Wrong Dipstick? Honda Accord 2.4 Reading Low
by ThirdeYe
24 minutes 18 seconds ago
radiator hose install, 08 Matrix.
by JustinH
36 minutes 58 seconds ago
Bendix CT-3 Brake Pads
by RevelationLion
55 minutes 14 seconds ago
Ever Have A Funniest Home Video Moment?
by coopns
Today at 08:20 AM
Parties
by AirgunSavant
Today at 08:02 AM
Static electricity accumulation of earth and human
by yvon_la
Today at 07:26 AM
18.14F this morning....
by Shannow
Today at 06:09 AM
Why it's a bad idea to ignore wheel-bearing noises
by Tegger
Today at 03:29 AM
Water decarbonization, does it work?
by FordCapriDriver
Today at 01:56 AM
Do I need a better tire for PNW trip?
by The_Eric
Yesterday at 11:51 PM
Turtle Beach PC headset hack
by asand1
Yesterday at 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
Yesterday at 11:10 PM
Welder_Repairman, saredX, Corraun, kevinstoyhauler, jimx1169
58022 Registered Users
99 registered (Al, Astro_Guy, AnthemBassMan, 2015_PSD, AirgunSavant, Bandito440, 9 invisible), 1605 Guests and 287 Spiders online.
58022 Members
66 Forums
249591 Topics
Page 1 of 2 1 2 >
#1410648 - 03/21/09 08:20 PM What oil to use in 5.9L Cummins?
jc49 Offline
Loc: westchester county, ny
I have a 2006 dodge ram with the 5.9 cummins. I was using amsoil series 3000 5w-40 but had bad oil reports from blackstone. showing high iron wear and high calcium levels. they recomended to switch to shell rotella oil, and i have had better test results. I would like to run synthetic. I just was wondering what everyone is using in these trucks... thanks
Edited by jc49 (03/21/09 08:26 PM)
#1410678 - 03/21/09 08:49 PM Re: What oil to use in 5.9L Cummins? [Re: jc49]
crazyoildude Offline
Loc: New Jersey
Shell Rotella is a good oil a lot of truckers use it. We use that in some diesels that we rebuild..
#1410754 - 03/21/09 10:19 PM Re: What oil to use in 5.9L Cummins? [Re: crazyoildude]
oilboy123 Offline
Loc: Everett, Washington
You mean the HDD 5w-30? What about the AME 15w-40 Amsoil
“Loyalty to country ALWAYS. Loyalty to government, when it deserves it.”
― Mark Twain
#1410942 - 03/22/09 07:09 AM Re: What oil to use in 5.9L Cummins? [Re: oilboy123]
Johnny Offline
Loc: Retired | Wausau, WI
Synthetics: Rotella T Synthetic 5W-40, Mobil Delvac 1 5W-40, Amsoil AME 15W-40, and Schaeffer's 9000 Series 5W-40. These are some that come to mind, but I'm sure there are more.
#1411028 - 03/22/09 09:20 AM Re: What oil to use in 5.9L Cummins? [Re: Johnny]
jmac Offline
Loc: N. Texas
Valvoline Premium Blue Extreme 5w40, The Cummins oil! is another one.
For the summer you may consider going to one of the brands conventional 15w-40 as well, that engine will not likely notice the difference as indestructible as those tend to be.
#1411081 - 03/22/09 10:16 AM Re: What oil to use in 5.9L Cummins? [Re: jc49]
D-Roc Offline
Loc: quelque part
Any chance you could post the oil reports you mentioned as bad?
#1411304 - 03/22/09 03:16 PM Re: What oil to use in 5.9L Cummins? [Re: D-Roc]
jc49 Offline
not sure how to do it...??
#1411440 - 03/22/09 06:14 PM Re: What oil to use in 5.9L Cummins? [Re: jc49]
trik396 Offline
Loc: USA
Delo, Schaeffers, Mobil 1, Valvoline... my Cummins likes them all.
2005 DodgeRam2500 4x4 CumminsTurboDiesel
617rwhp/1200+trq
2000 Pontiac TransAm WS6 RamAir LS1 with 460/440 RWHP/TQ and M6
#1411484 - 03/22/09 06:52 PM Re: What oil to use in 5.9L Cummins? [Re: jc49]
D-Roc Offline
Loc: quelque part
Many here on the board, including myself just type the wear metals and other readings out as per the UOA
for example:
Fe 19
Al 2
Pb 1
and so on.
#1411835 - 03/23/09 05:24 AM Re: What oil to use in 5.9L Cummins? [Re: D-Roc]
Bambam Offline
Loc: CT
I would love to see the report also.
07 DMAX CC 4x4
265 Goodyears
Bilstein 5100's
T-C pump rub fix
EGR Blocked
PCV rerouted
efi live tuned
Student of dnewton's dino teachings
#1411845 - 03/23/09 05:53 AM Re: What oil to use in 5.9L Cummins? [Re: Bambam]
Steelhead Offline
Loc: Washington
usually, high wear iron in a CTD 5.9 is due to a poor performance air filter not removing the fine particle dirt, ie silicon.
can also be a leak in after filter tube to turbo intake.
will show high silicon also
hard to beat the stock CTD filter for cleaning the intake air and long engine/turbo life. if you've got money to burn, can't beat the Amsoil EAO air filter
sucking in dirt also destroys turbos. early stages of the blades going will show high aluminum from intake turbo impeller ending up in the oil
late stages end up with turbo blades in engine and rods out thru side of block
Edited by Steelhead (03/23/09 05:57 AM)
#1412004 - 03/23/09 10:26 AM Re: What oil to use in 5.9L Cummins? [Re: Steelhead]
RWEST Offline
Loc: Somerset County, PA
"even if you're paranoid, they can still be following you" hide
"live so the preacher doesn't have to lie at your funeral" wink
#1412011 - 03/23/09 10:35 AM Re: What oil to use in 5.9L Cummins? [Re: RWEST]
jc49 Offline
I'm running the Banks Ram air filter, similar to the K&N style filter..
Here are the oil report findings from Blackstone:
JOHN: You switched to a different brand of oil, which shows up in the higher calcium additive. This Amsoil
was in use for 5,500 miles and engine wear increased above universal averages for the Cummins 6 BT.
Some diesels don't do well on synthetics, and yours may be one of them. But another reason for the wear
increase could be anti-freeze, if that's what potassium is. But we think it's more likely potassium is from the
EGR cooler and should improve next time. Change this oil, try going back to Rotella, monitor the coolant
level, and check back in 5K miles.
Diesel
Amsoil Series 3000 5W/30
0 qts
04/11/08
25,288 miles
#1412013 - 03/23/09 10:43 AM Re: What oil to use in 5.9L Cummins? [Re: Bambam]
jc49 Offline
Cummins with 30,979miles
Alum 8 high
Chrom 2
iron 55 high
copper 7
lead 7
tin 0
moly 2
nickel 1
mang 1
silver 3
ti 0
potassium 47 high
boron 7
silicon 5
sodium 5
calcium 3213 hign
magnesium 11
phosphorus 1039
zink 1207
barium 1
this was amsoil ser 3000 5w-40. i now have rotella in with better results
#1412197 - 03/23/09 01:54 PM Re: What oil to use in 5.9L Cummins? [Re: jc49]
1sttruck Offline
Loc: Camas, WA
Isn't Amsoil 3000 a 5w30 ? Kind of thin.
Page 1 of 2 1 2 >
