Chrome polish for spoke wheels
by gman2304
07/02/16 01:52 AM
'09 Nissan Sentra-Eni i-Sint XL 4AM 5w-30-10k.
by montero1
07/02/16 01:11 AM
Questions about manual transmission sounds
by Why_Anything
07/01/16 11:09 PM
HOW to learn PINSTRIPING & lettering ??
by SumpChump
07/01/16 11:08 PM
'96 Nissan Maxima - Intake R&R - EGR tube bent
by 92saturnsl2
07/01/16 11:00 PM
Anybody want a lot of 6 Carquest Blue 84060?
by CapitalTruck
07/01/16 10:38 PM
new Tundra color
by lawnman
07/01/16 10:36 PM
Bought A Yamaha XSR900 today!
by donnyj08
07/01/16 10:21 PM
Akebono ProACT vs EBC Ultimax "Blackstuff" pads
by slacktide_bitog
07/01/16 10:08 PM
Replace oxygen sensor by mileage ?
by Merkava_4
07/01/16 10:02 PM
I was slightly wrong on the Purolator transition
by slacktide_bitog
07/01/16 09:57 PM
Things your dogs have eaten.....
by OVERKILL
07/01/16 09:45 PM
Aidil, dandandan, dbertheau, Jennyp, dcdodge
58341 Registered Users
27 registered (Blkstanger, chrisri, bdcardinal, 3 invisible), 838 Guests and 13 Spiders online.
58341 Members
66 Forums
251131 Topics
#1439467 - 04/19/09 07:41 PM Life Expectancy of a 2001 GMS Jimmy w/ 4.3 Vortec
LoneRanger Offline
Loc: Midwest
My dad just bought a 2001 GMC Jimmy, it has the 4.3 Vortec V6 and auto trans, 110,000 miles. Appears to have been very well maintained and cared for. Motor sounds very good, no ticks or other noises. Dad's getting older and this is basically just for his around town running around. They have a newer model minivan for trips if necessary.
Will these Jimmy's go to 200K or more with reg maintenance?
'09 Subaru Forester .........(Quaker State Syn Blend 5W30)
'16 Ducati Multistrada DVT 1200S (Spectro Platinum 15W50)
#1439470 - 04/19/09 07:45 PM Re: Life Expectancy of a 2001 GMS Jimmy w/ 4.3 Vortec [Re: LoneRanger]
01rangerxl Offline
Loc: Birmingham, AL
It should be able to go over 200K with good maintenance. I'd go ahead and do a coolant flush and transmission fluid flush.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 185K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 180K miles
#1439485 - 04/19/09 07:54 PM Re: Life Expectancy of a 2001 GMS Jimmy w/ 4.3 Vortec [Re: 01rangerxl]
440Magnum Offline
Loc: Texas
X2 on the coolant flush, and while you're at it give it a good check-out for signs of DexCool damage (heavy deposits in the radiator, coolant leaks, nasty-looking old coolant). If it has those problems, odds are good that an intake gasket job (or worse) is in your future. And if it were mine and even if the old coolant looked flawless, I wouldn't let it NEAR DexCool again, I'd use Zerex, Mopar, or Motorcraft G-05.
Other than that, the 4.3 is about as bulletproof as an old-style (pre-LT1) smallblock Chevy v8 (which it is, minus 2 cylinders).
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#1439486 - 04/19/09 07:55 PM Re: Life Expectancy of a 2001 GMS Jimmy w/ 4.3 Vortec [Re: 01rangerxl]
LoneRanger Offline
Loc: Midwest
Roger that. Coolant flush already done, w/Dexcool (and pellets). Trans flush pending. Probably axle/differential drain and fill as well.
#1439536 - 04/19/09 09:07 PM Re: Life Expectancy of a 2001 GMS Jimmy w/ 4.3 Vortec [Re: 01rangerxl]
daves87rs Offline
Loc: Michigan
+1
Whatever you are, be a good one.
#1439573 - 04/19/09 09:37 PM Re: Life Expectancy of a 2001 GMS Jimmy w/ 4.3 Vortec [Re: daves87rs]
Chris142 Offline
Loc: apple valley, ca
My boss has a 1995 S-10 with a 4.3. Fortunatly for him it's a pre-Dexcool truck
It's going on 290K. The rest of the truck is falling apart but the 4.3L runs as good as new.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#1439616 - 04/19/09 10:34 PM Re: Life Expectancy of a 2001 GMS Jimmy w/ 4.3 Vortec [Re: Chris142]
JTK Offline
Loc: Buffalo, NY
Blazers/Jimmis of that vintage can nickle/dime you with front torsen bar issues, wheel bearing/ABS exciter rings, etc.. Assuming it's 4wd, is it the selectable 2wd/4hi/4low or is it AWD? The AWD transfer cases are kind of an odd-duck (and costly to repair/replace). The regular 4wd are run of the mill. Just excersize it somewhat regularly and make sure not to run the front diff low on gear oil. The 4.3L / 4L60E combo is great. Interiors are horrible rattle squeek traps, but as always, if the price is right, who cares!
Joel
Edited by JTK (04/19/09 10:35 PM)
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#1440523 - 04/20/09 09:00 PM Re: Life Expectancy of a 2001 GMS Jimmy w/ 4.3 Vortec [Re: JTK]
LoneRanger Offline
Loc: Midwest
Its the selectable 4WD. Its my dad's, he got it last week.
#1441126 - 04/21/09 02:13 PM Re: Life Expectancy of a 2001 GMS Jimmy w/ 4.3 Vortec [Re: LoneRanger]
Drew99GT Offline
Loc: Colorado Springs
We've got 225K on a 98 Blazer. It's take A LOT to get to that mileage, but it still runs alright, and it's seen some pretty severe service with some towing at high elevations and tons of rutted out backwoods driving.
It's on it's 3rd tranny and intake gaskets were replaced. Short of that, all the usual maintenance type stuff - brakes, water pump, alternators, shocks, etc.
#1441736 - 04/22/09 09:06 AM Re: Life Expectancy of a 2001 GMS Jimmy w/ 4.3 Vortec [Re: LoneRanger]
JTK Offline
Loc: Buffalo, NY
That's good! Dunno if you Dad is familiar with part time 4x4 systems, but he might want to get in the habit of exercising the system once or twice a month. The electric shift on the fly actuators tend to lock up from moisture/corrosion if you don't. I used to do this on all my 4x4's while rolling down the driveway without the wheels turned, such that you don't excessively load/bind the drivetrain on a dry surface. Working the parking brake from time to time is also a good plan on older vehicles (if it still works!!)
Joel
Edited by JTK (04/22/09 09:07 AM)
#1445111 - 04/25/09 04:26 PM Re: Life Expectancy of a 2001 GMS Jimmy w/ 4.3 Vortec [Re: Chris142]
FXjohn Offline
Loc: NE Indiana
just do a lot of trans drains/fill, now and then 30k's. The motor will last forever.
I'd put in a new cap and rotor, some older ones were prones to moisture problems.
he's right, the engine will outlast the body.
