Mercon LV or MaxLife
by buck91
Yesterday at 11:46 PM
VW Electric Plans
by Y_K
Yesterday at 10:49 PM
Oil Recommendation for Nissan 3.5 V6 113,000 miles
by BlueSmoke16
Yesterday at 10:10 PM
Sticky Ear Question - Speak Up!
by Ducked
Yesterday at 10:07 PM
House hunting follies
by Jarlaxle
Yesterday at 09:36 PM
Goodbye, Stubby
by Inspecktor
Yesterday at 09:35 PM
Undercarriage
by jay929
Yesterday at 09:31 PM
$1200 Cabela's Gift Card For Sale- Louisville, KY
by FirstNissan
Yesterday at 08:37 PM
Motor oil recommendations, '04 Toyota Sequoia
by ShadowSix
Yesterday at 08:21 PM
Quick Question About Car Battery Quality And Price
by crazyoildude
Yesterday at 07:44 PM
Shelf Life of Gas Stabilizer.
by George7941
Yesterday at 07:34 PM
Got some Leather Seats for the Focus
by Miller88
Yesterday at 06:53 PM
gioburk, turrican, GGilbert, leje0306, DLL
58951 Registered Users
45 registered (1JZ_E46, Bandito440, asiancivicmaniac, bdcardinal, barkingspider, bowlofturtle, 5 invisible), 962 Guests and 9 Spiders online.
58951 Members
66 Forums
253706 Topics
Page 1 of 2 1 2 >
#1412116 - 03/23/09 12:25 PM Why is my muffler glowing red hot.
handyman Offline
Loc: TX
I was able to pick up a second hand small generator. Itís an old Coleman power mate. It has a five horse Briggs and Stratton engine I was surprised when it started right up.
I have two problems that I could see right off hand. (1) After about two minutes the muffler started glowing red hot. Also every now and then sparks fly out of it. It is located right above the gas tank and so Iím worried about that.
(2) The thing vibrates around so much but I donít think that there is too much to do about that.
Any suggestions?
Is it running too rich? Should I get a new muffler?
2011 Prius III 60k
2006 Senna LE 160k
2001 Saturn L140 160k
1993 Corolla LE 150k
#1412119 - 03/23/09 12:28 PM Re: Why is my muffler glowing red hot. [Re: handyman]
lexus114 Offline
Loc: Easton, PA
maybe burning too lean??
2012 Mercedes-Benz C300 4matic
2015 Lexus RX350 AWD
#1412133 - 03/23/09 12:38 PM Re: Why is my muffler glowing red hot. [Re: lexus114]
c3po Offline
Loc: Maryland
You need to get the carburetor adjusted, if it is vibrating then the mixture is probably wrong.
You may have to take the carburetor off and clean it.
#1412144 - 03/23/09 12:48 PM Re: Why is my muffler glowing red hot. [Re: c3po]
pcoxe Offline
Loc: South Carolina
late ignition timing will also cause this. If the engine has a flywheel magneto, the key may have sheared off, allowing the flywheel to shift out of register.
#1412153 - 03/23/09 12:54 PM Re: Why is my muffler glowing red hot. [Re: pcoxe]
handyman Offline
Loc: TX
Wow. Thanks.
Do you think I should just take it to a fix it shop or break out a small engine repair book and work on it myself?
They might be able to fix it in a short time or less while it might take me a few hours.
2011 Prius III 60k
2006 Senna LE 160k
#1412166 - 03/23/09 01:11 PM Re: Why is my muffler glowing red hot. [Re: handyman]
c3po Offline
Loc: Maryland
 Originally Posted By: handyman
Wow. Thanks.
I guess it depends how mechanically inclined you are.
I have cleaned small carbs and adjusted them, that's easy, just do not know about the flywheel key. Maybe someone else on here can walk you through that.
#1412169 - 03/23/09 01:15 PM Re: Why is my muffler glowing red hot. [Re: c3po]
bepperb Offline
Loc: Milwaukee, WI
Hot = lean but late timing is also suspect.
I imagine the carb is pretty dirty, and the jet is not clear enough to provide the full amount of fuel. You won't be able to clean this with additives, you'll probably need to get into the carb. At least remove the bowl and get a feel for how much varnish there is.
The shroud is easy enough to remove, and you can see if the keyhole matches or not for flywheel timing.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#1412170 - 03/23/09 01:16 PM Re: Why is my muffler glowing red hot. [Re: c3po]
Johnny Offline
Loc: Retired | Wausau, WI
You also might was to check the muffler to see if it has a spark arrester screen in it. Sometimes they can get plugged up which causes excess heat to build up in the muffler and it's not letting the exhaust escape like it should. This would also cause sparks and ruff idling.
#1412336 - 03/23/09 03:47 PM Re: Why is my muffler glowing red hot. [Re: Johnny]
browning300wsm Offline
Loc: quebec....canada
[1] your carb is too LEAN open the screw on the bottom of the carb 1/8 of a turn ..
[2]to get at the flywheel key you will have to remove the nut on top of the flywheel ,than u can see if the flywheel key slot is in line with the crankshaft key slot..if they're not in line u need a puller to remove the flywheel and replace the key...
i question my SANITY for purchasing a 3.5 ..5 cyl.
repaired my sanity sold the 3.5 colorado ..got a jeep liberty 3.7
#1412581 - 03/23/09 07:26 PM Re: Why is my muffler glowing red hot. [Re: browning300wsm]
jldcol Offline
Loc: ohio
I would run it without muffler for more than the 2 min. and see if problems still occur, if not new muffler may be the fix. Leanness and late timing are also possible. More likely maintanence issue dirty carb, over carboned head/piston/valves, or junk in gas tank.
Sorry if unclear, I intended to make no sense at all.
#1412589 - 03/23/09 07:33 PM Re: Why is my muffler glowing red hot. [Re: browning300wsm]
Tom_T Offline
Loc: Jacksonville, Fl
Anything it possible but a sheared flywheel key on a generator would be way down on my list. I'd quick-check the muffler then valve clearances and junp on the carb.
#1412650 - 03/23/09 08:48 PM Re: Why is my muffler glowing red hot. [Re: Tom_T]
c3po Offline
Loc: Maryland
I wonder if he has a clogged muffler, kind of like a cat-converter getting hot or glowing when it is hot, just a thought.
#1412664 - 03/23/09 08:56 PM Re: Why is my muffler glowing red hot. [Re: c3po]
JTK Offline
Loc: Buffalo, NY
Yep, on somehting like a 5hp, it's either leaning out for some reason, or it's reving above the RPMs it was originally governed to. As far as vibs? Any flat head single cyl powered generator I've ever seen will shake itself to pieces. I've got a ~6yr/old Coleman Powermate suitcase style 1800 Watt job. It's got a HUGE muffler on it that makes it quiet for an old school Briggs 3.5hp, but even with the rubber isolators, screws loosen and panels fall right off if it's run for hours on end.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#1412678 - 03/23/09 09:04 PM Re: Why is my muffler glowing red hot. [Re: c3po]
SnakeOil Offline
Loc: USA
Run some premium. Premium resists lean conditions a little better. If that doesn't help, do any and everything above.
2001 Ford Taurus LX - 2001 VW Jetta 2.0
2005 Nissan Titan - 2009 Ford F-150
2008 Ford Ranger
#1412829 - 03/24/09 12:40 AM Re: Why is my muffler glowing red hot. [Re: SnakeOil]
punisher Online   content
Loc: snowblind in TX
So.............how is running lean going to create excess heat in the exhaust? Check for loose flywheel/partially sheared key. Sometimes a partially sheared key is tough to spot.
Page 1 of 2 1 2 >
