45515 Members
64 Forums
193807 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#1364836 - 02/06/09 01:59 PM
EGR Valve Cleaning
Loc: Maryland
I have a 2004 Mercury Marauder that obviously has an EGR Valve on it, deleting it will probably cause some problems so that may be out of the question. I ran a bottle of Amsoil PI last summer and I am now doing a Maintenance Dose with Lucas Gas Treatment. I am wondering if the Amsoil PI is good for cleaning the deposits in the EGR Valve, and if this maintenance dose of Lucas Gas Treatment will prevent future deposits. I am wondering if Redline Fuel Injection Cleaner would be a better product to use once a year to clean the EGR Valve. Has anyone on here deleted there EGR Valve, I did it on my El Camino, but that does not have a computer on it. Let me know if I am on the right track to use Amsoil PI every year or maybe I need to use it every 4000 miles instead. Also let me know any thoughts again on Lucas preventing any EGR Valve deposits.
#1364842 - 02/06/09 02:01 PM
Re: EGR Valve Cleaning
[Re: c3po]
Loc: LA
I would like to know how to clean one.
"RX is great, the instructions are not"..Sprintman 7-2009
#1364845 - 02/06/09 02:03 PM
[Re: c3po]
Loc: beaver land EH?
I have a 2004 Mercury Marauder that obviously has an EGR Valve on it, deleting it will probably cause some problems so that may be out of the question. I ran a bottle of Amsoil PI last summer and I am now doing a Maintenance Dose with Lucas Gas Treatment. I am wondering if the Amsoil PI is good for cleaning the deposits in the EGR Valve, and if this maintenance dose of Lucas Gas Treatment will prevent future deposits. I am wondering if Redline Fuel Injection Cleaner would be a better product to use once a year to clean the EGR Valve. Has anyone on here deleted there EGR Valve, I did it on my El Camino, but that does not have a computer on it. Let me know if I am on the right track to use Amsoil PI every year or maybe I need to use it every 4000 miles instead. Also let me know any thoughts again on Lucas preventing any EGR Valve deposits. LOL! granted that your engine burns clean, I simply cannot see how adding combustible additives pre-combustion will help in cleaning EGR valve. If deposits is of concern to you, and assuming that you want your car in it's very best shape, I would (a) take the engine up to temperature as often as possible: i.e. take it on an extended highway drive for hours, and (b) use high quality detergent gasoline, (c) keep your short driving trips to an absolute bare minimum. Otherwise, you may have to do the manual scrubbing methond. Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#1364853 - 02/06/09 02:11 PM
[Re: Quest]
Loc: Utah
I have a notoriously problematic EGR on one of my vehicles, and I have used electrical contact cleaner on with sucess. It fails before I clean it and passes (barely) after. I like contact cleaner because it does not leave residue. My engine is a GM 4.3 with CPI. The EGR gets pretty carboned up and I have to pull it off to clean it.
It is dangerous to be right in matters on which the established authorities are wrong. ..." – Voltaire
#1364860 - 02/06/09 02:19 PM
[Re: JDD]
Loc: Maryland
I always make sure that this car gets up to temperature when I drive it, no short trips.
#1364902 - 02/06/09 03:01 PM
[Re: LT4 Vette]
Loc: Pocatello, ID
Just take it off and clean it out, and reinstall.
Fords seem to have trouble with these.
1998 BMW 323iC Convertible 1975 BMW 2002 5 other cars...
#1364907 - 02/06/09 03:04 PM
[Re: crw]
Loc: LA
but WHAT is the process??????????????????????????????????????
#1364912 - 02/06/09 03:07 PM
[Re: crw]
Loc: PA
EGR only has exhaust going through it. Any fuel system cleaner wouldn't even reach it until it had passed through the combustion chambers and been burned. If you want to clean the EGR valve, you'll have to remove it.
That said, if you put in the effort, chances are you'll be pretty satisfied with yourself after having accomplished it. There's just something about washing hard gunk away with vicious solvents...
If you want to prevent future clogging, the best way is to make sure your engine burns cleanly. A good fuel system cleaner might help with that. Also try to use good quality fuel and a low-SAPS oil, and make sure your tune is good.
1996 BMW ///M3 RLI: 15w-40 Low Ash, ATF PLUS, 75w-110 LS BMW: DOT 4
#1364923 - 02/06/09 03:15 PM
[Re: d00df00d]
Loc: Pocatello, ID
On my 4.6L (which I used to have) it takes less than five minutes to remove, inspect, and reinstall. But it never got dirty.
On my 302 from '91 vintage, it would get clogged up with carbon. I just used my one remaining clean finger to wipe it out, but I suppose you could also spray something in there.
What it is, is just carbon sitting in there, which causes the valve to not operate properly. Seriously, it's just a matter of wiping it out.
The trouble might be, once you have it off hopefully the gasket will still be good when you go to put it back on. Again, on my 4.6 the gasket held up fine and I was able to reuse it.
#1364928 - 02/06/09 03:28 PM
[Re: c3po]
Loc: los angeles
Have you ever used Carbon Killer? It's at http://www.slip2000.com I have not tried it.
THIS SPACE FOR RENT, PLEASE PM ME.
#1364940 - 02/06/09 03:37 PM
[Re: d00df00d]
EGR only has exhaust going through it. Any fuel system cleaner wouldn't even reach it until it had passed through the combustion chambers and been burned. If you want to clean the EGR valve, you'll have to remove it. EGR valves rarely go bad. Problems with the EGR valve are commonly due to a clogged (carbon) EGR passage. Shops will gladly sell you a $400 EGR valve, though. An EGR passage can be cleaned out with an electric drill and a length of frayed wire (old speedometer cable etc). If you then polish the EGR passage to have a smooth like glass finish, the passage will remain usually free of deposits.
#1365111 - 02/06/09 06:14 PM
[Re: moribundman]
Loc: Maryland
Does anyone know about this BG EGR Valve Cleaning Service. I think they put some chemical in the EGR ports to clean them out, has anyone tried this. Also, does anyone know how much it costs.
#1365274 - 02/06/09 08:58 PM
[Re: c3po]
Why don't you test the EGR valve before you go ahead and damage or destroy its diaphragm with a solvent?
#1365284 - 02/06/09 09:13 PM
[Re: moribundman]
Loc: Phila,PA
I cleaned the one on my 6.8L V10 F250. It was a pain to get off. Once off it is a really neat little device.
I took a few q-tips, dipped them in solvent and scrubbed. keep getting fresh q-tips with new solvent. After about 15 Q-tips the thing was like brand new.
Take apart you throttlebody and scrub that with solvent and rags. Make sure you scrub the butterfly plate real good.
Unplug the battery so the computer can remap air/fuel ratio with clean equipment, and BAM!! Your engine runs smoother, and gets slight better MPG!
// 2013 Subaru WRX // SOLD: -11 Volkswagen Jetta -04 Lincoln LS -01 Ford F250 -04 Mazda Rx-8 -97 Jeep Wrangler -97 BMW M3 -97 Nissan Maxima
