Pennzoil synthetic blend vs full synth
by kenpoed
05/25/13 01:03 PM
PYB stopped my Ticking!
by Realtech214
05/25/13 12:36 PM
Proposed Tesla Ban in North Carolina
by 97prizm
05/25/13 12:21 PM
1991 Indirect injection diesel / no emissions
by polux
05/25/13 11:43 AM
New-to-me 1985 F250 Explorer
by 92saturnsl2
05/25/13 11:35 AM
Honda A01 specs???
by gregk24
05/25/13 11:27 AM
Why doesn't Mobil 1 make a 0-50?
by ARMY_Guy
05/25/13 11:23 AM
replacing battery buick lucerne
by lucerne06
05/25/13 11:19 AM
how to read battery date code
by lucerne06
05/25/13 11:17 AM
Premix water
by supercity
05/25/13 11:05 AM
Uncle died today
by GreeCguy
05/25/13 10:58 AM
Memorial Day
by GROUCHO MARX
05/25/13 10:17 AM
Rick_Kean, patmoetighe, ohbehave, Maritimer, Beezerbob
45559 Registered Users
98 registered (Alex38, 97tbird, ARMY_Guy, aquariuscsm, 95busa, 12 invisible), 1731 Guests and 240 Spiders online.
45559 Members
64 Forums
193934 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 2 1 2 >
#1459590 - 05/10/09 09:05 AM What gear lube in a 97 corolla
VW_TDI_PD Offline
Loc: Chicago, IL
Just bought a 5 speed 97 corolla... What does this trans take from the factory?
#1459618 - 05/10/09 09:42 AM Re: What gear lube in a 97 corolla [Re: VW_TDI_PD]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
The factory fill is 80w-90 AFAIK. GL-4/GL-5.
I would use a good 75W-90 GL-4.
#1459619 - 05/10/09 09:43 AM Re: What gear lube in a 97 corolla [Re: VW_TDI_PD]
simple_gifts Offline
Loc: Middlesex County CT
GL4 according to
http://www.amsoil.com/scripts/runisa.dll?amsoiloaf:index
Many people, including myself, run a 50/50 mix of Redline MTL and MT90.
2003 Echo, >300K, Peak and a white can.
2006 B2300, 73K,ALM
#1459645 - 05/10/09 10:27 AM Re: What gear lube in a 97 corolla [Re: VW_TDI_PD]
Bill in Utah Offline
Loc: UT
I've got a 2005 5 speed Corolla and it really likes the Amsoil 75w-90 gear lube.
I ran the factory lube and it was good. Then Mobil 1 75w-90 and it was [censored] and have the Amsoil in for over 70k so far and its still excellent.
Take care, Bill
#1459658 - 05/10/09 10:50 AM Re: What gear lube in a 97 corolla [Re: Bill in Utah]
bmwtechguy Offline
Loc: South Carolina
Is that the MTG, Bill? And the same lube been in there for 70k miles or have you changed it once?
#1459691 - 05/10/09 11:16 AM Re: What gear lube in a 97 corolla [Re: bmwtechguy]
Drew99GT Offline
Loc: Colorado Springs
Factory fill is 75w-90 GL-5. The manual states 75w-90 GL-4 or GL-5.
I've tried every fluid out there in my 94 Corolla 5 speed, to include synthetic GL-4s and GL-5s. Conventional GL-5 works best.
#1459694 - 05/10/09 11:19 AM Re: What gear lube in a 97 corolla [Re: bmwtechguy]
Loc: UT
I think its the FGR that is in there. (I'm about 80% sure it is not the severe gear lube (I put that in the diffs of the Subaru and had some issues that Pablo fixed)
Same lube for 70k so far. Works excellent below zero and well above 100 degrees.
Bill
#1459878 - 05/10/09 03:01 PM Re: What gear lube in a 97 corolla [Re: Bill in Utah]
VW_TDI_PD Offline
Loc: Chicago, IL
Drew, so a GL-5 is really best? I thought there was an issue wih syncros, and GL-5 yellow metal levels?
I was thinking about redline MTL/MT90 mix, but im curious about why you like the conventional GL5... what brand do you run now? Is it ok in the super cold?
#1459950 - 05/10/09 04:32 PM Re: What gear lube in a 97 corolla [Re: VW_TDI_PD]
unDummy Offline
Loc: RI
Most GL5 gear oils are buffered and don't have issues with manual transmissions. The LSD additives will usually not assist the shift so avoid gear oils equipped with LSD additive.
Redline MT90, Torco RTF, Amsoil MTG, BG, Eneos, Idemitsu, Synlube, Motul, Ford, GM, ..... have gear oils for your manual trannie.
Toyota also recently developed a lifetime fill LV MTF. With Nissan, Kia, Hyundai, GM,....and numerous other automakers switching manuals to thinner 75w85's in place of 80w90 gear oils, I am going to guess that LV MTF is an 85wt, or possible thinner gear oil. A 75w85 GL4 might also be an option.
Those who say it cannot be done, should not interrupt the person doing it.
Your automaker lied!
Is this a spelling/grammar forum or BITOG?
#1460055 - 05/10/09 07:09 PM Re: What gear lube in a 97 corolla [Re: unDummy]
VW_TDI_PD Offline
Loc: Chicago, IL
undummy, I tried MT90 in my 2004 VW golf, and the cold weather performance was totally unacceptable! I switched to MTL and that was great. Im a little skeptical of MTL in a car 12 years old (MTL once started a huge trans leak in a suzuki sidekick, which thichker lube cured instantly), so I think I will first try a MT90/MTL mix. Should make it a 72.5w85 LOL.
#1460137 - 05/10/09 08:32 PM Re: What gear lube in a 97 corolla [Re: VW_TDI_PD]
LT4 Vette Offline
Loc: Jupiter, FL
Are you sure MTL cause the leak ?
#1460492 - 05/11/09 06:11 AM Re: What gear lube in a 97 corolla [Re: LT4 Vette]
VW_TDI_PD Offline
Loc: Chicago, IL
I have heard reports on forums of MTL causing leaks in some cars. I cant be for sure what caused the leak, but I switched out the factory fluid to MTL because of 2nd gear grind and bad cold weather shifting. MTL cured the grinds! A few weeks later, It started leaking bad, pancake sized oil leaks overnight.
So, I switched to some generic castrol gear lube in a drum at a car dealer used for BMWs, and bam, leak totally disappeared. So, all fingers point at MTL. No problems when I used it in my 04 golf, though. PS, I miss my LT4 vette!
#1460530 - 05/11/09 07:08 AM Re: What gear lube in a 97 corolla [Re: VW_TDI_PD]
kr_bitog Offline
Loc: South East Asia
I have tried many trans fluid on my toyota, and so far the amsoil mtg provides the most consistent shift cold and hot. Redline MT-90 sometimes give better shift but sometimes doesn't.
Mobil 1 gives humming noise on fifth gear.
Motul 300 doesn't give smooth shifting.
Redline 75w90 NS give a bit hard mechanical shifting.
There is one time I use some syntehtic with LSD additive (because the dru written with it), it gives the most effortless shifting, howeve after 1000 km high speed driving, the shifting turns terrible.
So seems now comes back to Amsoil as the most popular choice, or try the mixture of MTL and MT-90.
#1469031 - 05/18/09 06:50 PM Re: What gear lube in a 97 corolla [Re: kr_bitog]
VW_TDI_PD Offline
Loc: Chicago, IL
UPDATE, the mix of MTL/MT90 isnt really good... harder/notchier to shift than the stock fluid. I can imagine it will suck in the cold... disappointing, really. I might change to straight MTL before it gets cold. Or see what the toyota dealer offers.
Was the amsoil just as good as the stock fluid?
#1469169 - 05/18/09 08:40 PM Re: What gear lube in a 97 corolla [Re: VW_TDI_PD]
unDummy Offline
Loc: RI
Bleed/adjust the clutch. Lube the shifter.
If you require a 90wt gear oil, and are using a thinner then 90wt MTL/MT90 blend, then obviously it is probably not a fluid issue.
I also wouldn't consider a straight synchromesh fluid(MTL) in place of a transmission that requires a gear oil.
Never seen a leak caused by a fluid. Usually a leak means you have a seal failing. But, a thin synchromesh fluid is also not meant to replace a gear oil.
I've used Redline MT90 in dozens of Nissans/Toyotas/Mazdas...... and never noticed a shift issue during the winter.
How many miles on this transmission? Maintenance history?
Page 1 of 2 1 2 >
