New HDEO OIls.....a question?
by BigJohn
02/05/16 05:29 PM
I Finally Pulled the Trigger...
by MCompact
02/05/16 05:22 PM
Best oil filter for Toyota 1GR-FE
by DrRoughneck
02/05/16 05:17 PM
How long can unused oil filters sit?
by SkyXSteel
02/05/16 05:16 PM
Particulate Filters and Ash
by BigJohn
02/05/16 05:09 PM
1956 Triumph 500.
by DC_Stewart
02/05/16 04:32 PM
VW Diesel oil filters ?
by DC_Stewart
02/05/16 04:23 PM
Any experience with 98-02 corolla?
by barkingspider
02/05/16 04:11 PM
nice video
by raaizin
02/05/16 03:36 PM
Dumbest thing you have been told at a parts store
by tojo1968
02/05/16 03:30 PM
Our cars are due for oil, any recommendations?
by MilesToEmpty
02/05/16 02:30 PM
roof shingles- come from oil?
by edwardh1
02/05/16 02:28 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
98 registered (3for3, 2015_PSD, 05LGTLtd, 901Memphis, 04SE, 11 invisible), 1539 Guests and 158 Spiders online.
56834 Members
66 Forums
244277 Topics
#1326027 - 12/30/08 05:52 PM BG44K Review
JAG Offline
Loc: Fredericksburg, VA
Vehicle: 2003 VW GTI 1.8T Engine
Mileage: 113K miles
Purpose of additive use: Clean carbon from piston tops and clean injectors
Pre-Test Thickness/Coverage of Piston Tops' Carbon: Majority of piston tops' surfaces were covered with carbon with a thickness approximately equal to thickness of a penny. There were no areas of clean metal.
Results: Approximately 50% of the piston tops' surfaces are now clean metal. The rest is a thin layer of carbon equal in thickness to one or a few pieces of paper. This means that the percent change in the volume of the carbon is much greater than 50% and that's what most matters. I have no idea how much injector cleaning occurred but considering how the piston tops cleaned up, I think that the injectors were cleaned too.
Conclusions: I am pleased with the results. Sure, I would have liked to see 100% clean metal on the pistons but the improvement I got was large. I bet that two treatments would make them almost completely clean.
2015 Dodge Challenger SXT - Super Track Pak
#1326048 - 12/30/08 06:26 PM Re: BG44K Review [Re: JAG]
cos Offline
Loc: Metro Detroit
Nice!
How did you observe this? Some kind of bore scope down the plug hole?
'06 Ford Fusion 2.3/manual
QSUD 5W20
Amsoil MTF/MTG
#1326074 - 12/30/08 06:57 PM Re: BG44K Review [Re: cos]
JAG Offline
I simply took the spark plugs out and looked down the holes while using a flash light.
I should clarify that the carbon thickness observations I made were only by "eye-balling it".
#1326077 - 12/30/08 07:00 PM Re: BG44K Review [Re: cos]
Reddy45 Offline
Loc: USA
I'm interested. How does this compare to Seafoam, B12, MMO, etc..?
Google is telling me this is a can you pour into the gas tank, but I've seem some BG products that are run through a pump machine to clean carbon?
#1326097 - 12/30/08 07:23 PM Re: BG44K Review [Re: Reddy45]
JAG Offline
I can only compare this to FP+ which I used for several thousand miles...actually probably over 5K miles. The carbon on the pistons is what was there AFTER using FP+ so it did not "do the trick". I may experiment with higher than recommended doses of FP+ eventually.
BG44K that I used was in the metal can. BTW, what a pain not having a built-in neck like most bottled fuel treatments have.
#1327115 - 12/31/08 09:16 PM Re: BG44K Review [Re: JAG]
BearZDefect Offline
Loc: Lexington, KY
JAG,
Thank you for writing up the results of your experiment for us to see.
How were you able to eyeball the initial thickness of carbon buildup before treatment? Was there raised writing on the piston crowns that helped?
I can see how, once some areas are cleaned off, one can eyeball it pretty well.
What dose did you use?
#1327251 - 01/01/09 12:44 AM Re: BG44K Review [Re: BearZDefect]
JAG Offline
The initial thickness was eye-balled by scraping the deposits with a long metal rod.
The dosage I used was one bottled in a ~14 gallon tank (including the reserve).
#1328942 - 01/02/09 06:43 PM Re: BG44K Review [Re: JAG]
BearZDefect Offline
Loc: Lexington, KY
Thanks, JAG.
#1330791 - 01/04/09 03:55 PM Re: BG44K Review [Re: BearZDefect]
BearZDefect Offline
Loc: Lexington, KY
I was hoping someone would pipe up, but since nobody has I'll ask:
For you experienced steam cleaners, haven't some of you done similar before and after comparisons? I wonder how the results compare to BG44K.
Obviously using BG44K involves less work, but more money, compared to hot water injection.
#1332243 - 01/06/09 01:33 AM Re: BG44K Review [Re: JAG]
Tempest Offline
Loc: Las Vegas NV
Where did you find this stuff at JAG? Heard of it before but haven't seen it for sale.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#1332423 - 01/06/09 09:33 AM Re: BG44K Review [Re: Tempest]
JAG Offline
I got it at a VW dealership. Try searching online for BG distributors in your area...many of them will be places that also perform service work since the BG lineup also includes machine-powered flushes.
#1354757 - 01/27/09 09:22 PM Re: BG44K Review [Re: JAG]
hooperswish1 Offline
Loc: highlands ranch, colorado
Napa dealers carry it. Pretty pricey-$20+ Works very well IMHO.
#1355086 - 01/28/09 10:58 AM Re: BG44K Review [Re: hooperswish1]
ocrstar Offline
Loc: N. Michigan
eBay.
