Avoiding short trips like the plague
by FordCapriDriver
06/25/16 03:11 AM
API CK-4
by JustPlainFolks
06/25/16 02:37 AM
Rotella T
by momo
06/25/16 01:51 AM
3,000 mile OCI/severe service/newspaper delivery?
by Aurora09
06/24/16 11:46 PM
move over esters...time for alkylated napthenes
by Shannow
06/24/16 10:46 PM
ear wax and ear plugs
by motor_oil_madman
06/24/16 09:26 PM
Discount Tire Direct 4th of July Sale
by sopususer
06/24/16 08:37 PM
What kind of oil drain plug gasket is this?
by Chris B.
06/24/16 07:36 PM
by Chris B.
06/24/16 07:34 PM
First time changing oil what to use ?
by sshazam
06/24/16 07:13 PM
toshiba 720p 28" TV hdmi to thinkpad vga cable?
by bmwjohn
06/24/16 06:48 PM
1988 Brougham
by momo
06/24/16 06:38 PM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
18 registered (bbhero, 285south, asand1, ChristianReske, 2 invisible), 527 Guests and 13 Spiders online.
58257 Members
66 Forums
250769 Topics
#1441568 - 04/22/09 01:46 AM How often to grease u-joints
wirelessF Offline
Loc: Oahu, Hawaii
I changed all the non-greaseable u-joints to greseable u-joints in my Tundra and I was wondering what type of grease to use and at what intervals to grease them?
#1441574 - 04/22/09 02:28 AM Re: How often to grease u-joints [Re: wirelessF]
Shannow Online   content
Loc: Oz
My 1990 4Runner specced moly grease at 5,000km (3,000 mile) intervals.
The drilling through the cross shafts make them immensely weaker than no greasable.
Any time you are told that you need to do something "for your own good"...it's usually not good for you
#1441597 - 04/22/09 04:58 AM Re: How often to grease u-joints [Re: Shannow]
demarpaint Offline
Loc: NY
I recently switched to this grease from Amsoil.
Synthetic Heavy-Duty Grease, NLGI #2, GC/LB (GHD)
I was using Mobil 1 red grease, but didn't like how it ran out of the grease gun. I used it for many years w/o problems, but the Amsoil product seems better. Grease applications depend on how the vehicle is used. If it vehicle is used off road, in mud etc, follow Shannow's suggestion. In normal PC use, I grease mine 3 times/year.
God Bless Our Troops
#1441616 - 04/22/09 05:56 AM Re: How often to grease u-joints [Re: demarpaint]
Johnny Offline
Loc: Retired | Wausau, WI
The Amsoil GHD is a very good grease for this application, but under most circumstances, any grease with the GC/LB classification will work just fine.
When I had my Jeep, I greased it every time I changed the oil, which was every 5-6K.
#1441618 - 04/22/09 06:08 AM Re: How often to grease u-joints [Re: Johnny]
Zaedock Offline
Loc: Massachusetts
Anytime you wheel in deep water or mud, you should grease all your u-joints and steering/suspension. If you don't wheel and don't have a lift, then they really don't need too much maintenance. I'd say check'n them or adding a pump or two every 5-6K is good advice.
I use a little tub of Pennzoil EP grease. It was $2 on clearance from WalMart.
2012 F150 Ex-cab 5.0L/2004 Malibu Maxx LT
1992 YJ "The Heep"/1994 Olds Cutlass Ciera 3.1/auto
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#1441665 - 04/22/09 07:47 AM Re: How often to grease u-joints [Re: Zaedock]
mstrjon32 Offline
Loc: Elkridge, MD
I just pulled one of the original u-joints off my Jeep at 170K, and while it was loose, after pulling the caps it still had plenty of grease after all this time. Replaced it with another non-serviceable u-joint, but I think it might already be going bad after just 6K.
#1441897 - 04/22/09 12:04 PM Re: How often to grease u-joints [Re: mstrjon32]
mechtech2 Offline
Loc: Chicago Area
With that Zerk fitting, you now have a hole for the water to get into, or grease to leak out.
But like Zaedok said, rough water conditions [immersion] would make me give them a squirt of grease.
And as long as you have them, the 5,000 mile thing is OK too.
#1442072 - 04/22/09 03:08 PM Re: How often to grease u-joints [Re: mechtech2]
[RT] ProjUltraZ Offline
Loc: Honolulu, HI
the Redline CV grease is good. lots of moly
#1442152 - 04/22/09 04:09 PM Re: How often to grease u-joints [Re: [RT] ProjUltraZ]
wirelessF Offline
Loc: Oahu, Hawaii
 Originally Posted By: [RT
ProjUltraZ]the Redline CV grease is good. lots of moly
I might look into that grease, since they sell them locally.
#1442619 - 04/23/09 12:48 AM Re: How often to grease u-joints [Re: wirelessF]
hal Offline
Loc: NC
mystik red is good grease for this or moly-graph; both might last longer if you're mud'n. or you could just use the yellow stinky stuff.
#1442790 - 04/23/09 07:52 AM Re: How often to grease u-joints [Re: hal]
Kestas Offline
Loc: The Motor City
Keep in mind the logistics of greasing this micromotion application. You don't want to use too thick of a grease. If too thick, it'll get squeezed out instead of flowing back in to the contact area. Kluberplex BEM 34-132 is well-suited for this application. It is an NLGI 1.5 grease made for micro-motion applications, resistant to elevated temperatures and has good washout resistance.
#1443240 - 04/23/09 03:29 PM Re: How often to grease u-joints [Re: Kestas]
PT1 Offline
Loc: near the mistake
My 2008 4Runner has them and interval is 15,000 miles. I use Valvoline durablend moly grease. Toyota doesn't want you using a high moly grease in ujoints and specs lithium based grease. The Valvoline is a lithium based grease with only 1% moly so you get both and it is safe for ujoints as well.
Oils well that ends well...
