Installing a dish washer.
by ram_man
4 minutes 12 seconds ago
Strangest Three Wheel Car Ever
by Fsharp
44 minutes 56 seconds ago
Remove Gasoilne and other Blowby Gasses
by landtoy80
53 minutes 23 seconds ago
Trans Am said goodbye to his battery today.
by ls1mike
Today at 09:39 PM
Lil Big Rig - I want one
by montero1
Today at 09:01 PM
[Cut Open] Champ PH2808 - Torn Pleat
by Bud_One
Today at 08:41 PM
2015 silverado dealer oil change
by Realtech214
Today at 08:27 PM
delo 400 $17/gallon at walmart now?
by motor_oil_madman
Today at 08:23 PM
Looks like Classics are going bye,bye at WM
by chainblu
Today at 08:18 PM
acdelco ph64
by gabriel9766
Today at 08:11 PM
Using USED oil as a top off?
by Vern_in_IL
Today at 07:57 PM
Question-Buying from a rental agency
by powayroger
Today at 07:31 PM
TrogDorInjection, wytenow, maxud, OrchardAuto, Moredoor
56874 Registered Users
84 registered (BigD1, 2015_PSD, BigCahuna, bdcardinal, Basshead, 6 invisible), 1117 Guests and 201 Spiders online.
56874 Members
66 Forums
244474 Topics
Page 1 of 3 1 2 3 >
#1363833 - 02/05/09 04:44 PM 2002 ford v6 escape: replacing alternator...
mikeinaustin Offline
Loc: austin, texas
i came across the following directions on the internet on how to replace the escapes alternator. is all the below work really needed just to replace the alternator??? Any of you have experience doing this?
[2002 ford v6 escape]
The easiest way or should I say the most convenient way to change the alternator is to:
1. Loosen lug nuts and wheel hub nut on right front tire.
2. Place the car on a jack stand on the right side.
3. Remove the tire.
4. Remove the plastic splash guard.
5. Remove the belt.
6. Pop the ball joint out.
7. Remove the lower control arm.
8. Take wheel hub nut off.
9. Remove drive axle carrier bearing nuts.
10. Remove entire axle as one unit.
11. Take wire and connector off alternator
12. Remove all three alternator bolts and push alternator off to the side.
13. Remove alternator mount bracket.
14. And finally remove alternator
#1363860 - 02/05/09 05:04 PM Re: 2002 ford v6 escape: replacing alternator... [Re: mikeinaustin]
John_K Offline
Loc: Columbus, Ohio
Sounds like...
1. Disassemble vehicle, set aside.
Incredible.
John
2009 Mercury Grand Marquis, 8 cyl auto, 53xxx miles, QS syn
2005 Hyundai Sonata, 4 cyl auto, 85xxx miles, Pennzoil/Castrol
Current oil stash: 551 qts.
#1363862 - 02/05/09 05:06 PM Re: 2002 ford v6 escape: replacing alternator... [Re: John_K]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
And their sales are slumping why?
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1363867 - 02/05/09 05:13 PM Re: 2002 ford v6 escape: replacing alternator... [Re: StevieC]
MNgopher Offline
Loc: Lakeville, MN
While not defending how hard it may be to replace it, if it is anything like all the other Ford OEM alternators I've had experience with from my explorers and F150's, it will give over 150,000 miles of reliable performance before it gives up the ghost. Not exactly an "everyday" job. The GM alternators I've had experience seemed to go 60,000 and then croak. Of course, that was many years ago, so it may have changed with the times...
#1363871 - 02/05/09 05:18 PM Re: 2002 ford v6 escape: replacing alternator... [Re: MNgopher]
StevieC Offline
I could understand a bit of work to get it out, but all those steps listed above are just ridiculous. I bet you the power steering pump is easy to replace because it never needs to be on most cars...
Designers need to think... Why were older cars easier to service?
#1364032 - 02/05/09 07:17 PM Re: 2002 ford v6 escape: replacing alternator... [Re: StevieC]
OVERKILL Online   content
Loc: Ontario, Canada
How easy is the one to replace on your Hyundai?
The one on my Expedition is dead in the middle of the top of the engine....... The Lincoln and Mustang are two bolts.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#1364034 - 02/05/09 07:18 PM Re: 2002 ford v6 escape: replacing alternator... [Re: OVERKILL]
firemachine69 Offline
Loc: Sudbury, ON, Canada
I promise you that 99.9% of the purchasing public never care to check how much replacement brakes cost, or where the alternator is located...
I have a very bad mem... What were we talking about again?
#1364040 - 02/05/09 07:25 PM Re: 2002 ford v6 escape: replacing alternator... [Re: firemachine69]
StevieC Offline
Mine is at the back of the engine. 2 bolts and it's off. I checked this out already in my Technical manual.
Lots of space to get at it, and an easy disconnect for the wiring, you don't even have to disconnect the battery!
#1364047 - 02/05/09 07:31 PM Re: 2002 ford v6 escape: replacing alternator... [Re: StevieC]
artificialist Offline
Loc: Florida
Depends on the older car...
On Ford Mustangs where a big block was stuffed into the space of a small block, work was a major pain.
Oh, and define exactly what you mean by older. Nissan FWD Maximas and 300ZX models from the 1980s were a serious pain to work on, and they were prone to alternator failure, P/S rack failure, compressor failure, as well as other stuff. They may just be considered a modern car because they have Multi Port injection, computerized automatic transmissions, and were designed entirely on computers.
2010 Lancer Ralliart Sportback
#1364052 - 02/05/09 07:35 PM Re: 2002 ford v6 escape: replacing alternator... [Re: artificialist]
Lumina Z34 is apparently a nightmare to change the alt on. You have to drop the K-member or something?
02 Expedition
06 Charger R/T
14 Charger SRT-8
#1364053 - 02/05/09 07:35 PM Re: 2002 ford v6 escape: replacing alternator... [Re: artificialist]
StevieC Offline
70's and some early 80's... All the cars I seen growing up you could practically hide under the hood with the engine!
#1364055 - 02/05/09 07:37 PM Re: 2002 ford v6 escape: replacing alternator... [Re: StevieC]
Not bad, Ford was using quick disconnects on the alternators in the 80's ;\) Switched to the "eye" setup that needs to be unbolted with the 3G due to current capacity.
I bet not every Hyundai has an easy to change alt though ;\)
02 Expedition
06 Charger R/T
14 Charger SRT-8
#1364064 - 02/05/09 07:41 PM Re: 2002 ford v6 escape: replacing alternator... [Re: OVERKILL]
StevieC Offline
Sisters was, and the same engine that Hyundai uses in my mom's Kia is very easy... Upfront and 2 bolts again!
#1364073 - 02/05/09 07:47 PM Re: 2002 ford v6 escape: replacing alternator... [Re: StevieC]
I'll have to check my aunt's Tucson next time she's up ;\)
02 Expedition
06 Charger R/T
14 Charger SRT-8
#1364076 - 02/05/09 07:48 PM Re: 2002 ford v6 escape: replacing alternator... [Re: OVERKILL]
StevieC Offline
4 Cyl or 6?
Page 1 of 3 1 2 3 >
