Stop AIM at start up
Thankx. That worked.
No if I could just get rid of this screen each time at start up.
YSearchSuggest.dll
When the computer starts up this window comes up with [SEARCH]in the left top bar.
The address bar is : C:\Program Files\Yahoo!\Search
Inside of this screen is the following.
uninst_iess.exe
YSearchSuggest.dll
2007.2.23.1
Search Suggest
I would uninstall the "Yahoo Search" and/or instant messenger program. Then reboot and reinstall and that should fix your problem.
YSearchSuggest.dll
Try:
Left click start> run> type msconfig> startup> this will list all startup programs, see something you don't want, check it and apply.
Turn off the I-tunes/Quick Time, Adobe Speed Launcher and the Java Update Scheduler... This will save you quite a bit of memory and make the computer a bit peppier...
John1782 / StevieC
Your instructions worked flawlessly. This no longer starts up. [YSearchSuggest.dll ]
Turned off unwanted / needed start up items.
Thankx so much for helping me clean up this computer.
Regards,
bill
You're welcome!
