45500 Members
64 Forums
193741 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#1389415 - 03/01/09 02:17 PM
SP111 TRANSMISSION OIL
Loc: new jersey
ARE THERE ANY TRANSMISSION FLUIDS COMPATIBLE WITH hYUNDAI" SP111 TRANSMISSION FLUID? IF YOU DO A LOT OF HIGHWAY DRIVING HOW OFTEN SHOULD TRANSMISSION FLUID BE CHANGED?
#1389464 - 03/01/09 03:31 PM
Re: SP111 TRANSMISSION OIL
[Re: ramp1950]
Loc: Central Coast, Calif.
30k drain and fill or 60k complete flush/exchange seems to be the consensus around here. Every ATF manufacturer seems to make a SPIII compatable fluid. look at multi-vehicle fluids which are often MERCONV.
You get what you pay for... So keep in mind how much you paid for this advice.
#1389737 - 03/01/09 08:22 PM
[Re: tom slick]
Loc: new jersey
castrol import multi vehicle transmission fluid says it is recommended for vehicles using SP111 transmission fluid has anybody used it as a replacement?
#1389806 - 03/01/09 09:13 PM
[Re: ramp1950]
Loc: Milwaukee, WI. USA
I know, I'm new here too but from what I have seen, looked for, and discussed regarding Mitsubishi/Hyundai SP III (not SP111) both fluids are the same, and this topic has already been discussed. Please refer to my posts, or do a search on this topic before posting!
Just providing sound advice.
#1389818 - 03/01/09 09:34 PM
[Re: ramp1950]
Loc: Ontario, Canada
Also depends on what you are looking to spend. Some people on this board are running Amsoil ATF in their Hyundai. How much is SPIII from the dealer?
#1389890 - 03/01/09 11:23 PM
[Re: adamg]
Loc: Bay Area, CA
Under normal driving, the fluid does not need to be FLUSHED until seven years or 105,000 miles, whichever comes first.
AMSOIL ATF, Castrol Import Multi-Vehicle ATF and Valvoline Maxlife ATF are all multi-vehicle fluids that claim SP-III compatibility but are not OEM approved.
Also, you should also be aware that Hyundai uses a chemical tracer in the SP-III fluid. In the event that the transmission fails, a fluid sample is taken and if the fluid is not SP-III, you'll be facing an uphill battle.
You might want to wait until you are out of warranty (the fluid change isn't due until 105k) before switching to a non-OE fluid. The fluid may turn brown, but that's normal according to Hyundai.
Cheap tires are a false economy.
#1390040 - 03/02/09 07:18 AM
[Re: The Critic]
Loc: new jersey
you have all been helpful thank you for your comments and corrections on SPIII transmission fluid . The latest price on the fluid a quart from the dealer is $8.50.
