33010 Members
60 Forums
137170 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#1428322 - 04/07/09 10:58 PM
Do K&N's make for a louder intake?
Loc: Smitten for the Mitten!
Hey all, just curious about this one. my car has had a k&n on it since i bought it just over a year ago, and the car's intake has always been pretty audible. the actual intake ducts go into the fender and into the bumper so IMO it shouldnt be that loud. would switching to a paper element filter help reduce this noise? i've added aftermarket intakes on other cars before that made the intake noticeably louder, but this car still has the stock intake, just a different filter. i want your thoughts please
Lucas oil stabilizer looks like it belongs on my waffles, not in my engine! :()
#1428326 - 04/07/09 11:01 PM
Re: Do K&N's make for a louder intake?
[Re: Klutch9]
Loc: Oklahoma
This seems to be a common occurrence with most vehicles, but on a lot of the forums where I see posts about intake noise, the guys usually like it.
I'm not fond of K&N intakes due to the oiling of the filter and the subsequent silicon that is sent downstream onto the MAF wires and into the engine.
#1428330 - 04/07/09 11:05 PM
[Re: Reddy45]
keep in mind though that i dont have an aftermarket intake, just the filter. my car also doesn't use a MAF, it has a MAP sensor... but thats unrelated at the moment. the thing does a good job trapping big debris, as any filter should. but i have also become concerned lately that it may not be filtering as well as it should. after this next ARX run im doing synthetic OCI's for 7,500 miles so i want a good filter, not a loud one. yes i know, im 19 and i want my car to be quiet... call me weird
#1428335 - 04/07/09 11:11 PM
[Re: Klutch9]
Loc: Kewaunee WI
YES! The k&n fipk I had on my silverado was so loud when pulling my camper that I removed it and gladly put the stock one back on.
2004 Chevy Silverado 2500HD 6.0 2001 Pontiac Grand Prix 3.1 1996 Ford Escort 1.9 1974 Chevy Monte Carlo 350
#1428343 - 04/07/09 11:17 PM
[Re: Klutch9]
Loc: Oklahoma
keep in mind though that i dont have an aftermarket intake, just the filter. my car also doesn't use a MAF, it has a MAP sensor... but thats unrelated at the moment. the thing does a good job trapping big debris, as any filter should. but i have also become concerned lately that it may not be filtering as well as it should. after this next ARX run im doing synthetic OCI's for 7,500 miles so i want a good filter, not a loud one. yes i know, im 19 and i want my car to be quiet... call me weird Exactly. Folks who have simply dropped a K&N FILTER into their vehicles have experienced increased noise since it is less restrictive. But, are you getting less restriction at the price of more debris being sucked into the engine? UOAs here where the vehicle uses an oiled filter usually show higher levels of Si, as the oils in the filter material do get sucked into the intake manifold.
#1428346 - 04/07/09 11:18 PM
[Re: Klutch9]
Loc: Kansas
Inside the stock airbox, it makes no difference what filter is in there. Paper, K&N, foam, no filter... the intake resonance volume is controlled by all the baffles/chambers built into the stock system. Only when you remove the box and replace it with an open element cone filter and/or associated piping will the intake tone become much more audible.
Any perceived noise you hear from a drop-in K&N is just a placebo effect... it's not flowing that much more.
Edited by zulu (04/07/09 11:19 PM)
2010 Civic 1.8 sedan M/T: QS 5W20; Bosch 3323 2009 Silverado crew 5.3: QS 5W30; Bosch 3334
#1428353 - 04/07/09 11:27 PM
[Re: zulu]
im gonna propose a challenge here... since i've been reading up about the increased levels of silicon in the oil with the k&n air filters, and since wix filters can be bought for so cheap (i like their oil filters and i hear good things about the air filters too), im gonna buy one and drop it in. even if the sound difference is null, i'll at least know the filter is doing its job and doing it well
#1428381 - 04/08/09 12:39 AM
[Re: zulu]
Loc: Northern CA
All air cleaner elements (or no element  )flow within a couple of percent of the same when installed in the same automotive air cleaner box. Any difference in sound comes from the damping and sound absorbing properties of the filter element. If you don't have a well muffled intake, you can hear a difference. Of course, the average factory intake is fairly well muffled.
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
--Mark Twain
#1428462 - 04/08/09 06:23 AM
[Re: XS650]
Loc: North Texas
Any aftermarket cone type filter will make a louder noise for any CAI. I had a AEM intake with a Dryflow filter, way too loud for my liking...sold it to some kid who thought it was pretty cool.
2002 Tacoma 3.4L 111K (as of 05-28-10) Mobil One AFE 0W30
1997 Jetta 2.0L 127K (as of 07-03-10) GC 0W30
#1428580 - 04/08/09 09:22 AM
[Re: XS650]
All air cleaner elements (or no element  )flow within a couple of percent of the same when installed in the same automotive air cleaner box. Any difference in sound comes from the damping and sound absorbing properties of the filter element. If you don't have a well muffled intake, you can hear a difference. Of course, the average factory intake is fairly well muffled. seeing as how my intake only has one intake resonator, and is mainly hard plastic (instead of tubing, there's this huge plastic box that leads into the throttle body), i can see how it would naturally by pretty loud. so im just gonna try swapping in your everyday filter to see if it makes a difference.
#1428723 - 04/08/09 11:31 AM
[Re: Klutch9]
Loc: Balto.
#1428755 - 04/08/09 12:06 PM
[Re: Bamaro]
Loc: SW Michigan
mine is louder because I frankly only have light a foot of intake tract before the IM and that's including the filter. About 50 secs in this video you can hear how loud intake is on startup.. http://videos.streetfire.net/video/Exhaust-Compilation-1995_81348.htm
100 characters ehh?
#1429359 - 04/08/09 09:34 PM
[Re: Buffman]
Loc: North Texas
Pretty cool video. I dig the sheet metal work on that intake.
#1429471 - 04/09/09 12:15 AM
[Re: ARB1977]
Loc: SW Michigan
not my work. place sells those. For a hefty price too. Wish I had that much skillz :)
100 characters ehh?
#1442653 - 04/23/09 02:49 AM
[Re: zulu]
Loc: NC
Any perceived noise you hear from a drop-in K&N is just a placebo effect... it's not flowing that much more. +1 If you really want some intake growl you gotta take off the resonator [censored].
