$1.99 Formula Shell at Menards.
by Topo
4 minutes 21 seconds ago
2012 Ram 3500 6.7 Cummins
by hollnagelc
23 minutes 12 seconds ago
Fleet Farm Havoline $1.59/Mystic $1.99 Qt MMIR
by MDS
42 minutes 39 seconds ago
Lower oil pressure at startup than when warm?
by Cperk
44 minutes 3 seconds ago
Need help on finding oil
by Whimis
Today at 09:34 PM
diesel pump shuts off early
by motor_oil_madman
Today at 09:31 PM
QSUD 5-30, 7688mi, 2.2 Ecotec (04 Saturn Ion)
by MinamiKotaro
Today at 09:31 PM
Cigars , whiskey, and aspirin
by CourierDriver
Today at 09:08 PM
Quake State UD 5w30 SN, 7400 mi, 07 Subaru EJ25
by dsr70
Today at 08:48 PM
Hey golfers
by CourierDriver
Today at 08:41 PM
Follow up first car question
by renegade_987
Today at 08:36 PM
mobil 1/ATF mix for AR lube?
by askoop
Today at 08:08 PM
btbeme, SideSwipe, Eddie2390, b3av3r, 84z90z
45551 Registered Users
106 registered (88m53453, 05LGTLtd, 04SE, 901Memphis, 2004tdigls, 97tbird, 5 invisible), 1204 Guests and 246 Spiders online.
45551 Members
64 Forums
193906 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#1426520 - 04/06/09 12:38 PM Old B&S roto-tiller engine not starting.
nthach Offline
Loc: California
Me and the neighbor are having a bear of a time to get a old B&S 5HP engine on a rototiller to start, I've tried multiple shots of starting fluid with no avail. We changed the original Champion RCJ8 with a NGK CS1(J19LM equivalent), no go. I pull the starter off and I noticed the flywheel was rusty and so was the coil. Should we replace the coil and clean the flywheel with a flap wheel?
The carb's working fine, the plug smelled like fuel.
#1426546 - 04/06/09 01:03 PM Re: Old B&S roto-tiller engine not starting. [Re: nthach]
tom slick Offline
Loc: Central Coast, Calif.
Is it getting spark?
You get what you pay for...
So keep in mind how much you paid for this advice.
#1426592 - 04/06/09 01:46 PM Re: Old B&S roto-tiller engine not starting. [Re: tom slick]
Quest Offline
Loc: beaver land EH?
spark, carb, contact point,etc. all needs attention.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#1426617 - 04/06/09 02:08 PM Re: Old B&S roto-tiller engine not starting. [Re: Quest]
SuperDave456 Offline
Loc: Dallas, Texas
Ive "fixed" neighbors abused equipment with a new sparkplug.
Sometimes it really is that simple.
#1427037 - 04/06/09 09:15 PM Re: Old B&S roto-tiller engine not starting. [Re: SuperDave456]
nthach Offline
Loc: California
No spark. I've gotten the motor stripped down to the flywheel, but I lost 1 BB for the recoil. I need to find my 2-jaw puller to yank the flywheel off.
#1427391 - 04/07/09 08:55 AM Re: Old B&S roto-tiller engine not starting. [Re: nthach]
eoghan Offline
Loc: Nebraska
"flywheel was rusty and so was the coil. Should we replace the coil and clean the flywheel with a flap wheel?"
1st thing is to clean up the flywheel use some fine grit sand paper and clean up the magnets on the flywheel and do the same for the legs on the coil (I would try cleaning before replacing the coil) then change the points as well, that along with the new spark plug should do the trick for the spark. If cleaning the coil does not work then yes replace it.
Once you have spark make sure that you have fuel flow check the carb and lines and filter you may have to address those as well. Especially if it has been neglected and had old fuel left in it.
these small engines are pretty simple if they have spark and fuel then it should start.
Audaciter beer
Powered by Amsoil & Amsoil accessories!
#1430604 - 04/10/09 01:50 AM Re: Old B&S roto-tiller engine not starting. [Re: eoghan]
nthach Offline
Loc: California
Polished the flywheel with medium emery cloth and WD-40 for lubrication.
I'm throwing in a new coil and electronic ignition in this thing.
#1432913 - 04/12/09 10:01 PM Re: Old B&S roto-tiller engine not starting. [Re: nthach]
motorcity Offline
Loc: Michigan
If it has the gas tank attached to the bottom of the carb. These carbs are natorious for clogging up, and may need a re-build.
#1432989 - 04/13/09 12:03 AM Re: Old B&S roto-tiller engine not starting. [Re: motorcity]
nthach Offline
Loc: California
^ it does.
I dropped in a new electronic coil assembly and it did run great but it started to bog down and stall. Do I need any more parts to rebuild the carb?
I'll try a fresh fill of Chevron tomorrow first.
Edited by nthach (04/13/09 12:07 AM)
