addguy,
Thanks for the additional comments. Let me see if I can clarify where I'm coming from.
Originally Posted By: addyguy
You're right, there are a lot of ways to look at this, and you probably won't damage the engine at this point.
If I thought (or knew) I was going to damage anything, then of course I wouldn't do it .... of course there is always that
slight amount of uncertainty .....
Heheheh ..... yeah .... it's not so much that I'm trying to "prove" anything ... certainly not to anyone on here ..... most that frequent this forum probably have far more experience than I in this area (oil, lubrication, bypass filtration, etc.) ..... I'm sure I wouldn't even know where to start ....
If anything, what I'm trying to prove, or more accurately,
answer for myself, is the following question:
How far can I reasonably go ?
This being done for the long-term, as once I establish the initial baseline, I'll scale back on the UOA's significantly - probably one mid-OCI, and one at the end when I dump and change. Or maybe just one at the end, depending on what I pick for an OCI .... dunno ....
The idea is to push this initial run as far as I can to find the limit ... and then I will likely scale back the OCI to incorporate a margin of safety.
I dunno if I have mentioned here or not but some acquaintances of mine have a bypass setup (OPS-1) on their straight truck (Cat C-15 engine) and they went over 100K miles on their initial OCI ....
on dino oil (not synthetic) .... I suspect that may have been possible due to both the sump size and the amount of make oil they used, although I'm not sure.
Quote:
You've gone 47k on a fill of oil, longer than most do. You've gotten your value out of this oil fill.
Have I ?
Thanks for being so willing to spend my money ....
It's true that based on the OC interval I have achieved so far, I have eliminated 3 to 4 oil changes.
Quote:
You make your living with this truck.
Well .... yes ..... I'm trying to ...
If you were familiar with what is happening with regards to freight, amount of (way, way down) and freight rates (nearing a drop of at least 50% in 18 months since I started with the carrier I'm currently leased on to - most of it in the last three months) .... you might well understand better what my motivation is.
I'm having to run more miles for less money per mile .... and having to deadhead (unpaid) further to get back in the freight lanes or a good spot ..... my carrier used to offer paid empty moves after you had sat 24 hours without getting loaded ..... to move you to a better area (basically it helped cover the cost of fuel) ..... but no more ...... now you can just sit and rot .... because they ain't gonna move ya.
I have seen (smart) people see the writing on the wall early enough and throw in the towel and put their truck up on the block to get out from under it .... and others who weren't so smart have their trucks repo'ed ..... others who were just plain dumb lose the truck and everything else ..... including their homes. It's getting really ugly out here .....
How about this - you go out on the road (I have gone out for as long as three months at a time) and you get .......
one run ...
per week ..... the rest of the time you just sit ... and sit ...... and sit .......
Much (but not all) of our freight is tied to the car companies - of course, you been following what has been happening there .....
All of them traditionally shut down mid-summer for
a couple of weeks to change over the lines for the next model year .... it usually gets pretty slow around that time ....
Chrysler is currently shutdown ...... GM is talking about going down
for 9 weeks this summer .....that's almost two months ..... and all of them did extended shutdowns at the beginning of the year .....
Quote:
Are you really going to gamble that you 'may' be shortening the life of the engine to save roughly $50-60 for new oil?
It ain't just $50 or $60 ..... I run 100K miles or more a year .... it's more like $400 to $500 per year
minimum - oil only ....... figure another 6 to 7 years of life out of the vehicle (maybe more) and you are talking $2500 to $3500 dollars .... dunno about you but that's real money to me .... maybe almost enough for the downpayment on the replacement for this vehicle.
Quote:
I'm not trying to berate you, please understand that.
No worries - I totally get that you are not.
Quote:
But the science of this balancing act is getting over my head, so my argument becomes 'what's the point'?
The point is simply to answer the question I posed above, based solely on factual, objective data and science, and to avoid letting emotions rule the day.
There's plenty of emotion here on BITOG as regards oil, OCI's, etc. - and there's nothing wrong with that whatsoever - alot of it I actually find pretty funny (amusing) ..... the passion and all ......
Some people spend time here as a past time or a hobby ..... my motivation is a little different perhaps than many - I'm doing it as business .... strictly business (although I have to confess I do find monekying around with this stuff quite enjoyable)
I'm determined survive these ugly economic times, and not become a casualty ..... that's why a year ago - when a number of people I know where sitting back with their heads in warm, dark places - I was looking at everything I could do to reduce my operating costs as far as possible ....
Quote:
However, I again defer to Doug Hillary or the lab you were talking to - they're the experts, so if you trust them, keep going.
I evaluate and consider all sources of data and/or opinion - be it you, Doug, or Blackstone - and I take all of it with a greater or lesser degree of salt ...... and try to come to own my conclusions - since ultimately I'm the one that has to make the decision on when to pull the plug and fill the pan ..... or accept responsibility for the consequences if I don't.
