Round holes AND louvers! Oh the humanity!
by Nick1994
08/25/16 04:20 PM
Should I change the oil when changing spark plugs?
by THafeez
08/25/16 04:08 PM
Maxima synthetic oil
by gman2304
08/25/16 04:02 PM
Mobil vs. Castrol: Battle of the Walmart 0W-40s
by 1JZ_E46
08/25/16 03:58 PM
Need advice for older car burning too much oil
by Car_Careguy
08/25/16 03:29 PM
Camaro 2.0T review by subaruwrxfan
by wemay
08/25/16 03:18 PM
Dryer Duct Boosters?
by 2015_PSD
08/25/16 03:02 PM
some strange lawsuits against fast food franchises
by John_Conrad
08/25/16 02:40 PM
Rotella T5 10W-30 in Chevy Z71
by RHALL
08/25/16 02:20 PM
Multigrade Oils in Mowers
by camrydriver111
08/25/16 01:59 PM
Is this GM executive serious ? Or he's a moron ?
by HTSS_TR
08/25/16 01:40 PM
My UOA with Frantz TP Filter
by Jonzobot
08/25/16 12:43 PM
ryaneirich, Gabe78, taters, Louis_Desbiens, Burk
58918 Registered Users
89 registered (97f150, 1JZ_E46, 007, 2015_PSD, 390pi, 2002 Maxima SE, 9 invisible), 1855 Guests and 5 Spiders online.
58918 Members
66 Forums
253549 Topics
#1343103 - 01/15/09 08:30 PM 2007 Ford Edge transmission
stp44 Offline
Loc: Bowling Green Ky
Does anyone know if the 2007 Ford Edge has a drain plug for the transmission? If so where is it located.
#1343160 - 01/15/09 09:14 PM Re: 2007 Ford Edge transmission [Re: stp44]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
Ford Trannies don't last very long, so I wouldn't worry about changing the Fluid as you will be changing the tranny soon enough... JUST KIDDING!
Go to the dealer and ask them to show you at the Parts Desk, or just enquire about whats involved and they will tell you... Then you leave an do it yourself!
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1343243 - 01/15/09 10:29 PM Re: 2007 Ford Edge transmission [Re: StevieC]
bdcardinal Offline
Loc: Santa Barbara, CA
Transmission Fluid Drain and Refill Printable View (178 KB)
Material Item Specification
MERCONŽ V Automatic Transmission Fluid
XT-5-QM (or XT-5-QMC) (US); CXT-5-LM12 (Canada) MERCONŽ V
NOTE: In order to completely clean the torque converter, this procedure needs to be carried out 3 times.
With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02.
NOTE: If an internal problem is suspected, drain the transmission fluid through a paper filter. A small amount of metal or friction particles may be found from normal wear. If an excessive amount of metal or friction material is present, the transaxle will need to be overhauled.
Remove the transmission fluid drain plug and allow the transmission fluid to drain.
Install the transmission fluid drain plug.
Tighten to 9 Nm (80 lb-in).
Fill the transaxle with clean transmission fluid.
Start the engine and let it run for 3 minutes. Move the range selector lever into each gear position. Repeat Steps 2, 3, 4 and 5 two more times.
After the transmission fluid has been changed a total of 3 times, check the transmission fluid level for a final time, making sure that the transmission fluid is at the correct level.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#1343929 - 01/16/09 04:04 PM Re: 2007 Ford Edge transmission [Re: bdcardinal]
stp44 Offline
Thanks bd cardinal. I now know it has a plug but I do not see any thing that even looks like a drain plug. Do you know the location?
#1344584 - 01/17/09 09:01 AM Re: 2007 Ford Edge transmission [Re: stp44]
Rustyknife Offline
Loc: Missouri
its got the 6f50, and its right on the bottom.....those suck to refill
#1344690 - 01/17/09 11:43 AM Re: 2007 Ford Edge transmission [Re: Rustyknife]
Eddie Offline
Loc: Florida, Cape Coral
I thought the Ford Edge with the 6 spd AT used a Aisin transmission. That AT requires A 3309 fluid
CX5 Touring 2.5L :-)
#1344726 - 01/17/09 12:19 PM Re: 2007 Ford Edge transmission [Re: Eddie]
Ben99GT Offline
Loc: MS
The Edge does not use the Aisin. It uses the Ford 6F (Ford-GM JV) trans.
Ford has moved away from the Aisins.
2001 F150 Supercrew
1991 Mustang LX notch
1999 Mustang GT
