
#1474483 - 05/23/09 12:09 PM Re: Amsoil ATL [Re: Pablo]
rumple Offline
Loc: USA, NJ
Here is Bob Wilson's long test page on ATF testing with the 1st gen Prius, and here is a useful graph he put together.
Rumple
#1475049 - 05/24/09 01:03 AM Re: Amsoil ATL [Re: rumple]
montero1 Offline
Loc: East Coast
So, should I use it, or not?
'08 Prius
'08 GL1800
'09 Sentra
'98 Shadow 750
'10 Jeep Rubicon
#1475053 - 05/24/09 01:09 AM Re: Amsoil ATL [Re: montero1]
synman Offline
Loc: canada
probably not.
#1475136 - 05/24/09 07:52 AM Re: Amsoil ATL [Re: montero1]
Pablo Offline
I would say use it with confidence.
We are talking about ATL, not ATF for a WS application, not T-IV.
I think the test above is pretty cool, but inconclusive. It's well known that ester bearing synthetic fluids will hold Cu in solution, plus he had (and reports it as such) Si/abrasive action, not related to the ATF.
