Husqvarna XP vs Low Smoke oil
by Buzzsaw
05/01/16 04:20 PM
Looking Equivalent for Synchromesh Part #12345349
by perryg114
05/01/16 03:55 PM
Wife received debt collection letter
by chiefsfan1
05/01/16 03:34 PM
Honda D series and 0w20
by EWPE
05/01/16 02:23 PM
Higher End Mower to recommend to Customers
by yeehaw1960
05/01/16 02:19 PM
Michelin Pilot Super Sport 500+ mile review
by JHZR2
05/01/16 02:15 PM
how much to check out the front end of a vehicle?
by motor_oil_madman
05/01/16 01:42 PM
which tq converter for my 408 stroker?
by tomcat27
05/01/16 01:42 PM
Best 0w-20 oil available on the Danish market
by shDK
05/01/16 01:11 PM
coupons.com $6 off two jugs of VWB
by sir1900
05/01/16 12:45 PM
NAPA Canada - NAPA Syn, Pennzoil HM, Royal Purple
by sir1900
05/01/16 12:32 PM
Wix 57035
by AirgunSavant
05/01/16 12:31 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
83 registered (01rangerxl, 90Notch, andyd, 901Memphis, 2015_PSD, 90crvtec, 7 invisible), 1993 Guests and 313 Spiders online.
57758 Members
66 Forums
248313 Topics
#1394448 - 03/05/09 09:29 PM What is Lucas zddp additive? Saw a bottle at NAPA
ziggy Offline
Loc: stamford, CT
I wa at my local NAPA place today, and talking with a guy thier, he seemed knowledgable about oil, additives, as i talked with him. He showed me a white bottle, black label, form LUCAS. It was an oil additive, he said was a zddp additive. Was good to use for bearings mainly for todays oils. Reading the back of tthe bottle, it was something like a 16 or 24 oz bottle, don't remember, Instructions said to pour the entire contents in, and drive for 1,000 miles, drain the refill with new oil. Didn't mention to use the product agian.
Talking to him, i mentioned i thought too much zinc was bad for the catalyc converter. HE agreed, but thought the lucas bottle was inda overkill.
SO! What is this stuff? What is it good for? HE also mentioned it was mainly for high reving engines, sports cars, racers, things of that nature.
#1394475 - 03/05/09 10:09 PM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: ziggy]
The Critic Offline
Loc: Walnut Creek, CA
Unless you drive a Yugo, you don't need it.
In all seriousness, adding such a large amount of ZDDP to a properly formulated engine oil will upset the additive balance. It is not something that I would consider doing.
11 Prius - 126k - M1 EP 0w20/OE
07 Accord 2.4 - 109k - M1 5w20/FPS Filter
10 Altima 3.5 - 33k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#1394494 - 03/05/09 10:28 PM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: The Critic]
TallPaul Offline
Loc: By Detroit
Well we don't know how large an amount of zddp it is, because we don't have data on this product. It may only have 2000 ppm of zddp, which would raise the crankcase oil by about 200 ppm. OTOH, it might have 10,000 ppm, in which case it is a great product, but wasteful to drain out after 1000 miles, and would only need a third or half bottle to dope your oil.
The masses, thirsting for convenience, unwittingly dig the grave of the automobile as we knew it. The industry already has one foot in that grave.
#1394551 - 03/05/09 11:42 PM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: ziggy]
postjeeprcr Offline
Loc: USA
It is an Engine Break In Additive, you add it to a rebuilt engine to help protect it when you first run it.
Here is a pic of the bottle and a link to the MSDS.
http://www.lucasoil.com/images/medialibrary/0DC0102E823EA69DA07DAA93244AA1F2.pdf
If I agreed with you, we'd both be wrong.
#1394565 - 03/06/09 12:10 AM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: postjeeprcr]
daves66nova Offline
Loc: los angeles
would this be good to add to man. trans oil?
THIS SPACE FOR RENT, PLEASE PM ME.
#1394567 - 03/06/09 12:16 AM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: daves66nova]
Hethaerto Offline
Loc: Tennessee, USA
Put this in your manual trans oil and your diff oil.
Works like magic and lasts a very long time. It makes your shifter work silky smooth, and in cars with very old fluids in there, putting in fresh syn gear oil with this product can make it feel like you took 500 lbs out of the trunk.
Tufoil
I like it cheep.
#1394683 - 03/06/09 07:41 AM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: Hethaerto]
TallPaul Offline
Loc: By Detroit
Thanks for the link postjeeprcr. MSDS suggests major zddp concentration. Need a VOA. This may be a killer additive where only a couple ounces per oil change are needed.
#1395043 - 03/06/09 03:40 PM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: TallPaul]
MolaKule Offline
Loc: Iowegia - USA
Tufoil is a Teflon additive and Teflon has never been shown to reduce or modify friction is colloidal form. In some cases it does quiet gear boxes but as a sound deadener.
I can see the Lucas additive being used for run-in, but with any ZDDP booster for other than run-in applicaions, how are you going to determine how much of this OTC additive should be added without testing?
Edited by MolaKule (03/06/09 03:41 PM)
Some days I amaze myself. The other days I leave the keys in the Refrigerator. smile
#1395132 - 03/06/09 05:47 PM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: MolaKule]
TallPaul Offline
Loc: By Detroit
Yep, got to test or call Lucas and see if they will give you the ppms for zinc and phos and whatever other adds.
#1395482 - 03/07/09 02:55 AM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: TallPaul]
postjeeprcr Offline
Loc: USA
Your welcome, I have a product sheet for it but I can't remember where I got it from and I did not see it on their website. If anyone wants to see it, PM me and I can email it to you.
#1396625 - 03/08/09 12:40 PM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: postjeeprcr]
klingon20 Offline
Loc: california
Never used it but is does seem interesting
#1397321 - 03/09/09 07:34 AM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: postjeeprcr]
TallPaul Offline
Loc: By Detroit
 Originally Posted By: postjeeprcr
I have a product sheet for it ...
Thanks, I got the product sheet you sent. It says it's called Lucas TB Zinc-Plus. It does not give z and p levels, but does say "addition of 16 oz to 4.5 qts motor oil will achieve approximately 5000 ppm zinc." Woah! I once ran 2000 ppm zinc in my F150 and there is question of whether at that level, but surely higher, you would get corrosion of the metal or some type of damaging effect. But 5000 ppm in the crankcase figures to the 16 ounce bottle having about 40,000 ppm zinc.! Even Bruce381's PCMO additive is only around 20,000 ppm zinc.
Then the sheet says "Add one bottle with every oil change to increase the zinc content of your motor oil." I can't believe they would say this if it is 40,000 ppm zinc. It does say not for passenger car use.
If it really has that much zinc, then one ounce should treat the whole crankcase to boost zinc by 250 ppm. This is great stuff, but I would want a VOA to confirm those zinc levels and to see what other stuff might be in it.
BTW, sheet also says 13.5 cst, so easy pour. But Bruce's 20,000 ppm stuff is pretty thick like maybe a 70 wt or molasses.
#1397850 - 03/09/09 04:54 PM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: TallPaul]
Ken2 Offline
Loc: Washington St.
Why? Exactly what is inadequate with any modern engine oil in any modern stock engine that this product will help?
Save your money. If you want better oil, buy better oil. Don't try to home-brew.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#1397911 - 03/09/09 06:13 PM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: Ken2]
azsynthetic Offline
Loc: Phoenix AZ
There is no over the counter oil that you can buy that has 2000ppm zinc. Do I need that much zinc in my engine? Probably not but I would like to overkill on the additive than not having enough. I am currently using Redline race oil as a supplement to all of my oils to boost moly, zinc, and P.
#3159445 - 10/17/13 10:31 PM Re: What is Lucas zddp additive? Saw a bottle at NAPA [Re: TallPaul]
dixon700 Offline
Loc: pa
I believe higher than my 1100ppm of zinc in my delvac would help in a high performance diesel application like mine. There is a lot of guys running higher hp diesels that add zinc. Im not sure if it's needed, but that's why I'm here to learn.
04.5ram CTD lots of parts delvac15w-40 just delvac next time Donaldson elf7349 02 elantra gt castrol edge10w-30 oem filter
