2015 silverado dealer oil change
by Realtech214
02/09/16 08:27 PM
delo 400 $17/gallon at walmart now?
by motor_oil_madman
02/09/16 08:23 PM
Looks like Classics are going bye,bye at WM
by chainblu
02/09/16 08:18 PM
acdelco ph64
by gabriel9766
02/09/16 08:11 PM
Using USED oil as a top off?
by Vern_in_IL
02/09/16 07:57 PM
Question-Buying from a rental agency
by powayroger
02/09/16 07:31 PM
2010 G37xS Schaeffer's 5W30 6,800 miles, 102K
by nighamreuki
02/09/16 07:20 PM
TYC Cabin Air Filters
by DrRoughneck
02/09/16 07:19 PM
Time to vent...shop damaged wheel...again!
by gregk24
02/09/16 07:07 PM
Wooden Box Retirement Gift
by doitmyself
02/09/16 07:03 PM
PL30001 Cut open
by Dyusik
02/09/16 06:47 PM
Founder of BlackStone Labs passes away
by JetStar
02/09/16 06:10 PM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
112 registered (69GTX, 04SE, 97f150, AlienBug, AandPDan, AEHaas, 9 invisible), 1525 Guests and 222 Spiders online.
56865 Members
66 Forums
244468 Topics
Page 1 of 2 1 2 >
#1362400 - 02/04/09 01:36 PM Lucas Gas Treatment Mileage
c3po Offline
Loc: Maryland
I have been using about 4-5 ounces of Lucas Gas Treatment when I go to gas up. I may be adding too much since each time I fill up I am only putting in 14 gallons of gasoline.
I ran a tank with the Lucas Gas Treatment and got 22 m.p.g.
I ran a tank without the Lucas and got 23.42 m.p.g.
I am thinking that my mileage drop is because I have added too much Lucas Gas Treatment. How much Lucas Gas Treatment should I add to 14 gallons of fuel.
Is it better to use this product every tank or every other tank as a maintenance dose.
The vehicle is a 2004 Mercury Marauder with 28,000 miles on it.
Any thoughts or advice would be appreciated.
#1362405 - 02/04/09 01:39 PM Re: Lucas Gas Treatment Mileage [Re: c3po]
wavinwayne Offline
Loc: North Alabama
I've been adding approx. the same amount, and have been trying to convince myself that my MPG drop was due to other things. I'll cut back on the amount of Lucas on my next fill-up, and see if that helps. I don't have the info in front of me, but it seems like 3 oz. is about the right amount for a 14 gallon tank.
Silence is golden, but duct tape is silver.
#1362424 - 02/04/09 01:50 PM Re: Lucas Gas Treatment Mileage [Re: wavinwayne]
c3po Offline
Loc: Maryland
I see you are not the only 1 with this issue, but the car seems to be running great so maybe I will try the 3 ounces.
#1362478 - 02/04/09 02:34 PM Re: Lucas Gas Treatment Mileage [Re: c3po]
demarpaint Offline
Loc: NY
I tried the Lucas using the same dose as MMO 4oz/ 10 gallons of gas. I found the MMO worked better, I also cut/increased the Lucas dose and still found MMO to be better. OD'ing with any of these fuel adds will cut power and MPG. IMO for the money MMO is a better value than the Lucas when adding to gas.
The problem this time of the year is the colder temps, it can really throw things off as far as MPG go.
Edited by demarpaint (02/04/09 02:36 PM)
God Bless Our Troops
#1362575 - 02/04/09 03:59 PM Re: Lucas Gas Treatment Mileage [Re: demarpaint]
chevrofreak Offline
Loc: Billings, MT
I had the best results in my Crown Vic at 2 ounces per 10 gallons.
I <3 Red Line oil
#1362588 - 02/04/09 04:12 PM Re: Lucas Gas Treatment Mileage [Re: chevrofreak]
panthermike Offline
Loc: Phoenix, AZ
I tried Lucas in my brother's Lancer at the recommended dose and it only got around 23mpg over a few tanks(usually gets 27-29).
It seems like some cars like it and some don't, as far as mileage is concerned.
'14 Camaro ZL1; M1/ 9K
'15 Lincoln MKC; PP 5w30 17K
'77 F250 "Ol Yeller"; Kendall GT1 20w50/Mos2
#1362597 - 02/04/09 04:18 PM Re: Lucas Gas Treatment Mileage [Re: chevrofreak]
c3po Offline
Loc: Maryland
I have a Marauder which is basically a Ford product like your Crown Vic, if you say 2 ounces per 10 gallons, then maybe I will do 2.5 ounces per 14 gallons.
#1363063 - 02/04/09 09:50 PM Re: Lucas Gas Treatment Mileage [Re: c3po]
rg200amp Offline
Loc: Phila,PA
When you use UCLs they are not really conbustable. So in theory you are "diluteing" the petrol.
If your going to use it full time, I would not exceed the bottles instructions. I would even be inclined to cut the recommended dosage in half.
// 2013 Subaru WRX //
SOLD:
-11 Volkswagen Jetta
-04 Lincoln LS
-01 Ford F250
-04 Mazda Rx-8
-97 Jeep Wrangler
-97 BMW M3
-97 Nissan Maxima
#1363859 - 02/05/09 05:01 PM Re: Lucas Gas Treatment Mileage [Re: rg200amp]
crw Offline
Loc: Pocatello, ID
This time of year it's really hard to go by anything when looking at MPG. I'm down more than 10% from normal weather conditions. I had a new theory about this... and that is, since it takes the engine so much more time to warm up, that warm up time is extended, and the engine must use more fuel during this warm up time.
I gave all my cars to my kids...
#1364589 - 02/06/09 09:35 AM Re: Lucas Gas Treatment Mileage [Re: c3po]
ARB1977 Offline
Loc: North Texas
3oz per 10 gallons...4oz will put you in the ballpark. I would try FP60 Plus, yea its more expensive but you use half as much. Which in turn saves alittle money in the end.
2002 Tacoma 3.4L 175K (as of 09-24-15)
M1 HM 5W30 / Toyota filter
2008 CRV 2.4L 138K (as of 12-06-15)
PP 0W20 / Fram Ultra filter
#1364592 - 02/06/09 09:40 AM Re: Lucas Gas Treatment Mileage [Re: ARB1977]
wavinwayne Offline
Loc: North Alabama
I just filled up with Exxon 93 octane (10% ethanol) in my GTI. This time I did not add Lucas. On my previous fill-up (Exxon 93 octane NO ethanol) I got 26.5 mpg, using 4 oz. of Lucas UCL. It will be interesting to see if there is any difference in mpg with this tank.
#1364803 - 02/06/09 01:33 PM Re: Lucas Gas Treatment Mileage [Re: wavinwayne]
c3po Offline
Loc: Maryland
The next time I fill up I will be adding only say 3 ounces to 14 gallons of gas, if the mileage is down after this then I may either just use the Lucas in the summer or try MMO instead.
Maybe the Lucas gets thick in this cold weather, I will see how what the lower dose does for gas mileage.
#1371358 - 02/12/09 06:54 AM Re: Lucas Gas Treatment Mileage [Re: wavinwayne]
wavinwayne Offline
Loc: North Alabama
Results are in. I just completed a 390 mile run on a tank of Exxon 93 Octane (10% Ethanol). I managed to squeeze 28.9 mpg from this tank. I'm not sure if any conclusion can be drawn from my experience, since I drove slower on this most recent tank of fuel, and did not exceed 65 mph on the highway. The weather has also been considerably warmer this week than it was for the tank where I only got 26.5 mpg.
#1371390 - 02/12/09 07:39 AM Re: Lucas Gas Treatment Mileage [Re: wavinwayne]
c3po Offline
Loc: Maryland
I will be filling up my tank today, the previous tank had the Lucas in it, I am doing a maintenance dose every other tank.
I think I will be cutting my dosage in half, or if the mileage drop keeps up with Lucas I may have to use MMO in the winter and use the Lucas in the summer since the stuff is thick.
#1371671 - 02/12/09 12:50 PM Re: Lucas Gas Treatment Mileage [Re: c3po]
c3po Offline
Loc: Maryland
My gas mileage was the same, 23 m.p.g. I was putting in the Lucas every other tank, today when I gassed up I decided to put 3 ounces in, I will see what happens.
It is either 4 ounces every other tank, or maybe 3 ounces every tank. I will check the mileage on the next tank and if it is lower then I may use this Lucas every other tank.
Page 1 of 2 1 2 >
