30211 Members
60 Forums
123765 Topics
Max Online: 728 @ 01/04/10 06:48 PM
#1474406 - 05/23/09 10:34 AM
Mobil One 15w50 or rotellaT 5w40
Loc: ny
I have an old Ford 5.8l Winsdor that presently uses Mobil 1 15w50 for oil pressure reasons. Thinking of switching to Rotella T 5w40 for the cold weather starts. Would I see a significant diff. in cold starts between the two at around 5 or 10 degrees f? What about the oil pressure when hot? Thanks
#1474410 - 05/23/09 10:40 AM
Re: Mobil One 15w50 or rotellaT 5w40
[Re: liberty]
Loc: NY
Unfortunately there is only one way to really tell, and the reason I say that is because you mentioned oil pressure reasons. The 5W40 is going to be better for cold starts, and perform like a 40wt oil when hot, in an engine without OP issues there really won't be a whole lot of difference. In an engine with OP issues, the difference can be more noticeable.
GOD Bless our Troops
#1474482 - 05/23/09 12:09 PM
[Re: demarpaint]
Loc: On the deep blue.
Do you have a real oil pressure monitor or a dummy gage?
Signature? Why?
#1474578 - 05/23/09 02:53 PM
[Re: dave1251]
Loc: ny
A real guage. When hot i get 10 lbs at idle and around 25 lbs at 2000 rpm. The max pressure I can get is around 38 lbs no matter how high the rpm. This is with the 15w50.
#1474582 - 05/23/09 02:58 PM
[Re: liberty]
Loc: Hawaii
Consider another option: Castrol Syntec 5W-50.
Now, whut we've got heah is failya to c'mmun'cate.
#1474585 - 05/23/09 03:03 PM
[Re: marco246]
Loc: ny
I heard that it shears very quickly. Is that true?
#1474590 - 05/23/09 03:14 PM
[Re: liberty]
Loc: jupiter, florida
Probably, its castrol...
Ford F-150
#1474806 - 05/23/09 07:32 PM
[Re: peterdes]
Loc: Illinois
FrankN can tell more about this , but doesn't the M1 15-50 flow at a pretty low temp, like -40 or so? Better than some 5-30 dino oils at that temp. Just looked it up. -45 F. http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_10W-30.asp
Edited by tig1 (05/23/09 07:33 PM)
2007 Ford Fusion 46,000 miles M1 5-20EP 2007 Ford Focus 58,000 miles M1 5-30EP 10,000 mile OCI M1 ATF
#1475147 - 05/24/09 08:17 AM
[Re: StevieC]
Loc: ny
I get about 2 or 3psi at idle and maybe a max of 20 psi.
#1475152 - 05/24/09 08:24 AM
[Re: liberty]
Loc: Bad Axe, MI
Sounds like shes needs a new pump, them old v8 fords where like that. new pump and shed be be right back to norm press with a 5w30.
"Always"..Mobil 1
Current fill 0w30 Green Cap
#1475200 - 05/24/09 09:27 AM
[Re: daman]
Loc: ny
I was told the exact opposite by an old time machine shop. He said bad main bearings are the culprit and suggested the heavier oil. I then called an oil pump manf. and they said a pump would not help either. The truck is a 1990 with 81K ORIGINAL MILES.
#1475215 - 05/24/09 09:52 AM
[Re: liberty]
Loc: Bad Axe, MI
I've over the years worked around many of them older fords '84-'90 302's and 351's were all the same like that mileage didn't matter and yes new/tight cam bearings is where there pressure lies but a new pump is easer and more cost effective for old stuff like that,get your self a high volume pump and she'll be like new,trust me.....have been around it being done it does help/cure.
"Always"..Mobil 1
#1475235 - 05/24/09 10:10 AM
[Re: daman]
Loc: ny
Do you reccommend a brand of pump
