Just flushed 14 quarts of Redline D6 through my 06 Tacoma tonight. Its very annoying how you have to use a pump to get fluid into this trans and then you have to use a jumper wire on the OBD-II port to assure the level in the trans is correct in relationship to temp.
I took it for a ten minute drive and it shifts very nicely indeed! Im planning on installing a trans by-pass filter this week. The WS had 30K on it and still looked very red and smelled fine. Not what I am use to with other fluids. We will see how it holds up.
