Rotella T 10W-30 3729 Miles 2008 Subaru Legacy GT
Sequim, WA
Here's the latest on my Legacy GT. The Rotella is proving to be a solid choice for this engine. The copper is still a bit high, but I suspect that is an interaction between the Rotella chemistry and the big, copper oil cooler. The fuel is a bit high likely because the warm-up for this change was all at idle while I changed the coolant and P/S fluid.
Code:
Report Date 18-MAY-09
Lab Blackstone
Make Subaru
Model Legacy GT
Year 2008
Engine 2.5L Turbo F4
Miles On Veh. 30,016
Oil Brand Shell
Oil Series Rotella T
Oil SAE J300 10W-30
API SX CJ-4/SM
Miles on Oil 3729 ~2 months in service
***Elements***
Aluminum Al 3
Chromium Cr 0
Iron Fe 5
Copper Cu 16
Lead Pb 1
Tin Sn 1
Molybdenum Mo 2
Nickel 0
Manganese Mn 0
Silver Ag 0
Titanium Ti 0
Potassium K 6
Boron B 24
Silicon Si 14
Sodium Na 4
Calcium Ca 2252
Magnesium Mg 8
Phosporus P 1107
Zinc Zn 1501
cST @ 100 C 10.9
SUS @ 210 F 61.3
Flashpoint 375
Fuel % TR
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.3
TBN N/A
Additives None
***Filters used***
Air Filter Subaru OEM
Oil Filter Subaru OEM
Location Reno, NV USA
Ed
Where do you get the Rotella 10w30? Here in Chicagoland I can only find it at Menards (big box hardware, think HD) and that only in the winter.
I pick it up at the local Shell distributor. It doesn't cost any more than GTX, QS, Valvoline, etc. at Kragen/Pep Boys.
Yes, that zinc number looks to be a bit high. This is what I got last time on he same date code batch: P 1245, Zn 1338. I think we are seeing lab errors in the higher numbers. If any of the labs doing these cheap analysis are within 10%, I'd be surprised.
Ed
Nice car, nice oil, nice uoa.
You should change the listed oil filter to: Tokyo Roki, fka OEM.
I presume that "big, copper oil cooler" refers to the oem cooler.
-Dennis
Originally Posted By: addyguy
For CJ-4/SM Rotella, that's a LOT of zinc.
Shouldn't it be around 1100-1200?
x2...nice numbers!!!
