ATP AT-205 good engine cleaner ?
by kr_bitog
05/25/16 06:16 AM
List of VOA's from Russian Oil Club
by spiderbypass
05/25/16 01:43 AM
Quicksilver Prem Plus
by jmw116
05/25/16 01:39 AM
Creating white letter tires
by turtlevette
05/25/16 12:22 AM
Hypothetical Question On Incorrect Filters
by Triton_330
05/25/16 12:18 AM
Pennzoil $2.99/qt at tractor supply!
by Chris142
05/24/16 10:25 PM
Brother passed away this morning
by oilboy123
05/24/16 10:21 PM
Changed oil tonight - what a fine evening
by pacem
05/24/16 10:10 PM
Interesting observation on Ultra
by RusskiBoSS
05/24/16 08:48 PM
2009 Honda Civic Cooling fan running continuously
by Doog
05/24/16 08:31 PM
adhesive for pea gravel?
by xfactor9
05/24/16 08:19 PM
Micro guard Gl14609 150 hours
by robo339
05/24/16 08:02 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
61 registered (97f150, asisensei, Asterix, ABerns, 7 invisible), 1223 Guests and 112 Spiders online.
57973 Members
66 Forums
249375 Topics
#1343103 - 01/15/09 08:30 PM 2007 Ford Edge transmission
stp44 Offline
Loc: Bowling Green Ky
Does anyone know if the 2007 Ford Edge has a drain plug for the transmission? If so where is it located.
#1343160 - 01/15/09 09:14 PM Re: 2007 Ford Edge transmission [Re: stp44]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
Ford Trannies don't last very long, so I wouldn't worry about changing the Fluid as you will be changing the tranny soon enough... JUST KIDDING!
Go to the dealer and ask them to show you at the Parts Desk, or just enquire about whats involved and they will tell you... Then you leave an do it yourself!
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1343243 - 01/15/09 10:29 PM Re: 2007 Ford Edge transmission [Re: StevieC]
bdcardinal Offline
Loc: Santa Barbara, CA
Transmission Fluid Drain and Refill Printable View (178 KB)
Material Item Specification
MERCONŽ V Automatic Transmission Fluid
XT-5-QM (or XT-5-QMC) (US); CXT-5-LM12 (Canada) MERCONŽ V
NOTE: In order to completely clean the torque converter, this procedure needs to be carried out 3 times.
With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02.
NOTE: If an internal problem is suspected, drain the transmission fluid through a paper filter. A small amount of metal or friction particles may be found from normal wear. If an excessive amount of metal or friction material is present, the transaxle will need to be overhauled.
Remove the transmission fluid drain plug and allow the transmission fluid to drain.
Install the transmission fluid drain plug.
Tighten to 9 Nm (80 lb-in).
Fill the transaxle with clean transmission fluid.
Start the engine and let it run for 3 minutes. Move the range selector lever into each gear position. Repeat Steps 2, 3, 4 and 5 two more times.
After the transmission fluid has been changed a total of 3 times, check the transmission fluid level for a final time, making sure that the transmission fluid is at the correct level.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#1343929 - 01/16/09 04:04 PM Re: 2007 Ford Edge transmission [Re: bdcardinal]
stp44 Offline
Thanks bd cardinal. I now know it has a plug but I do not see any thing that even looks like a drain plug. Do you know the location?
#1344584 - 01/17/09 09:01 AM Re: 2007 Ford Edge transmission [Re: stp44]
Rustyknife Offline
Loc: Missouri
its got the 6f50, and its right on the bottom.....those suck to refill
#1344690 - 01/17/09 11:43 AM Re: 2007 Ford Edge transmission [Re: Rustyknife]
Eddie Offline
Loc: Florida, Cape Coral
I thought the Ford Edge with the 6 spd AT used a Aisin transmission. That AT requires A 3309 fluid
CX5 Touring 2.5L :-)
#1344726 - 01/17/09 12:19 PM Re: 2007 Ford Edge transmission [Re: Eddie]
Ben99GT Offline
Loc: MS
The Edge does not use the Aisin. It uses the Ford 6F (Ford-GM JV) trans.
Ford has moved away from the Aisins.
2001 F150 Supercrew
1991 Mustang LX notch
1999 Mustang GT
