Delo 400?
by Sealbilly
07/25/16 07:17 PM
Noob question about chain maintenance
by JeepWJ19
07/25/16 07:00 PM
Rural King Full Synthetic Oil Sale...
by AnthemBassMan
07/25/16 05:16 PM
Mobil 1 EP oil filter - Cross Reference
by Kung_Faux
07/25/16 05:08 PM
sears SYWR $30 off $30 surprise
by eljefino
07/25/16 05:03 PM
Does BG 44K work?
by j_mac
07/25/16 04:56 PM
First CEL on the SRT-8
by OVERKILL
07/25/16 04:00 PM
How wide are the error bars on Seq IIIG tests?
by bulwnkl
07/25/16 03:15 PM
Who watches the oil co's?
by Camprunner
07/25/16 02:44 PM
Magnetec "Edged" out?
by ARCOgraphite
07/25/16 02:34 PM
Let's talk RUM
by car51
07/25/16 02:23 PM
Any .257 Roberts Reloaders On The Site?
by 2015_PSD
07/25/16 01:18 PM
dewpoint, Luuey, Eskimio, Jngoose76, Ken_Clifton
58593 Registered Users
96 registered (alanwayne1908, aquariuscsm, AIRJAC3, Anakin, 182RG, 8 invisible), 1946 Guests and 16 Spiders online.
58593 Members
66 Forums
252242 Topics
#1448179 - 04/29/09 06:01 AM Larger PH8A version
Shup1 Offline
Loc: West Coast Florida
I looked prior to asking but have not been able to find out if there is a larger (physical sixe) of Fram PH8A, would like to something larger.
2006 Dodge 2500 CTD / 2007 Chrysler 300 / 2009 Mailbu / 93 F-150 (185k miles and no synthetic oil, bypass filter and it still runs)
#1448350 - 04/29/09 10:01 AM Re: Larger PH8A version [Re: Shup1]
Gary Allan Offline
Loc: Pottstown, PA
51776 7" long. There's even one that is fatter but not as long. It's larger in total volume. I forget the number.
http://lube-direct.com/gallan/
#1448360 - 04/29/09 10:14 AM Re: Larger PH8A version [Re: Gary Allan]
Gary Allan Offline
Loc: Pottstown, PA
P550299 (51776/FL299)
P550580 (51189)
P551267 (51641 - probably biggest due to diameter)
P551603 (51459)
P553411 (51411)
P554407 (another 51459)
#1448455 - 04/29/09 11:21 AM Re: Larger PH8A version [Re: Gary Allan]
Shup1 Offline
thanks Gary...I knew you would have it!
#1449885 - 04/30/09 03:09 PM Re: Larger PH8A version [Re: Shup1]
RWEST Offline
Loc: Somerset County, PA
Or, if you want to use Fram, the PH977A. \:\!
"even if you're paranoid, they can still be following you" hide
"live so the preacher doesn't have to lie at your funeral" wink
#1450588 - 05/01/09 07:03 AM Re: Larger PH8A version [Re: RWEST]
Shup1 Offline
ixnay on the ramfa..just used it cause I knew the number of the top of my bald head!
#1452714 - 05/03/09 10:23 AM Re: Larger PH8A version [Re: Shup1]
widman Offline
Loc: Bolivia
I really doubt that capacity is the issue unless you are running 20,000 mile oil changes with a badly tuned engine or cheap oil.
Efficiency is more important if you want to reduce wear. Move to a synthetic like the P169071 which will take out 95% down to 7 microns instead of 20+ microns as in most filters.
Richard's Car Restorations
#1472000 - 05/21/09 11:18 AM Re: Larger PH8A version [Re: widman]
FusilliJerry82 Offline
Loc: Richboro, PA
Gary, do you know if an oversize exists for the Purolator L24651 listed for a 5.0 Ford Explorer?
Edited by FusilliJerry82 (05/21/09 11:18 AM)
2000 Protege 1.6 215k - Mopar Max Pro 10w-30/Mopar Oil Filter
#1472022 - 05/21/09 11:34 AM Re: Larger PH8A version [Re: FusilliJerry82]
ryland Offline
Loc: Portland, OR
I've read that its not good to use an oversized filter because it causes reduced oil pressure, reduced flow, and if you have a faulty adbv it takes longer for the filter to fill up and raise the oil pressure causing your engine to run dry longer. So whats the value of a larger filter?? More filter media area? Better cooling?
#1472074 - 05/21/09 12:10 PM Re: Larger PH8A version [Re: ryland]
dwendt44 Offline
Loc: Central Wisconsin
If you install any filter with out oil in it, it takes 2 seconds to fill.
What you've read is nonsense, no offense intended.
Oil pressure won't change, and flow through the engine won't change either. Flow through the filter will slow slightly, that's good.
A faulty abdv? How often does that happen?
With a good quality oil and filter, even an oversize one, you shouldn't have any worries.
My 2
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#1472093 - 05/21/09 12:26 PM Re: Larger PH8A version [Re: widman]
OVERKILL Online   content
Loc: Ontario, Canada
+1 on the Donaldson.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#1472120 - 05/21/09 12:44 PM Re: Larger PH8A version [Re: FusilliJerry82]
Gary Allan Offline
Loc: Pottstown, PA
Yes and no. This uses the modular thread. You may have an oil cooler that sorta complicates it.
I believe that the 4.0 OCH and 5.0 that use the modular thread actually have the old 3/4-16 thread adapted via the right angle mount (if used) otherwise, it's a stud with 3/4-16 block side threads and 22x1.5mm exterior threads.
It it has a right angle mount w/o oil cooler, then you just get a right angle mount for a Chrokee for a lot less money ($40). If it's got an oil cooler, then the extension bolt for the cooler won't necessarily work depending on if it sits on the block side or the filter end of the right angle adapter.
Otherwise ..the bypass is a touch higher on this Wix offering
Part Number: 51087
UPC Number: 765809510876
Principal Application: Ford European-Dorset Engs.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.477
Outer Diameter Top: 3.661
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 19
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 355
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 24
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
#1472951 - 05/22/09 12:20 AM Re: Larger PH8A version [Re: Gary Allan]
ryland Offline
Loc: Portland, OR
maybe this is what I was thinking about. Oil pressure fluctuation.
http://www.youtube.com/watch?v=xXGi2Aun9h0&feature=related
#1472959 - 05/22/09 12:30 AM Re: Larger PH8A version [Re: ryland]
Gary Allan Offline
Loc: Pottstown, PA
He's talking about bulging the can. Bigger can ..more flex.
Now if you're running one of these engines, I'd say follow this guy's advice. I'm sure that he found out that a bigger element made it harder to cope with.
