2002 GMC Yukon Climate Control Problems
by Kgrant
02/06/16 01:11 AM
Vacuum leak after 3800 intake manifold gasket job
by CaliCarLover
02/06/16 12:17 AM
Pops-a-vent fuel can vent
by 901Memphis
02/05/16 11:08 PM
GM Oil Life Update
by CapitalTruck
02/05/16 10:48 PM
Toyota 2.4L & AWD Ok?
by Nick1994
02/05/16 10:40 PM
0W20 in the US but 5W30 outside US for Mazda
by perryg114
02/05/16 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
02/05/16 08:48 PM
why would someone want to pay with a phone?
by turtlevette
02/05/16 08:16 PM
The connection was reset problem
by Triple_Se7en
02/05/16 08:14 PM
BIG PROBLEM!
by Avery4
02/05/16 08:03 PM
11,000 miles on a BMW
by BigJohn
02/05/16 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
02/05/16 07:20 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
30 registered (devarshi84, Abakev, CaliCarLover, chrisri, bbhero, 2 invisible), 463 Guests and 188 Spiders online.
56834 Members
66 Forums
244295 Topics
Page 1 of 3 1 2 3 >
#1396960 - 03/08/09 07:31 PM Only one fluid on the market!
GMorg Offline
Loc: Mizzou-land
The GM recommendation for my AWD Rear Drive Module (RDM) is VersaTrak fluid (P/N 12378514). This is not AutoTrak II fluid. The closest thing to an alternative is RP Synchromax, but I have found mixed reviews as to how well Synchromax works in these RDMs. Even Amsoil does not make a public recommendation for an alternative. (I have seen some online Amsoil rep recommendations, but I cannot verify them as original.)
Does anyone know what makes VersaTrak so darn special. If I knew more about VersaTrak fluid, I might be able to logically consider an alternative. I can't even find an MSDS for the stuff. Does anyone here know what sort of additive strategy is used in this fluid.
#1396981 - 03/08/09 07:47 PM Re: Only one fluid on the market! [Re: GMorg]
Whitewolf Online   content
Loc: MI, USA
Yes. I will try explain tomorrow.
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
#1396986 - 03/08/09 07:51 PM Re: Only one fluid on the market! [Re: Whitewolf]
[email protected] Offline
Loc: Michigan
Strange...over on saturnfans VUE forums, people are regularly using RP without issue.
My parents 2003 VUE AWD had the rear carrier clutch packs disengrate @ 40,000 miles. The think was humming and grumbling. Thank god for extended warranties. I told my Dad that every 15,000 we HAVE to change the rear carrier fluid, no questions asked.
12 Prius
43k miles Toyota 0w20
05 Jeep GC-4.7l
116k miles Edge
97 FW Vista 278
T-4.3Gi 185hrs&
4kw genset 17hrs- T5
#1397277 - 03/09/09 04:25 AM Re: Only one fluid on the market! [Re: [email protected]]
NHHEMI Offline
Loc: NH
RP Synchromax is the only fluid I know of that has successfully been used to replace Versatrak fluid from GM. I have not heard any mixed reviews or horror stories. Just good results. My 08 Chevy Equinox( AWD )called for it in the t-case( rear diff was 75W-90 not the Versatrak ). As big an RP fan as I am, and as many good reviews as I read using Synchromax to replace it, I had reservations using it at the least while under warranty.
Your best bet, to be safe, is to just use the Versatrak fluid. It pretty much is the same situation as the Autotrak II fluid from GM. No real aftermarket replacement specifically for it.
Edited by NHHEMI (03/09/09 04:26 AM)
Proud user of Royal Purple products thumbsup
#1397992 - 03/09/09 07:36 PM Re: Only one fluid on the market! [Re: NHHEMI]
GMorg Offline
Loc: Mizzou-land
I don't know of any horror stories either. But, I do know of two examples of trying Synchromax to remedy the "RDM groan" and it it not working for more than a few months. In both cases, VersaTrak fluid was tried and the groan was held at bay for at least a year. I have read of many people using Synchromax successfully without the groan. I don't personally know any though.
I recognize the my personal sphere is small and that two observations will not prove anything. I would still like to know what makes VersaTrak tick.
#1398693 - 03/10/09 01:25 PM Re: Only one fluid on the market! [Re: GMorg]
ryan2022 Offline
Loc: Calgary
I'm not sure about the original question, but I'll be the first to admit, GM uses some top notch fluids.
Edited by ryan2022 (03/10/09 01:25 PM)
2016 Mazda CX-3 GS Mazda 0w20
2006 Pontiac Vibe Motomaster formula syn 5w30
#1398752 - 03/10/09 02:19 PM Re: Only one fluid on the market! [Re: GMorg]
NHHEMI Offline
Loc: NH
Is this on an older vehicle? Say early to mid 2000's? I read about a lot of issues back then with AWD systems from GM. Poor design and no matter what you did they failed up.
#1398929 - 03/10/09 06:10 PM Re: Only one fluid on the market! [Re: NHHEMI]
GMorg Offline
Loc: Mizzou-land
The vehicle is a 2005 Pontiac Montana SV6. I think that driving style has a lot to do with problem too. There doesn't seem to be many issues with vans that do mostly highway driving. Since the clutches only engage when the wheels are spinning at different speeds, the RDM doesn't get much use while driving in a near straight line or when there isn't much spinning. I think that my problem is that the van was driven primarily on curvy mountain roads until recently. Since I have moved, it has to go though a lot of parking lot maneuvers. I wish that there was a way to disengage the AWD in the warm season.
#1402944 - 03/14/09 11:10 AM Re: Only one fluid on the market! [Re: GMorg]
GMorg Offline
Loc: Mizzou-land
Well, I was a little surprised that I didn't get any input on the additive strategy for VersaTrak. I guess that it is such a low volume product that it doesn't spark much interest. I bought some RP SynchroMax yesterday and I will give it a try when Spring finally comes. If the RDM starts to moan early, I'll let you know.
#1410571 - 03/21/09 07:19 PM Re: Only one fluid on the market! [Re: GMorg]
GMorg Offline
Loc: Mizzou-land
I did a RP Synchromax replacement of the VersaTrak fluid in my RDM - including the recommended 5 minute circles in each direction and rinse. I now have the loudest moan yet! I will give the RP a few days - its quite as long as I don't make slow, deep turns. If it doesn't improve, then I will switch back to VersaTrak at $20 per pint. It's still not a horror story yet, but I am not pleased with RP Synchromax in this application. I am tempted to just throw in some Molybdenum disulfide and loose the rear traction.
#1410602 - 03/21/09 07:42 PM Re: Only one fluid on the market! [Re: GMorg]
benjamming Offline
Loc: northern Alabama
Any UOAs?
#1410622 - 03/21/09 07:58 PM Re: Only one fluid on the market! [Re: benjamming]
GMorg Offline
Loc: Mizzou-land
No, I haven't done a UOA. I was surprised at how clear and clean the VersaTrak looked when I drained it. I have heard that others sometimes see suspended metal in the drained fluid.
#1411003 - 03/22/09 08:50 AM Re: Only one fluid on the market! [Re: GMorg]
NHHEMI Offline
Loc: NH
Are you sure you don't have a problem unrelated to fluid?
#1411282 - 03/22/09 02:47 PM Re: Only one fluid on the market! [Re: NHHEMI]
GMorg Offline
Loc: Mizzou-land
I don't think that I have another problem.
The moan first arose around 25K miles. I went to the dealer. The service department found the TSB and performed the service. They changed fluid, drove for 20 minutes, did 5 minutes of tight circles in each direction, and changed the fluid again. Everything seemed fine. At around 50K (past fall), the moan became noticeable only when hot and only in the tightest turns.
All winter, the groan was gone (still on old VersaTrak fluid). I assume that it never got hot enough to drop the viscosity into the groaning range. In the past month we have had some warm days. The groan was back on the warm days. It wasn't bad, but I thought I should go ahead with the TSB recommendation again - before any issues appeared. After few responses here and nothing really negative anywhere else, I decided to give RP Synchromax a try.
Everything seemed fine with the flush except that the groan was immediately louder with RP. It eventually quietened down with the circles. I replaced the fluid after the exercise and the groan was back and loud. I did a few circles and the groan quietened again. I check the level and topped off. This morning, the groan is back and loud. I did a few circles and the moan was reduced. When I got to my destination, I turned into the parking lot and the sound is back. A few circles later, it is reduced.
I don't have each access to a slick surface to test the AWD and I don't think that we will get much more ice. So, I suppose that the RDM could be stuck in AWD and I would not know. The sound is only present during slow, deep turns. I am beginning to conclude that there is no counterpart to VersaTrak fluid on the market and that RP Synchromax is not an equal substitute.
#1411677 - 03/22/09 10:54 PM Re: Only one fluid on the market! [Re: GMorg]
GMorg Offline
Loc: Mizzou-land
I am headed to the dealership tomorrow for VersaTrak fluid. The weather guessers say that it may rain, so I may be switching fluid in the rain. My RDM groan has become very apparent at nearly every turn. It's still quiet when not turning.
If the RDM goes back to silence with VersaTrak fluid, I will be convince that RP Synchromax it not appropriate for this application! If it stays noisy, I will admit that I still don't know.
Page 1 of 3 1 2 3 >
